WARNING: READ ALL INSTRUCTIONS BEFORE TRYING ON THIS PRODUCT.
Thank you for purchasing our product! We are excited for you to try our Secrui-Tee: A Safe Self-Bondage & Sleep System. This product is designed for users intending to submit themselves to a safe, secure, and serene experience. Please visit our website for a full listing of our products and remember to play safe!
The base package you’ve purchased includes the following:
• Securi-Tee long-sleeved shirt
• Securi-Tee sleep pants
• Securi-Tee bed sheet (Queen-sized)
• Charging cord
All packaged products arrive fully charged and can hold a battery life of up to ten (10) hours of continual use. A charging port is available at the top right corner of the sheet. Do not use any of our products while they are charging. With safety being our highest concern, all restraints disengage if the battery life depletes to zero. Some users have voiced their desires for a longer experience, and we are designing a version 2.0 set for house a longer battery life.
The Securi-Tee shirt and pants will pull over your torso like normal apparel. This package contains a black shirt and black pants with a grey stripe down the side of each leg. If desired, you can use the zipper attachment at the waist to join the top and bottom articles. The shirt will have a button close to the right shoulder, used to activate the restraint once secured to the bed sheet.
The Securi-Tee bed sheet first over your normal Queen-sized bed frame. There is an additional strap on each corner of the sheet, which will need to be run under your mattress to join in an X-shape. This ensures your movements do not remove the sheet. This also prevents you from sliding off the mattress onto the floor.
Once the sheet is secured, there are three multiple options for anchoring your limbs. There are click-in buckles embedded into the Securi-Tee long-sleeved shirt and sleep pants, as well as throughout the Securi-Tee bed sheet. The shirt has buckles on the front and on the back of the wrists. The pants legs have buckles on the front and on the back close to the ankles. The bed sheet has eight (8) buckles sticking up along the edge of the sheet, one at each corner and one in the middle of each side of the sheet after it has been fitted, allowing for a variety of face-up or face-down positions. Connect the buckles at your wrist(s) and/or ankle(s) to the desired position.
Use your chin to press the button ONCE on shirt’s right shoulder in order to activate the system. The buckles will all pull taught, indicating the system is ready for the user to input the time interval. Any unused buckles will pull under the canvas of the bed sheet. Each tug on a used buckle will add one hour to the timer, acknowledged by an accompanying pull on all used buckles. After ten (10) seconds of no additional tugs or ten (10) registered tugs, the system will lock until the duration is complete.
FOR IMMEDIATE RELEASE: PULL UPWARDS ON ALL USED BUCKLES FOR TEN (10) SECONDS.
Usage Ideas:
• Depending on your position, you may be able to maneuver your body to slip out of the pants and/or shirt, provided you have not zipped them at the waist.
• Tug at random intervals for an uncertain release time
• Roll two six-sided dice and tug that many times. Eleven (11) and twelve (12) are either rerolls or automatic max durations.
• For partner play, have a partner tickle you after pressing the activation button. See if you can prevent any squirming for at least until the countdown completes!
Other products available:
• Securi-Tee Time Projector: plugs into the charge port to project the time remaining onto the ceiling. Note: does use some battery life.
• Securi-Tee Wrist & Ankle Locking Restraints: slips over the wrist and ankles clip-in buckles on the shirt and pants, to prevent slipping out of the garment. Made of soft leather.
• Securi-Tee Randomized Unlock Code: a separately purchased bed sheet that, after the countdown is complete and the restraints lock, will expose one of the unused buckles. If the user can pull on the buckle three times, then the system will unlock regardless of any time remaining. Note: we advise having the lights on for this feature.
• Securi-Tee Love Hug Shirt: A long-sleeved shirt that has additional buckles on the sides, allowing for a straitjacket experience. Similar button activation and time-Teeugging process, with a charging located on the bottom hem of the shirt. Comes with two crotch straps, and built-in chest and side straps to prevent slipping the shirt over the user’s torso.
Securi-Tee: A Safe Self-Bondage & Sleep System (Solo/M)
- bigsmile21
- NeedControl
OMG so hot!! I want one
Any additional features like gags or toys?
A sensory deprivation hood would be good. Something that completely gaggs, blindfolds and deafens a user for a desired time.
Special pants could be designed with vibrational pads to tease your more, sensitive areas. Maybe even some gloves and socks to do the same.
