D&D LOVERS PLEASE READ ON
Just a fun idea I am working on as opposed to running a regular D&D with bondage added! [mention]gag1195[/mention] [mention]cj2125[/mention] [mention]Volobond[/mention] [mention]Charmides[/mention]
Most notable differences from D&D. No magic, no combat, since this occurs in our very real realm of normal people and places.
Let’s start with some new concepts, we have suggestions and Instructions.
A suggestion is made willy-nilly, others can follow your suggestion or decide not to follow it purely role play based. Instructions are enforced by going into dice rolls, you have an Instruction DC, which needs to be beaten if your victim doesn’t want to go along with your instruction.
Your instruction DC = Charisma score.
The actual instructions are entirely up to you, however you have a limited amount of Instruction Slots = 10 + CHA modifier, per day, some roles, or tribes might give you more instruction slots.
You can make suggestions as many times as you want and others can go along with it, but if you want to enforce saving throws you need to use one of your Instruction Slots.
Examples:
1.
Dave (Dom Jock Rigger): “Get on your knees Jeff!â€
Jeff (Switch GND Gear): “Yes sir.â€
Jeff does what Dave suggests, Dave does not need to use an instruction slot.
2.
Greg (Dom Jock Body Worshiper): “Get on your knees Tom!â€
Tom (Dom Daddy Rigger): “No way buddy, I am here to tie you up.â€
Being the initiator Greg now has the opportunity to use an instruction slot, he does, his DC is 17 equal to his Charisma score. Tom needs to make a charisma saving throw, but Greg has smelly feet as a jock and his body worship kink imposes disadvantage on Tom’s saving throws.
Tom rolls a 17 and a 6. He has to use the 6, and doesn’t have a choice but to get on his knees.
3.
Steve (Sub Jock S/M): “Get on your knees Louis!â€
Louis (Switch Skater S/M): “No way buddy, I am here to tie you up.â€
As a sub Steve doesn’t have access to instruction slots, if Louis wants he can use an instruction slot, he doesn’t and opts for an intimidation showdown and rolls a 7. Not that good, this isn’t a consensual scene so Louis does not have advantage against Steve, so he decides to use his tricks and adds a 2d6 to his role, rolling 6 he now has 13.
Steve does his intimidation contest and rolls a 12.
Steve now has to surrender and let Louis tie him up.
Next let’s talk about Stamina
Unfortunately fun can’t go on forever, everyone has stamina = STR + CON scores.
Your stamina steadily decreases with 1 point per hour under normal circumstances that you are awake. In play sessions it decreases with 2 points per hour. If you are under excessive stress from extreme kinks or in pain your stamina points decrease 3 points per hour, if you are acting outside of consent it decreases 4 points per hour.
Stamina recovers fully after a long rest, and you can roll a d10 in a short rest to recover that amount of stamina. If you are proficient in endurance, you roll a d20 in a short rest.
If your stamina reaches 0 you will fall unconscious. This requires emergency response, either first aid or to the hospital.
Relationships are possible, however you need to spend at least 50 stamina points together before you can enter into a consensual relationship.
That brings us to Consent.
When two characters meet they need to agree on consent alternatively one of them acts out of non-consent.
The initiator of the non-consensual act must immediately do an Athletics, Sleight of hand, Intimidation or Persuasion contest.
If you win the contest you enter into a play session with all of your advantages. However if you lose the contest you lose all your advantages, but you have the choice to still enter into a play session. You can continue trying to overpower or coerce your opponent using your skills, but they will have access to their advantages.
A Play session is loosely your equivalent of combat in D&D, when you enter into a play session all present roll initiative. Initiative is a d20 + Cha Mod.
Highest initiative goes first and your imagination gets to take over.
Anything is possible, but your characters will have some Limits. The limits are more for role playing than game mechanics, take note of your limit thresholds and role play accordingly.
Your characters Pain limit indicates how much pain you can take. It is equal to CON mod + STR mod, and is a max score of 10.
Your character also has a Senses threshold, this indicates how much foul smell, bad taste or visual gore you can take. It is equal to 5 + CON mod, and is a max score of 10.
