Arkadia (F) (CHAPTER 2 POSTED 1/22/26)
TamatoaShiny123
Post by TamatoaShiny123 »
CHAPTER 1: CARLY (M/F)
The Portal website loaded you straight into the video feed.
The transparent glass cube sat dead center on a small black stage under clean white light. Its edges caught glare like razor lines. A low stool was bolted to the floor inside. Carly Winters sat on it with her back straight and her chin level, as if posture counted as part of the solution.
A calm overlay sat at the top of the screen. Nothing in the interface tried to hype you up.
ARKADIA NETWORK PORTAL
LIVE:
CARLY_WINTERS // “THE SILENT EQUATION”
REWIND: LOCKED (LIVE BROADCAST)
STUDY LAYER: RESTRICTED FOR YOUR TIER
RESULT: PENDING
Carly wore a metal double-wrap lock vest that pinned her arms to her sides. The design looked mechanically engineered instead of theatrical. It compressed her shoulders without forcing them into strain. Metal finger cages sleeved each digit and locked them into place. They weren’t there to hurt her. They were there to remove the option of fine-motor improvisation. Her gag was a silver metal panel harness that cupped her jaw and locked her mouth closed while leaving her chin free so that it could become an input device.
A mechanical keypad rested on a pedestal in front of the stool at mouth height. The surface was divided into pressure panels instead of buttons. A small timer above it counted down from 10:00 in rigid, unblinking digits.
The timer was the trial. The fog warning was the same countdown, surfaced as an explicit consequence when Arkadia wanted to remind you what running out of time did to the room.
A handler, clad in anonymous black, stepped into frame long enough to check the gag placement and confirm the vest was secured correctly. He didn’t acknowledge Carly or the fact that he was on camera. He did his work and stepped out of frame.
Carly inhaled through her nose and held it for one beat. Then she exhaled slowly. A mic near her jaw captured her breath for the feed. A digital placard flashed inside the cube long enough for the audience to read it.
THE SILENT EQUATION
ARCHITECT SIGN-OFF:
E. CARTER
CONDITION: NO HANDS. NO VOICE.
FOG: AT 0:00.
GOAL: SOLVE FIVE EQUATIONS.
ERROR: FOG TIMER LOSES 0:30 PER MISTAKE.
FAILURE: SCREEN BLANKS. SUBJECT REMAINS UNSOLVED.
Carly read it without changing her expression.
The screen inside the cube flickered on. The pressure panels brightened for a moment, signaling that they were active. With that, the first equation appeared. It wasn’t too complicated on paper. Carly did the arithmetic in her head and checked herself. She’d made mistakes before when she tried to complete the math too fast. Arkadia recorded mistakes like the weather. It didn’t shame the performers. It wrote them down and showed them to the people who helped fund the organization and paid to study the trials.
Carly leaned forward and pressed her chin into the first panel. A buzz answered her. It wasn’t loud, but it was still aggressive. It sounded like a warning disguised as feedback.
She pressed again. The buzz grew even sharper. She pressed again, matching her inputs to the solution she’d mapped in her head. The buzz rose in intensity with each press. The sound wasn’t meant to hurt her, but it was meant to make her hurry. She slowed down anyway.
Arkadia loved systems that provoked panic. It made for great data.
The keypad timer ticked down. The audience could see it in the corner like a taunt. The stream stayed wide. It didn’t zoom in or cut away. It just watched Carly complete the sequence with one final chin press. The keypad chirped, and the equation screen updated: CORRECT.
Carly exhaled in a controlled thread of breath through her nose. She didn’t celebrate or glance toward the camera. She kept her eyes on the screen.
The second equation appeared immediately. This one included a trap meant to punish assumption. Carly caught it because she distrusted convenience. During her time in competitive puzzle box-solving races, she’d seen too many people outside Arkadia get praised for ‘confidence’ when they were only boldly guessing.
Carly pressed her chin to the panels again. The buzz climbed again. Halfway through the input, the buzz spiked into an uglier tone. It sounded like audible irritation that made your body want to jerk away from the source. Carly held steady. She finished the sequence.
