This is story of the hardest to undo TUG I played with my ex-girlfriend Jennifer.
When my ex-girlfriend Jennifer and I were about 6 months into our relationship, we got to try something that, although we regretted it at first, I now look back on it as a good experience. At this point we had already tried the roleplay (the one where she got her wrists hurt, but the one where she got to squirt again) and we were looking for new things to try or other roleplays we could actually do (due the fact that being completely alone in a house was something really hard to achieve).
What happened was that we managed to get on our hands a roll of brown packing tape (the most common in Cuba) that fell from a truck (this isn’t a figure of speech, it literally fell from a truck when they began to accelerate after a red light, I grabbed to try and return it, but the truck just sped away before I could get to them).
Seeing that I had just got a new bondage tool, I called Jennifer and told her what just happened, and she got excited. This happened on a Tuesday. The next Friday, when I picked her up from college and went to my house, she was kind of overly excited. Other than tying her up with the tape, we hadn’t planned anything else. When we arrived, after calling my parents and sister, I calculated we had about an hour, maybe two completely alone, so we went wild (as much as we could anyway). The plan was simple: the roll was almost empty, so what we were going to do, as packing tape was bad for gagging, was that we were going to use it up all in a single TUG.
To avoid having issues in case of emergency (or my family arriving early), she only took off her underwear (she was wearing a skirt and a blouse that day).
I then proceeded to tie her hands in front of her, then I tied her breasts using two long strips, and then gagged her wrapping the tape around her head three times. We already had scissors to cut the tape, so we were “ready†in case of emergency of being caught.
She kneeled in front of me and started jacking me off. After maybe a minute or two I told her to stop, I made her stand, and tied her even more parts of her body with the tape (her feet, legs and thighs and then tied her elbows together and then hands to her chest). I laid her face down on the bed and started fingering her pussy.
After getting her wet enough, I put on the condom and started fucking her. We changed the position a couple of times and ended up in a sort of doggie style, on which she had her orgasm and I (after jacking off outside) came inside her (with the condom still on).
After disposing of the condom, it came the moment we never thought about: removing the tape. Even if packing tape doesn’t adhere too much to the skin, it does to hair, and she had a lot of hair on her head and arms (very short, almost transparent and very smooth hair, but a lot of it nonetheless). I started to cut the tape, and slowly peeled it off from her legs. It took me about two minutes to get all the tape out of her legs.
Then came the arms, and these ones were almost traumatic.
I first cut the tape so she could freely move her arms, then I just peeled off the pieces on her back and chest. The pieces on her wrist became loose with the sweat, so they were easy to peel. But then, the ones in the upper arms, on the first one (her right arm), the elbow piece came off somewhat easy, the others were painful. Very painful. She could feel her hair getting plucked out by the tape. I pulled it out slowly at first, but her expression of pain made me want to end it fast, so I warned her that I would pull it fast. She nodded and I pulled with all my strength. Her skin went red after that, and I could see the small, almost transparent hairs glued to the tape. For the left one, I tried to get it wet, so it would unstick, and it worked somewhat well, although it was still painful.
Then it came the head’s turn. The front part of the gag was already loose because of her saliva and sweat, but all the back was glued to her hair. With the scissors I cut the gag (separating it from her skin with my fingers) near her lips. Once it was only stuck to the back of her head (where the hair starts to grow), I went to get water. Apparently, it took me too long to fill the glass. I heard a small cry of pain and went back running to the bedroom. She was on the bed with teary eyes, holding the tape. She pulled it out herself and plucked out a lot of hairs, so, naturally, she was in pain. She had red marks all over her arms and some on her face (luckily those marks disappeared a short while before my family arrived).
I gathered every piece of tape and dispose of it, and then spent the rest of the afternoon (until my family arrived) cuddling and nursing the marks.
Learning about tape (M/F)
- Flyingvulture
Pro tip for everyone twith ape over any hair:
Grab the hair (like if you were making a ponytail) or pull it away (in case of beard) so when you pull the tape it pulls against the force you're applying instead of pulling directly from the follicle.
For short hair, push the skin (making the hair to tense between skin and tape) and then push the hair just above the follicle, that way you make an "anchor point" that will be receiving the pull instead.
That is a lot less painful
TW: @VultureLeader
Tumblr: Wrapspirit
Tumblr: Wrapspirit