Your character has a ticklish factor, this indicates how much you can withstand tickling. It is equal to a third of your CON score, and is a max score of 10.
Staying on the topic of tickling. Ticklish factor influences your stamina depletion. If your ticklish factor is 1-3 you can’t stand tickling and your stamina decreases 2 points per 10 minutes of tickling. If your ticklish factor is 4-6 you lose 1 stamina point per 10 minutes. From 7-8 you lose 1 point for 30 min tickling. On 9-10 you lose an extra 1 point per hour.
*Stamina lost to tickling does not contribute to bondage or relationship experience.
Bondage is the central theme, so there should be game mechanics controlling the bondage and escape of said bondage.
Restraining someone requires equal parts of strength, wisdom and intelligence.
Experience is the key word and in this game it is equal to your level. You gain experience by practicing bondage or studying it. You choose your starting experience, discuss with Rope Master to make sure it fits with your character. Beginner (1), Intermediate (2) or Expert (3).
For levels 1-4 you need to spend 20 Stamina points in play sessions or 8 stamina points studying bondage out of play sessions to gain 1 point of experience. For levels 5-8 you need to spend 25 stamina points in play or 10 stamina points studying. For levels 8+ you need to spend 35 stamina points in play or 15 stamina points studying. Experience max level is unlimited however character levels end at 10.
When restraining someone you also choose which material to use, and materials all have a bondage rating.
Rope (hemp, clothing line, jumping rope) – 2
Tape (duct, bondage, kinesiology) - 4
Clothes (scarfs, ties, socks, belts) - 2
Iron (cuffs, chains, stocks) - 8
Specialised (bondage sack, straightjacket, leather cuffs, Velcro) – 6
Add any gag and/or blindfold and increase the rating by 1 for each.
How well you restrain someone is calculated: Level + Knots (proficiency required) + Material Modifier + Ability. Where you can chose one ability depending of the situation (Strength for a struggling captive, Intelligence for an elaborate bondage, Dexterity for something quick, Wisdom for a willing captive, etc.). This is your Restraint DC.
*Rope Master can add/subtract to restraint DC depending on scene.
*If you are proficient in knots you receive 1d4 extra to your restraint DC.
Now, if you are tied up and need/want to escape your bondage, you would need to beat the Restraint DC. Escaping is a d8 + DEX Mod, if you are proficient in escapology it’s 2d4 + Dex Mod. As you roll to escape, the DC goes down until it reaches 0.
Example: The DC is 25. Prisoner rolls a 6 + 2 first, so the DC would lower to 17, next he rolls a 3+2, so it lowers to 12. During that time, the captor can roll a perception roll to see if he is escaping while the prisoner rolls for stealth or deception, if the captor catches him escaping, he can chose to retighten his bindings, sending them back to 25, or change them, creating a new DC.
All of that taken into account let’s look at the ability scores and skills. Ability scores work exactly like D&D, with some minor changes to skills.
Strength
Athletics – how strong you are
Dexterity
Escapology – how good you are at escaping bonds
Acrobatics – how agile you are
Sleight of hand – how quick you are
Stealth – how quiet you are
Intelligence
History – how much you know about history
Culture – how much you know about culture
Investigation – how well you observe your surroundings
First Aid – how well you know the human body
Knots - how well you can restrain someone
Constitution
Endurance– how much stamina you have
Wisdom
Perception – how well you sense what’s going on around you
Insight – how well you can tell what people’s intentions are
Charisma
Intimidation – how well you can influence others using force
Persuasion – how well you can influence others using tact
Deception – how well you can lie
Performance – how well you can interpret other characteristics that aren’t yours
1. First you pick your Body type and note the necessary modifications to your Ability Scores, to apply later.
Twink: +4 DEX
Twunk: +2 DEX; +2 STR
Hunk: +4 STR
Bull: +2 STR; +2 CON
Otter: +2 CON; +2 DEX
Bear: +4 CON
Average: +2CON; +1 STR; +1DEX
Connected to your body type is your scent. Your scent strength is 5 + CON mod. It is a score out of ten. Your scent can be smelled from 1m. If you are proficient in athletics the smell range increases to 1.5m.