CORRECT.
Four minutes had passed. The third equation appeared, and then the fourth. Each one asked her the same question in a different language: Could you keep your mind intact while you couldn’t use your hands or your voice, and also while sound and time attacked?
At the bottom of the screen, the Portal surfaced the fog warning as a second overlay: FOG: 3:00. It was not a new clock. It was the same ten minutes, spelled out in a way your body could not ignore.
Fog meant distraction more than blindness. It meant the lights would bloom, and the cube would fill with haze. It wasn’t harmful, but the metaphor spoke loudly to Carly.
The fifth and final equation appeared at the seven-minute mark. It looked simple until she realized it wasn’t. It included a negative sign in a place where the eye wanted to skip. It also carried an order-of-operations twist that punished anyone who relied on instinct.
Carly couldn’t write out the equation, even if the cube had given her paper and a pen. The finger cages denied her that luxury. She couldn’t mouth the numbers. The gag denied her that habit. She kept the equation in her head and ran it twice. Her breath tightened, just slightly. The mic caught it. You heard the restraint in her breathing more clearly than you heard anything else in the room.
Carly pressed her chin into the panels. The buzz escalated fast this time. It didn’t like her hesitation. It wanted her to commit before she was sure.
Carly paused with her chin hovering a hair above the next panel. She felt the impulse to rush. She remembered it as a physical itch under the skin. She remembered the specific kind of mistake that came from fear of wasted time, even when time was still available.
She thought, briefly, about a phrase Arkadia repeated in its training documents, the kind of line that showed up on a tablet right before a trial began: A silent trial revealed the truth.
Carly never cared that it sounded poetic. She cared what it did. Silence removed bargaining and excuses, forcing you to either solve or fail without selling personality to the crowd.
Carly checked her result one last time, then she pressed the final panel. The buzzer screamed for half a second and then died.
CORRECT.
The countdown froze with a little over two minutes left. The fog warning vanished with it.
The equation screen cleared. The cube stayed transparent and clean. The moment still shifted anyway. The room recognized completion before the audience did.
A mechanical tone sounded. The lock vest released in stages, accompanied by the sound of internal latches letting go. The finger cages unlocked with a series of small clicks.
Carly stayed still through the release. She waited until the final latch opened before she rolled her shoulders. The Portal overlaid the result in one clean line.
RESULT: PASS
The camera stayed on her as the fog warning disappeared from the overlay. Then, the stream ended with a soft fade and a final caption that appeared for two seconds.
VAULT UPLOAD: PENDING
STUDY LAYER: AVAILABLE AFTER INTERNAL REVIEW
After the feed ended, a handler returned to her line of sight. He kept his posture neutral. “You good?” he asked.
Carly nodded once.
He glanced at the monitor, not at her face. He didn’t congratulate her. Arkadia avoided praise because it made performers chase approval instead of mastery. “Any pain?” he asked.
“No,” Carly said. “The vest wasn’t too uncomfortable.”
He nodded once. “Good.” He stepped closer to the cube and reached for a latch. It was released with a small click. The transparent door swung open. Carly stepped out carefully.
Carly looked back at the glass wall and saw her own faint reflection: her dark gray one-piece performance bodysuit with neon green accents. Her dark brown hair was tied into a pair of identical pigtails on the sides of her head. Her usual glasses were swapped for prescription goggles so nothing could slide or snag during the trial.
Carly didn’t smile at her reflection over a job well done. She didn’t hate what looked back at her, though. She accepted what happened as another record.
Once the internal review cleared, the feed would become a product. People with money would replay her chin presses and call them tells. Analysts would chart her breathing and use it to shape marketing data for whatever products they were selling.
Carly let them do it. They could keep the story they bought. She kept the result: five equations solved with no incorrect guesses. She gave them the solutions, not a performance.
