Do harness gags hurt?(all)
brittanydeel864
Post by brittanydeel864 »
Ball gags already strain or hirt ypur jaw what aboy harness gags?
Girl early 20s wears a chastity belt occasionally. M/F lover.
illest
Post by illest »
My experience with harness gags are actually rather comfortable. One thing about harness gags are that they're tight so say if it's a ballgag you're not going to be able to work it out your mouth as easily as you would a standard ballgag. My only bad experience was one that came too small; I wanted to make it work amd in the process the straps that covered my face left marks for a hour and I was afraid they wouldn't disappear and people would see them.
brittanydeel864
illest wrote: 1 year ago My experience with harness gags are actually rather comfortable. One thing about harness gags are that they're tight so say if it's a ballgag you're not going to be able to work it out your mouth as easily as you would a standard ballgag. My only bad experience was one that came too small; I wanted to make it work amd in the process the straps that covered my face left marks for a hour and I was afraid they wouldn't disappear and people would see them.
I don't want facemarks. Ball gags already hurt.
illest
Post by illest »
brittanydeel864 wrote: 1 year ago
It won't happen under normal means. You have to be a idiot like I was where I was so much in the moment I tried to force strap a woefully small harness ballgag I ordered to finish a self-bondage setup rather than be reasonable and settle for my much better fitting harness ring gag.
brittanydeel864
I'm worried it will leave marks over my nose or hurt my head.