2. Second you choose the role you like to take in bondage sessions. This will give you specific advantages or disadvantages for use with instructions.
Master
You have authority, when you speak people listen. You gain access to instruction slots. Your instruction DC gets a buff of 4. If you are in a relationship with a slave who answers only to you, you gain unlimited instructions toward them.
Dom
You have a natural air of control around you. You gain advantage in Persuasion or Intimidation. If you have a relationship with a sub answering only to you, they fail any charisma saves against you except on a natural 20. You gain access to instruction slots.
Service Top
You live to please your sub. A Sub, Slave or Power Bottom gains a number of instruction slots to use on you equal to their CHA modifier. You will probably be following their suggestions but the instructions are just in case. You gain access to instruction slots.
Switch
You do not lean to either dominant or submissive sides, you can pick an extra charisma skill to be proficient in. You have much more flexibility in your kink. You gain access to instruction slots.
Power Bottom
Although you follow, you are definitely one to call the shots. When you want you can invoke advantage on instruction saving throws (do this before any rolls). You gain access to instructions.
Sub
You submit easily to others in consensual circumstances, any Charisma rolls made against you in consent have advantage. You have a safeword, if you invoke your safeword any Master, Dom or switch near you will stop what they are doing. The only exception is if you are in a relationship your partner might override your safeword consensually. You do not have access to instruction slots.
Slave
You submit at a whim, especially to a Master. You have disadvantage on instruction saving throws. You have a safeword, if you invoke your safeword any Master, Dom or switch near you will reconsider what they are doing. The only exception is if you are in a relationship, your partner can override your safeword. You do not have access to instruction slots.
Object*
All rolls made against you have advantage, and any rolls you make have disadvantage. Masters and Doms automatically succeed and have unlimited Instruction Slots toward you. You do not have a safeword. You do not have access to instruction slots. (*This might seem tempting but not a lot of Role playing possibility from your side.)
3. Third you choose your tribe. Your Tribe grants you features per level, you can choose which feature you want added with every level. You may multi-tribe after your original tribe reaches level 3. Levels are assigned by RM (Rope Master).
Skater
Skill Proficiencies: Acrobatics, Performance, and one skill of your choice
Levelling Traits:
I'll Try Anything Once- Whenever you use a skill that you are not proficient in, you may add 2d4 to the roll. You may use this ability once per day. You can select this trait multiple times. Each time you select it, you may use it one additional time per day.
Defy Gravity- Time spent boarding has given you a new understanding of physics; you have advantage on Acrobatics and Performance checks.
Skinnybones- Time spent boarding and falling on mostly concrete increases your Dexterity and Constitution scores by 1 each.
Adrenaline Junkie- At the start of each day, roll 2d6. You get these as temporary Stamina points, which are used up first before your regular stamina points are consumed, allowing you to endure a lot more pain and stress than regular dudes.
Skill Training- you are proficient in one skill of your choice.
Jock
Skill Proficiencies: Athletics, Endurance, and one other skill of your choice.
Levelling Traits:
Gymspiration: By spending at least 1 hour working out per day, you gain a single "gymspiration" point, which gives you advantage on a single d20 roll involving your strength, dexterity or constitution modifiers. You may select this trait up to three times. Each time you select it, you gain an additional gymspiration point, up to a maximum of 3. Your required workout time does not increase if you take this trait multiple times.
Bodybuilder: Your strength score increases by 2.
Hot Bod: Although culturally, what is considered attractive changes era to era, but a finely toned body never goes out of style. Whenever you meet someone who is attracted to you, and you're wearing clothing that shows your form off (tight-fitting clothes, speedos, tank tops, scandalously small towels, etc.) you may substitute your Strength modifier, instead of your Charisma modifier, on all Deception, Persuasion, Intimidation and Performance checks. If you have the gymspiration trait, you may also use your gymspiration points on the four skills listed above.
Break a Sweat: Your scent radius goes out to 10 feet. If you spend 10 stamina points and spend 30 minutes intensely working out, you cause yourself to sweat, increasing your scent radius out to 20 feet. If you encounter anyone with the body worship fetish, you have triple advantage (roll three d20's and used the highest of the three) on charisma rolls with them. One drawback, though- mundane, everyday people find your odor off-putting. You have disadvantage on all charisma rolls with "normies," due to your stank.
