https://www.deviantart.com/cannibalandr ... -862461968
MMMMFFF MMPPFFFHH HHHMMPPFFF!!!!
Let Me GO!
Gal Screamed and muffled roared through out the empty home as the notorious "Mummification Ran Sacker" choose wisely the perfect timing to capture and bundle up the famous starlit!
Why a hand full of rags and thick bands of cloth he stuffs and gas Gadot mouth full, then cleave ties her lips tight, leaving bulging fabric muffling her grunts, then wraps duct tape seal the all the cloth in, then takes vetwrap and really tightly applied the layers dozen upon dozens of layers till she's totally helpless gagging and scowling at her captor, even though indent from the cleave gag was still viable, she was Definitely Not making any sounds loud enough to reach the other floors or outside!!
Next was the Mummifier's specialty, Lots and Lots of tightly wrapped layers to bound Gal in an Inescapable Massive Cocoon! 4 thick Sherpa blankets each rolled with her perfectly swaddled up tight like a burrito with each turn and pass of the fabric cocooning her more and more the thickness of the cocoon couldn't be understated, she was wrapped in 6 inch thick cocoon of tightly stretched blankets, 2000 Meters of boat ropes, super thick like hemp ropes used to dock boats, perfect for the coiling of the ropes to stack upon each over and mummify Gal in another heavy monstrous cocoon he had enough to completely wrap the spool all the way from head to toes 3 times!
NNNMMFFFF!!!
The Mummifier reaches into his fat bag of tricks and pulls out the pallet wrap tube! Stretching it out nice and clear right in front of Gal's face so he could see her eyes go as wide as possible through the translucent material! Pure shock and terror in Gal's face, she thought this was the end he would encase her head and suffocate her and that be her it, Only he would begin wrapping her ropes and covering her in a new shining pallet wrap cocoon, lots of crackling and squeaking from this stuff she tried wriggling and thrusting from side to side looking like a bowling pin at this point, soon all his pallet wrap was gone from the roll to Gal's body making it her 3rd mummification and the cocoon at 10 inchs thick!
GGRRMNNMPPPGGGHHFF!!
Some pretty loud energetic furious grunting from Gal, She was the best Gag talker he captured so far! If only he had a camera take fully capture this wonderful scene in front of him! Well he couldn't get distracted he needed to finish this and get to robbing the joint, but his favorite bit of the mummifying jig was next, the heavy super thick overly puffy mummy sleeping bag! Perfect for long cold winter nights in the mountains or in this case, encasing Gadot within to keep her bundled up tight, so now Gal would be shuffled and scrunched up into the mummy bag like a stuffed turkey, adding about 8 inches of thickness to the cocoon and making her really really hot! But that thickness wouldn't last too long because all the down fluff in the bag could be compressed down with layers and layers of duct tape! Loud rips and rrrrmmppffsss filled the air as Gal looked on so wide eyed so shocked to be so helpless, she was cocooned with black and grey duct tape covering every patch of sleeping bag with no bulging from the puffiness, if she was found she would look like an oval shaped 13 inch thick column cocoon!
"Will my job is done here I can't wait to ransack your place while you scream and bitch and roll around like a fat worm on the ground tring to fight out, it's impossible your trapped here all night long!!
"FFFPPMMHH HHHPPMMM MMPPPPPFFF!!!
"I WILL ESCAPE!"
But all she can do is watch the Mummifier taunt her and walk away, eyebrows raised and with raging wobbling thrusts of might, Gal struggled hard and loudly bending, sitting up and scrunching the cocoon but not a single pop of air escaped the monstrosity! She was truly and utterly MASSIVELY Mummified at the mercy of the next person to arrive Would they be kind and try cutting her loose or would she end up in more terrible Perils?!
