Growing up I have tied myself in different ways, i remember one time while experimenting i did a double ended slipknot on one of my dressing gown belts, slipping a foot and hand in each and pulling tight. It was early one saturday morning, I was rolling about in bed like this enjoying myself, I hear footsteps coming up the stairs and my mother calling..pure panic surged through me as I struggled to shimmy off my covers to get under and hide. She pops her head in, says good morning and says she will make breakfast. She leaves, I could only pray she didnt notice me awkwardly positioned under the covers or she at least pretended. But this tie took abit of working out to loosen the nooses and get out.
Most of the hogties i use to do were just tying my feet, then hands, individually looped, and joining a third dressing gown belt/cord to join, though I never felt truly trapped. Or i will tie my feet/knees, then cross the hand ties through the feet before layng into the hogtie, never satisfying or bringing that adrenaline of im stuck and can't get out right now.
A few years ago browsing the internet I discovered a timed ice release technique using ice in a stocking/sock, this was the answer to a truly helpless self tie up. Living at home with parents, Im not able to get any fancy toys or anything like that. I also do all my sessions between 12-3 ish so everyone is sleeping, I have a room to myself.
I also seem to have a 'problem' where I cum way to easily/fast, like i can not touch my penis at all and I will blow once in position or I start to struggle most of the time. I then free myself instantly and don't get the time to enjoy myself in the moment. So knowing its not going to be fun if i blow right at the start of a session and i truly cannot free myself for a limited time, I try take some precautions(many times have failed).
About an hour or so before im set to tie myself using the ice in a sock technique(sometimes even more earlier in the day just thinking about it), I masterbate to avoid instantly cumming once im in position. Once everyone goes to bed i get to work, remove my covers and pillows from the bed(leave one for my head) and gather all my materials and tools.
I then tie two dressing gown belts to the bottom corners of the bed in preperation for my feet, and a solid curtain ring/loop to each top corner using shoelaces. I then go and get a large cup of ice cubes(we get big bags of them) and return to my room. I strip to my boxers, pull my penis and balls through the front hole, put a sock over them, and tie a bootlace around my base keeping the sock on, but not too tight i cant fit a finger between(acting as cock ring). I then put on a leather belt just below waste/above penis, make a loop with the closing strap, and put my penis in pinning it to my body immobile.
I then put 2 socks in one (make stronger/absorb water) and put a decent amount of ice in the toe of the sock, i thread the sock through one of the top corner loops on the bed so the ice stops the sock pulling through, and tie the sock close to the ice with a dressing gown belt. I repeat this for the other corner, i then tie a shoelace to the top frame, with sciccors on the other end just incase of emergencies.
I tie my feet to each bottom corner simply but that i need hands to untie, stretch my self up and work out on the dressing gown cords where my hands will be, i tie a knot, then a slip knot that will stop at that knot, so it won't cut circulation in wrists, but too tight to slip out. I double check each wrist individualy, making sure it not to tight, then i put a binder clip on each nipple, a black scarf wrapped around my eyes as a blindfold, lay back and reach up, find each slipknot with each hand and pull tight. I am totally trapped in an X shape, there is no way for me to free my hands without using the other but i cant reach. Pure adrenaline and slight panic as i know there is no way out until the ice in one of the socks melt so i can pull my arms through, or use sciccors to destroy my accumulated bondage stuff.
I love the feeling i get being totally trapped and knowing i cant do anything to get out, in this session before i have blown early real fast and also been very panicked and wanting out and feeling its hopeless til the ice melts. Other times i have tried tying my balls/tying balls to bottom of bed. One time in my stupid super horny thinking, i added headphones tied in place with orgasm inducing binuarals, and tied vibrating shavers/toothbrushes to my penis to try for multiple orgasms forced. That was one session i wished i gagged myself(dont want to risk), tho thinking about it now i would love to be forced to orgasm again but id prefer to try not while im stuck for real
Very sorry for the long post, i just wanted to share my ice in a sock method really but i have done so many different self bondage sessions over the years, some weak and some gone wrong. So far though, ice has never failed and im usualy out after 20-40min if i go easy on the ice. The blindfolded/hearing tones and not being able to move or get out was very tough not to shout for help, had to just remind myself i will be free it is ice.
True Self Bondage (M/self)
I've seen lots of people use ice "timers", but I have yet to try it myself.
Wow, you’ve developed a quite elaborate self-tying method. I did some crazy stuff too when I was younger, but you’re a few notches above what I did! Looks like you have fun. Thanks for sharing!
Cute story! Part of me wonders if you should just go on eBay and buy some handcuffs
Kinky twenty-something bisexual.
PM if you're bored
PM if you're bored
Great self bondage story.
I like it because i can do a really strict bondage but know im going to get out by self release, im trying to figure out a solid way to use it other than spread eagle, you should try it sometime and write a story, seems fool proof and you can kinda do a short one if you use little ice.shyguy92 wrote: 11 months ago I've seen lots of people use ice "timers", but I have yet to try it myself.
Thanks, haha well I kinda been doing it for at least 4 or 5 years now, most weekends. Alot of trial and error and working out better ways and reading others attempts.Canuck100 wrote: 11 months ago Wow, you’ve developed a quite elaborate self-tying method. I did some crazy stuff too when I was younger, but you’re a few notches above what I did! Looks like you have fun. Thanks for sharing!
Thanks, and i did want to maybe when I move outEl_llama wrote: 11 months ago Cute story! Part of me wonders if you should just go on eBay and buy some handcuffs![]()
Thanks