GND
Skill Proficiencies: Choose any three skills, one which must be Charisma-based.
Levelling Traits:
Neighborly: Increase your Charisma score by 2.
Plausible Deniability: Your charm, reputation, and social standing in "polite society" are beyond reproach. Any rumours of you committing acts of sexual debauchery are disbelieved instantly. A number of times per day equal to your Charisma modifier, whenever you encounter anyone who speaks out about your "proclivities of ill-repute" you may invoke plausible deniability on them. For the next 24 hours, no one believes them about this topic, and any time the speaker mentions you, they're met with scorn and threats and very likely kicked out of wherever place they currently are. This trait does not work if there is iron-clad evidence against you, or you are caught red-handed by multiple people.
Alarmingly Charming: Your friendly demeanor can get people to open up more, or you're adept at picking up on social cues. By spending 1 hour or more in conversation with someone, you can learn their Role, Tribe or Fetish.
Chamber of Secrets: You have a secret room all to yourself. This "room" can be anything from a hidden study, a basement sex dungeon, a studio apartment in a quiet part of town, or even a remote cabin in the woods. Work with the Rope Master to determine the details. No one, other than yourself, and whomever you invite (or abduct!) into this room, can ever find the place. Even cops, detectives, your nosy neighbor lady, or a couple of teenagers in a van with a dog will either overlook or miss the place entirely.
Skill Training: You gain proficiency with one skill of your choice.
Daddy
Skill Proficiencies: Insight, Perception, History and Culture
Levelling Traits:
Age Requirement: You must be age 35 or older to join this tribe.
Like the Back of My Hand: You know where to get the best of the best in town. 5-star restaurants, best bars, best places to shop, where to avoid so you don't get mugged, and who to talk to if you need a favor or a service, no questions asked. In addition, you know the backroads and shortcuts, and can reach a destination in half the normal time.
Age Before Beauty: You've been around the block a few times and seen some stuff. Increase your Intelligence, Wisdom and Charisma scores by 1 each. However, you're also getting too old for this shit, so decrease your Strength, Dexterity and Constitution by 1 each. You may select this trait multiple times. The bonuses and penalties stack. Note that you may not select this trait if it would reduce your Strength, Dexterity or Constitution scores to zero. You would effectively die, and that's not fun.
Maturity: You don't fly off the handle like these younger pups, nor to you submit to these half-wit doms stinking up the bars these days. Three times per day, you may choose to ignore an Instruction used against you. This trait does not work on other members of the Daddy tribe, and you still must make a save as normal.
Sugar Daddy: Your investments have paid off, and you always have an abundance of wealth, regardless of your current job status. Where you get the cash, that's between you and the Rope Master. In addition, you have a hot youngish (between 19-25) NPC trophy boy whom you're happy to support in exchange for his company. Three times per week, you can call up your trophy boy for some "company." This works like a normal bondage/sex session but it does not consume additional stamina points. In fact, at the end of your session, you regain 1d10 stamina points. Your trophy boy will also perform other tasks for you, like make deliveries, clean your house, or entertain guests, etc. Work out this arrangement with the Rope Master. It should be noted that your trophy boy is not a slave (though they can become one if the roleplaying story warrants), and will leave if horribly abused. Finding a new boy requires 1d4 months of searching online or browsing bars and coffee shops, etc.
Geek/Nerd
Skill Proficiencies: History, Culture, Investigation
Levelling Traits:
Cause and Effect- All those days spent gaming has reprogrammed your brain. A number of times per day equal to your Intelligence modifier, you may request that Rope Master drop a hint at the potential outcome of a certain action. You must invoke this ability before doing said action.
Big Brained- Increase your Intelligence by 2.
Data Collector- You know things, that's your job. You can find virtually anything on the internet or in a library, given enough time and access. In addition, you know a lot about certain topics. You may substitute your Intelligence modifier on all Charisma-based skill checks.
