Sam Marshal : 01 - Wood and Steel Toys (M/F)
Sam Marshal's stories
By Sam Marshal
Monday, February 16th 2004 - 08:12:16 PM
In 1995 I was a freshman that had 6 years in navy. The 6 years was spent as a machinist. While going to college I worked for a small welding and machine shop.
I met a women in college that good looking. She was a in her start of her third year of school. She was not so much a model good looking but the way she carried her self very attractive to me. We dated for two year until she graduated and found a job and move away. As we got to know each other we spent time together and became intimate. After a few months dating she asked me to stop by she had a surprise for me. If she was not home get the key from the fake rock and wait.
What I found after I retrieved the key was Nancy spread eagle held in places with 4 leather cuffs that were locked on. She had built a self tightening contraption and a time release device.
One end of the cuffs was anchored to four nylon load binders, the type that uses a one way cam clamp. The other ends of two were anchored to time release device. The time release was anchored to the wall. One on each side of the bed.
The Self Tightening Contraption used the tensioning strap run threw a ring located 5ft up on the wall and toward the bed and had a weight added to the strap so it would keep pulling on tightening strap. The weight was set to pull at 10lbs on take up side of the one way cam. That way all it did was keep taking up any slack in the cuff side of the one way cam. That way before long she was stretched tight and not much wiggle room was left.
The time release device was made of 1 ½" steel pipe one end had an eye bolt on one end. That end was attached to the wall. The other end had steel cap with a slot cut into it so a ¼" x 1 ¼" 6" piece of steel, which had 5/8" holes drilled into the length of it could be slid into it. When the piece of steel was put into the pipe it was filled with water and frozen it made a time release device. The steel will not slide out until the ice melts.
To say the least I was a little shocked to say the least when I found her like that. I started to look for the key or a knife to cut her loose but she told me to relax and take advantage do what I wanted. We played for two hours before the time released let go.
As time went on she asked if I could build her some bondage toys out of wood and steel.
I did build her some toys one was a stainless steel ring for her neck it was highly polished and could be mistaken of jewel along with bracelets for wrist and ankles. They were locked on with a small screw. She ended up wearing them 24/7 and no one suspected they were for bondage.
The most unusual was a chastity belt out of stainless steel. She had found a web site devoted to chastity belts. There were not any plans of how to build one but they did have good pictures and how to measure a person for one. I used that information and built her one. It took her about 10 weeks to get use to wearing it 24/7. I modified chastity belt from the picture and use one rod between the butt cheeks instead of two chain running over the butt cheeks it made it easier to conceal under clothing. The web site said it needs to fight snuggly so it dose not move a round and chafe and because of that it is easy to conceal under clothing.
Sam Marshal
Marshal99876a@hotmail.com
Index of all stories in the "Archive for Adults" section
Thursday, February 26th 2004 - 03:34:48 AM
In 95 the first part of December I had manufactured for Nancy a set of bracelets and a collar made of stainless flat stock ¼' by ¾'. The set was polish to jewelry like finish. All of the hinges were riveted shut ground smooth. Where the collar & bracelets open & closed that took a socket head screw in the finger joint to keep it closed. With out the wrench the collar or bracelets would not open, just like a lock. If some one asked she could and did show the person the screw and the tool to take them off. That did not happen often.
Now a lot of the time when we went out together. I would just use a plastic cable strap to hold her wrist together behind her when we drove somewhere. I kept a wire cuter handy in the car just encase we got stopped by a cop. That has happened a few times. When it did Nancy would get very excited about being discovered. I just told her to turn her back to me and stick out her hands so I could cut the cable strap. It worked every time we got stopped. Because we were moving a round a lot in the car the cops usually wanted to search it all they ever found was a bag of cable straps, wire cutter and small coil of coax cable in the back seat and few cut cable ties.
What I liked about those cuffs and collar was all you need to have to secure was a simple padlock or four of them. A few choke chains from the pet store and you could have a very sexy set of slave chains with out any signs of locks. Just open the bracelets and slip the rings of the choke collars on the bracelets and collar and close them again.
One time we were going to a movie to make things a little more interesting. I had gotten a vibrating egg and a panty girdle for Nancy to wear for the after noon at the movies. Just before we were to leave for the movies, I had use a padlock on her bracelets to lock her hands behind her back. I removed Nancy pants and pulled her panties down and put the egg in and then pulled the panties up. Next had her step into the panty girdle to make sure the egg did not have a chance of falling out. I replaced Nancy pants, to say the least Nancy was not sure she liked where this was going. Before we left the apartment I replaced the padlock with a cable strap and tighten it to 6' inches so she could have some movement of her arms. Put her long coat on her to cover the fact her arms were pined behind her. Off we went to the movies, all the time using the egg turning on and off just enough to teas her. Four hours latter Nancy was one very turned on women that wanted go to bed. It turned out Nancy like doing that, so we did it quite often.
Sam Marshal