TamatoaShiny123
CHAPTER 2: CALI (F/F)
Arkadia’s Portal didn’t feel like a website when it opened. It felt like a controlled room that just happened to have a live chat column. You signed into your Observer-tier account, and the interface let you in without ceremony. The livestream loaded whether you were ready to watch or not.
A tide-basin filled most of the frame. Water sat in a shallow, circular concrete trough, lit from above so it looked like dark glass. The stage around it remained matte and dry. Timing came from a low pulse that matched the cycle, steady and indifferent. A translucent sidebar slid in on the right.
LIVE NOW:
CALI SHORE // “UNDERTOW”
REWIND: LOCKED (LIVE)
VIEWER LAYER: OBSERVER
ANGLES: 1 OF 3 AVAILABLE
You hovered over the angle selector. The options blinked into view: wide, low, overhead. You stayed on wide. Beneath the header, the tier ladder sat formatted like a menu:
Silent Witness: $19.99/mo.
Observer: $49.99/mo.
Rhythm Voter: $99.99/mo.
Jury: $199.99/mo.
Curator: $499.99/mo.
Patron: Invitation-only
Being an observer afforded you Study Layer notes post-trial, helping you better understand what you witnessed. But higher tiers got to vote online regarding aspects of certain trials. You heard that Patrons were invited to witness live trials. A note appeared below it, plain as policy.
You will not message performers. You will not request restraints. You will not interrupt the record.
Chat scrolled under the note, already alive.
[SILENT WITNESS | driftwoodandglass]: First time catching Cali live.
[OBSERVER | KnotIndex]: You’re in for a treat. She never wastes a breath.
You could type in chat as an Observer, but you didn’t. You watched as Cali Shore walked in barefoot. She wore an aqua-blue performance wetsuit that clung to her arms and ribs like a second skin, darker at the seams, lighter at the joints. Her blonde hair already looked damp and salty, taped back into a low knot that would not slip or fling loose in the water. She didn’t acknowledge the camera. She watched the waterline.
A handler moved with her, gloved and anonymous. He guided her to the edge of the basin. Cali stepped down into the trough, and the water rose around her ankles. She paused for one breath, then another, letting the temperature register without flinching. The Portal added text at the bottom of the feed.
TIMER: 22:00
TIDE PHASES: 4 x 5:30
[SILENT WITNESS | driftwoodandglass]: Is she always barefoot?
[OBSERVER | SaltMath]: Usually. Bare feet read the water better.
You switched to the low angle. It sat near the basin level. From down there, the surface looked heavier. A second strip of text appeared, clinical and straightforward.
PHASES: LOW // RISING // HIGH // FALLING
HOLD-RULE: NO ACTIVE ESCAPE UNTIL FALLING
PENALTY: EARLY ATTEMPT = RESEAL + SHORTENED ESCAPE WINDOW (-01:00)
The hold-rule mattered here. There’d be no tugging hardware, probing the release plates, or attempting to reposition the anchor line. If Cali tried early, the handler would walk back in, reset every knot to its primary tightness, and cut time off the only phase where escape was permitted.
The handler began without hurry. He didn’t bring regular rope. The coils looked chosen for water exposure, the kind you’d use to tie your boat to a dock post. First came the chest harness. He wrapped a broad band across Cali’s upper torso just under the armpits, then cinched a diagonal band into an X that anchored her shoulders without forcing them back. It’d limit the tiny posture tricks used to create slack later. Then he attached a docking line to the harness. The rope ran from her chest to a low anchor ring on the basin wall. It gave Cali a controlled range of motion from the anchor rig. He tugged once and watched her chest rise and fall.
Then he brought Cali’s arms behind her back in a compact box-tie configuration designed to remove leverage. Her wrists sat close behind her lower back, not forced upward. The wrap locked her elbow angle and limited rotation so that she couldn’t twist her hands. Cali stayed still as he worked. She didn’t help, but she didn’t fight him. Arkadia would’ve measured both had she done either.
He moved to her legs next. First, he looped a rope band around her thighs just above the knees, then tethered that band to a low point on the harness, keeping her stance narrow. Another line sat at calf level for the same reason. It was meant to stop her from bracing wide, digging her feet into the ground, and overpowering the basin with posture.