As I Predicted!- You don't actually have psychic powers, but your uncanny ability to predict outcomes sure makes it seem like you do. At the start of each day, roll 1d20. Record that number on the die. You may substitute that number for any other d20 roll made that day, whether by you, the Rope Master, or other players. You may select this trait up to 3 times. Each time you select this trait, you may roll and record an additional d20 to use later in the day, to a maximum of 3d20.
Skill Training- You gain proficiency with one skill of your choice.
College
Skill Proficiencies: You're proficient in three skills of your choice.
Levelling Traits:
Frat Pack- You can call up 2 of your frat bros to assist you with a task, no questions asked. You may select this trait up to three times. Each time you select it, you can call up 2 additional frat bros, up to 6 total.
Party Animal- Alcohol does not affect you as badly, and you never wake up hung over. Also, while you are drunk, double your proficiency bonus on Persuasion and Performance checks. However, if you roll a Natural 1 on a Persuasion or Performance check, the Rope Master determines that something CRAZY happened at that party, and people talk about it for 1d4 weeks afterward.
Scholarship- You got into uni on a scholarship. If it's an academic scholarship, increase your Intelligence and Wisdom scores by 1 each. If you chose an athletic scholarship, increase your Strength and Dexterity scores by 1 each.
Dorm Life- You spent a long time living around guys and you have seen and smelled...... things. Horrific things. Weird things. Hot things? Either way, Your Senses threshold is 5 + double your Constitution modifier, and unlike mortal men, you may exceed the 10 maximum on it.
Skill Training: You gain proficiency in one skill of your choice.
Cowboy/Country guy
Skills: Athletics, Perception, First Aid
Levelling Traits:
That's How We Do It in Texas: You always seem to have a lasso on hand for emergencies, be they pesky cattle, bar bullies or cute ranch-hands. Your lasso can reach targets up to 15 feet away, allowing you to initiate a bondage session from a distance. Your Lasso grants a +2 material bonus to restrain a guy. You may select this trait up to five times. Each time you select it, your lasso's material bonus increases by 2, to a maximum of 10.
Home on the Range: Increase your Dexterity and Wisdom scores by 1 each.
Quick on the Draw: You have advantage on initiative rolls to initiate a bondage session.
Rustic Charm: Your salt-of-the-earth nature allows you to substitute your Wisdom modifier on Charisma checks.
Bad Boy
Skills: Sleight of Hand, Intimidate, one other skill of your choice
Levelling Traits:
Locksmith: You always have a bobby pin or some other lockpicking device on you. If you're restrained with mechanical devices such as handcuffs or shackles, you gain advantage on the check to get free. Oh and you can open locked doors and treasure chests, should you come across them.
Bar Fighter: You'd been in a few fights with drunks and can handle your own. Or at the very least, you can put a ton of hurt on someone who violates your consent. Your unarmed strikes deal 1d6 + your strength modifier (normally unarmed strikes are 1 + Strength modifier) to a person's stamina points, and anyone who attempts to start a bondage session without your consent takes 1d6 stamina damage per round, trying to tie you up.
Hot Tattoos: Increase your Constitution and Charisma by 1 each. You may take this trait up to five times, its effects stack. The third time you take this trait, the ink on your body is hard to hide, and you have disadvantage on Deception, Persuasion and Perform checks with stuffy, judgemental normies who think its "trashy," as determined by the Rope Master. The fifth time you take this trait, those same people won't even give you the time of day, and your checks automatically fail.
Because this is the "rebel" tribe, they get to break the rules a little, and raise up their attributes a lot higher, potentially, than the other tribes. Although if you get enough tattoos, you're covered in ink, and "normal" society might turn its nose up at you. Not that you really care, fuck the man! You're hot and your subs/doms know it.
Artist
Skill Profiencies: Perception, sleight of hand, performance
Leveling Traits:
Starving artist: You know what is to suffer for for your art and you’ll never sellout! You’ve gone long periods of time surviving on ramen so you gain profiency in endurance and persuasion.
