Hey Here is Aladdin for you! I hope you enjoy
Aladdin - Three more Wishes
Aladdin pulled the dark cloak around his face, hiding it from the people on the street.
He almost missed the days when he roamed these streets, a nobody. Now he was prince of Agrabah. He was known, he was famous, and he had to hide his face as he sneaked out of the city.
He pulled back the cloak as he crossed the dunes, leaving the city behind him.
He was sure he would find it. Aladdin had spent the best part of a week scouring the desert for the Cave of Wonders. He was after Jafar’s lamp. Another Genie! Another three wishes.
He played his wishes back in his mind when he stumbled over something. He looked down and brushed away the sand. The two-piece scarab! He had found it.
He placed the two pieces together, and within seconds, he was faced with the same terrifying sand lion he saw a few weeks ago. He walked in, still being a diamond in the rough, and the guardian let him pass.
Aladdin headed straight to where he knew the lamp would be.
“I knew it!” He went up the spire and grabbed the onyx lamp.
He rubbed it.
Red smoke billowed, and Jafar’s genie appeared!
“How may I serve you, Master? What, you!”
“Yes, me. Jafar, don’t you have something for me?”
“Yes, Master. Three wishes!”
Aladdin smiled; he had been waiting for this opportunity. Ever since he was shackled by Jafar’s henchmen, he had felt something nagging in his mind. He liked being restrained like that.
Sure, he almost died, but up until he passed out, he was so conflicted between enjoying the peril and being scared.
That’s why he was here now. To explore that feeling. He wanted to know what it was that excited him.
“Three wishes,” he whispered to himself. In his mind, he went through them.
“Jafar, I wish to be bound in a way that I could never escape!”
Jafar’s eyes widened. “Your wish is my command.” He pointed his finger at Aladdin.
Aladdin felt ropes, seemingly out of nowhere, pull his wrists behind his back. The ropes looped around and around, pulling tight. There were no knots, just a loop of ropes wound around his wrists and cinched in between.
Aladdin felt the feeling again. There was a small flutter in his stomach and something like an itch in his crotch.
He liked this; the excitement caused his dick to start growing.
He felt his clothes vanishing from his body. “The clothes will influence the ropes and make it easier to escape, Master. That’s why they’re being removed,” explained Jafar against his will.
After Aladdin felt the musty air against his completely naked body, he felt more ropes encircling his body, simultaneously pulling his elbows together behind his back and encircling his ankles, knees, and thighs.
This is when he lost balance and started toppling over. He closed his eyes, bracing himself, but he fell onto a luxuriously soft red satin pillow, fabricated by Jafar’s pointing finger.
Aladdin felt the ropes circling his limbs tighten, and he felt his cock throbbing.
More ropes slithered around his chest and cinched below his armpits, locking his upper arms to his torso. He still couldn’t see any knots.
He closed his eyes and let out a deep, satisfied moan.
“Is this inescapable?” Aladdin asked as he started twisting his slender muscles under the heaps of rope.
He pulled at his wrists, feeling the ropes actually pull back.
This was exhilarating. Aladdin felt his body react immediately; precum was running down his dick. He knew his body; it would all be over way too fast.
“Jafar, I wish for this feeling to intensify! Make it last!”
Once again, Jafar pointed at Aladdin, granting his wish.
Aladdin felt something on his nipples. He looked down, and there were two tiny red genie hands rubbing and softly pinching his hard nipples. Aladdin loved the sight of his pecs framed by rope.
He smiled his dashing smile as he felt even more rope starting to circle the bottom of his shaft, below his balls. The rope crept in two directions: one went over his taint and slid up between his butt cheeks, the other continued coiling around his cock.
Aladdin was overwhelmed with pleasure as he writhed against the bonds, tugging at the ropes, kicking his legs. Every time he felt a little bit of freedom in the ropes, they pulled tighter.
He was panting by now, moaning aloud with every movement of his captive state. He felt ecstasy run through his body.
He wanted it to reach its pinnacle.
He was so close! He felt it coming…
But on cue, his body lost all its senses, and he couldn’t push himself over the edge. He was like that for a few seconds before all the sensations rushed back, and he was pushed right up to the edge again.
He tensed all his muscles, let out a deep groan; he was so ready to cum…
Then he lost sensation again, his body calming down just enough to go through the process again, and again, and again…
Aladdin’s body started getting tired. Each time he pushed himself to completion, but he never got there.
“What are you doing, Jafar!”
“You wished for the feeling to last, Master. Your wish is my command.”
Aladdin cursed under his breath. He didn’t expect this. But that’s okay; he could just relax now and use his last wish as…
He felt the sensations course through his body, rippling from his toes, which he only now felt were also tied to each other, to his head.
He thrashed in his bonds; they pulled tighter.
His excitement was slowly starting to turn into panic, but not yet.
He felt the rope around his dick start vibrating, and the ropes that pulled between his ass cheeks spread them apart as Aladdin felt something invade his ass.
“Aaaaaghhh,” he shouted into the cave, his echoes bouncing off the walls. “What’s that, Jafar!”
“The feeling is intensifying, Master. Your wish is my command!”
Aladdin pulled at his bonds as he felt some sort of orb pushing into his backside.
Then he felt a feeling he could never have wished for. His body experienced pleasure that nobody had ever experienced. He felt the orb touching a specific spot, and his body started shaking.
He bit down on his teeth and groaned.
The sensations ran up and down his spine, enough to have him right on the edge, but he would never be able to breach it.
Aladdin felt his body tremble; the ecstasy was too much, his mind started swimming.
Before he knew what he was saying, the words had left his mouth: “I wish to cum! Please let me cum!”
Aladdin felt hot, sticky fluid spray against his lower abdomen, his abs getting some drops of cum on them.
The release was enough to make Aladdin almost pass out, but he knew he had made a mistake, and as he looked up at Jafar, he feared the slave had become the master.
“Three wishes done, Master! You no longer have control!” The evil grin spread across his face as he pointed his finger.
Aladdin was instantly aware of a large ball that pushed his jaw open. As he wanted to protest, the only sound he could make was muffled gibberish.
The feeling had now turned from pleasure to panic.
Aladdin thrashed in his bonds, but they held tight, growing ever tighter with each pull.
“Master Aladdin, we have 10,000 years in this Cave of Wonders. I wonder what we could get up to…”