Then came the ankle system. He secured a cuff around each ankle. Each looked simple until you noticed the small, reinforced eyelet hole built into the outside edge. That was where the line attached. He fed a rope line through the left cuff’s eyelet and ran it back to a low anchor ring on the left wall. Then he did the same on the right, tying off to a matching ring on the opposite side. Nothing tied her ankles together; the wall held her instead.
From the low angle, you could see the lines vanish toward the edge and pull taut whenever she shifted her weight. From above, the geometry turned obvious: chest to ring, left ankle to ring, right ankle to ring, knees narrowed by the thigh tether, and arms erased by the box-tie. Cali stood centered in the basin, allowed to adjust, but not allowed to walk herself to a release point whenever she wanted.
Then the handler brought the gag into frame: a dense, pale tan sponge with white straps sticking out on either side. He held it at her lips and waited.
Cali opened her mouth. He seated it firmly and stabilized it with two straps: one across her cheeks and around the back of her head, another under her jawline. The gag removed speech capabilities and mouth tricks, leaving breath as the only noise she could make. Cali tested it with a slow exhale through her nose. The waterproof mic clipped inside her wetsuit caught the hiss.
The handler stepped back and raised two fingers in a silent question. Cali nodded once. He left the frame. Phase One began.
LOW.
The waterline stayed shallow. But Cali didn’t get comfortable. She made a slight adjustment immediately: her toes spread, her knees softened, and her shoulders lowered so the harness would not shift as the water began to throw weight at her. She kept her eyes on the surface and watched it for patterns.
You switched to the overhead angle. The rig made even more sense from above: the docking line kept her centered, the leg bands removed stance options, the box-tie erased her arms from the equation, and the harness controlled her ribs and breath.
Low tide stayed boring on purpose. Cali didn’t tug or “check” the restraints like a nervous habit. She used the quiet to map what the rope did as she inhaled and exhaled. At 5:30, a tone sounded. Phase Two began.
RISING.
A circulation jet came alive below the waterline. The basin started to rotate slowly, and the water level climbed. From the low angle, the surface pressed against her shins and slid around them.
Then the first pulse hit. A short, controlled surge slapped the water into her calves. It didn’t knock her down, but it made her body want to react. The rig refused to let her.
Cali resisted the urge to fight the water head-on. She let the rotation turn her a few degrees, then corrected with a tiny shift into the opposite foot. It spread tension across her torso instead of allowing it bite in one place.
A harder pulse hit. Water smacked her shins, climbed into the hollow behind her knees, and then retreated. Cali kept her jaw still behind the sponge and didn’t clamp down on it. She breathed through her nose, slow enough that panic couldn’t latch on.
[SILENT WITNESS | driftwoodandglass]: She still can’t escape, right?
[OBSERVER | KnotIndex]: She won’t try to. Early attempt means reseal and a shorter escape window.
Cali lifted her ribcage slightly on the inhale and lowered it on the exhale. She learned where the docking line gave her a fraction of slack. Each surge taught her something.
At 11:00, the tone sounded again. Phase Three began.
HIGH.
The water rose to knee-to-thigh level, and the circulation strengthened. This was where the basin stopped feeling like a still body of water and more like a whirlpool.
The pulses hit higher and heavier. A surge rolled into her thighs and shoved against her knees. Another surge followed immediately, leaving her no time to reset. Water slapped her hips while a pulse climbed her ribs and smacked the chest harness. The mic caught the sound of water beating the straps.
Cali didn’t flinch. She let the water hit and pass. The urge to escape early showed up the way it always did in water trials. Her body’s survival instincts urged her to do something. Test the rig.
But Cali did the opposite. She chose stillness. She kept her center low and let the rotation carry tension into better alignment of the docking rope, millimeter by millimeter.
Another surge threw a cold splash up toward her chest. For a moment, it threatened her breathing pattern. But Cali kept it. In through the nose, and a long exhale with no rush.