Shibari Practitioner: The old art of Japanese bondage. When using rope, it gets +2 material rating. You can choose it up to 5 times
Performer: Choose one: Increase your Dexterity by 2, or your Charisma by 2
Bohemian: Grab your glass of absinthe and toast to truth, beauty, freedom and love! Gain profiency in Culture. Through your connections to other artists and members of more "avant garde" circles, you can call in small favors from this group and get in contact with other expression venues. You can get “inspired†once a day, which lets you roll your dice again and chose whichever result you want
Prep Guy
Skill Profiencies: Culture, Persuasion and Deception
Special effect: Prep guys get -2 Sense Threshold
Leveling Traits:
Trust Fund Baby: With more than enough money to spend, you can afford to throw money at your problems, be it buy expensive toys or hire help for mundane jobs or your little secret projects. Of course, making deals with that kind of people can blow up in your face, so if you chose to call for their help, roll an insight check to see if your new employees have ulterior motives. Discuss with the Rope Master what happens if you fail
Ivy League for Everyone: Increase your Intelligence by 2 and your and Charisma by 2
"Wait, I Think I Bought That": While money can't buy you happiness, it can buy you a lot of toys to make up for it. Sometimes you even have the right tool for the job. While in a dwelling you own (check with your Rope Master) roll 1d20. If the result is lower than your Charisma score, you own the item in question. Very expensive things, like cars, computers and heavy-duty sex dungeon equipment, might be rolled against half your Charisma score, rounded down. The Rope Master is free to say whether or not it is possible to own the item, and this does not let you buy things that are illegal
Personal Trainer: You gain proficiency in the Athletics and Endurance skills. Pick one of these skills. Your proficiency bonus is doubled with that particular skill.
Take my money: You buy proficiency with one skill of your choice
**Note: You only get the ability score increase when you choose it at a level increment, it could be level 1 or at a later level.
**(just for fun I added a poll for which tribe you are most likely to play)**
4. Lastly choose your kink. Your kink will give you some added specialty bonuses.
Bondage (prerequisite Dom, Master or switch) – You are an expert at ropes, knots, using duct tape, chains, and even zip ties. If you bind someone, they have disadvantage on trying to escape. If they have advantage on escape throws they lose their advantage but don’t have disadvantage.
Equipment: You have a duffel bag full of roping equipment! Discuss with the Rope Master and set up a list of what you have.
Gear – When wearing your gear you gain bonus to your role, if your role is Dom, Master or Power Bottom you gain +4 temporary Instruction Points. If your role is sub, slave, service top or object you gain +4 temporary stamina. As a switch you can switch between the two as required.
Equipment: You gain a full set of the gear of your choice: Leather, Spandex, Rubber, Pup play or neoprene. Discuss with the Rope Master and set up a list of what you have.
Body Worship – As a Dom, Master or Power Bottom your odors and tastes place a trance on others, if they can smell or taste you they have disadvantage on all rolls. As a sub, slave or service top your senses limit uses double your CON modifier (if you already use double, you use triple). As a switch you can switch between the two as required.
Equipment: none
S/M – You love pain. Either receiving it as a sub, slave or switch, or dishing it out as a Dom, Master or switch. As a Dom, Master or Power Bottom you can enact extreme kinks without taking non-consensual limitations, take note this will deplete your sub or slaves stamina very quickly. As a sub, slave or service top your stamina only decreases 2 points per hour during extreme kinks even outside of consent. As a switch you can switch between the two as required.
Extreme Kinks: Electric, Piss/scat, Choking, Fisting and Flogging.
Equipment: You have all equipment needed for your particular extreme kink. Discuss with the Rope Master and set up a list of what you have.
Roleplay - You just like to live out your more elaborate fantasies, it's not only sex, but the story behind it! Perhaps you want to pretend you're a jock? Or maybe a soldier captured by the enemy? Or you want to "kidnap" your sub and hold him for ransom? Either way, during a play session you can roleplay as another tribe, you may switch skills only if you have a "uniform" of the tribe in question, and you can make this switch once per 24 hours. If your role is Master, Dom or Switch, Subs resisting uniformed-up you have disadvantage on charisma checks against your Instructions. If you're a Sub, Slave or Switch, while in character, your stamina decreases -1 point per hour
Equipment: Props, costumes and uniforms. Discuss with the Rope Master and set up a list of what you have.
That’s it! Now roll your 4d6 and drop the lowest to find your starting ability scores, add the extra points, determine your modifiers, and have FUN!!
