Because of the switch of the URL to tugstories.blog instead of .com, a lot of the story links on the thread are not working and need fixing. This is also the same with the Author links what links to .com instead of .blog.
This could require a lot of work though as it is a lot of links unless there is a way of re-linking them all in one go.
M/M catalog stories not working
- bondagefreak
- Honorary Member
It doesn't require any work at all.Terry wrote: 2 months ago This could require a lot of work though as it is a lot of links unless there is a way of re-linking them all in one go.
Each author just needs to take care of their entry and change the links from .com to .blog.
I fixed my entry in under a minute months ago.
Alternatively, you can just click on any story link you wanna read and manually replace the .com with a .blog in the address bar. It will send you to the correct story.