The current nudged her hips off-center. Cali corrected by turning her shoulders a fraction, changing where the docking line landed. She didn’t submit to panic or try to beat the basin’s water. She negotiated with it until the rig sat exactly the way she wanted on her body.
At 16:30, the tone sounded again. Phase Four began.
FALLING.
ACTIVE ESCAPE PERMITTED.
The water began to lower, and the pressure changed. Instead of pushing into her, it started to pull outward, dragging away from the center. The outward draw created slack, but it also created instability.
Arkadia only gave her one window: five and a half minutes. This was the first time Cali moved with visible intent. She used what she had banked. On an exhale, she let the falling current pull her forward a fraction, then she rotated her hips to shift tension down the docking line. She repeated the motion. The anchor ring held a cam-style clasp designed to stay locked under inward pressure and release only when shifted outward at the correct angle.
You switched to overhead again. The geometry changed. She looked less pinned without ever having moved frantically.
Cali timed the next outward pull. She let it take the docking line, then added a controlled body turn. The clasp gave with a small, clean click. The change hit immediately: without the central tether, the rest of the rig lost its shape. The ropes still held her, but they stopped forcing her body into a single, obedient position.
Cali rolled her shoulders and let the box-tie breathe at the elbow wrap. She used the same exhale timing, letting the rope loosen when the water pulled away, then holding still when it pushed. Her wrists slipped in increments, not in dramatic jerks.
The water dropped to mid-calf. With the docking line gone, she finally had enough freedom to shuffle toward the basin wall without the rig snapping her back to center and reach the release point just below the surface line: a small strike plate fixed into the basin wall.
Cali turned her left side toward it first. The left ankle line still held her, drawn taut from the cuff’s eyelet to the anchor ring. She lifted her heel a fraction and pressed the outside of the left cuff to the plate. The cuff had its own release port near the eyelet, a tiny recessed point designed to pop when it met the plate at the correct angle.
The outward pull of the Falling tide helped. The line tugged away from her ankle as she pressed in. A clean click sounded. The rope slipped free of the cuff’s eyelet. The left ankle leash went slack immediately, still tied to the wall but no longer attached to her.
She didn’t celebrate or rush to movement. She adjusted one careful step, keeping her balance as the basin continued to pull outward. Then she turned her right side toward the strike plate. The second cuff still held the second line. Cali repeated the motion. Another click. The right rope slipped free of the cuff’s eyelet. Now both ankles were un-leashed. The thigh and calf bands still kept her stance narrow, and the box-tie still erased her hands, but the wall no longer owned her feet. Cali steadied herself in the falling water and took one careful step away from the strike plate, as if proving she could move without rushing. The Portal stamped the result in one clean line:
RESULT: ESCAPE.
[SILENT WITNESS | driftwoodandglass]: That felt like art.
[OBSERVER | SaltMath]: That’s Cali. She beats water by refusing to rush it.
The feed lingered on Cali as the handler lifted Cali out of the basin and undid the boxtie and chest harness. Once her arms were free and brought to the front, she pulled the sponge gag free, held it for a second, then dropped it back into the water, as if returning a piece of the trial to where it belonged.
Then the stream ended. A post-trial panel unlocked for Observers.
STUDY NOTES: NOW AVAILABLE.
You clicked and read through each one:
*Subject complied with hold-rule until the Falling tide phase.
*Breath cadence remained stable through High phase surges.
*Early phases used for harness seating and breath-timed slack mapping.
*High tide surges used to redistribute pressure and align rope positioning.
*Docking release exploited outward pull during the Falling phase via tension-angle clasp.
*Ankle leashes released independently at wall strike plate via cuff release ports.
*Sponge gag maintained silence and stabilized jaw for breath discipline.
You closed the Portal and sat with Cali’s success. She hadn’t beaten the water. She’d refused to rush it until it had no choice but to cooperate.
Ovi1
Post by Ovi1 »
2 amazing Chapters!
I love the concept and the slow, deliberate escapes!
