Tie up suggestions #2!
Bef
Post by Bef »
Hi all.
Did a post a while back which you were all very receptive to, thank you everyone.
Got another tie up coming up soon. Here to ask for more suggestions like last time! Same stuff that I have from the last post, any suggestions are welcome, my boyfriend will be tying me but I might try it on him if he’s keen.
Well it depends what you want from the tie up. If it is just to relax in the ropes, just have a squirm and struggle. Then either Nice tight hogtie or chairtie.
If you want something a little more then I would tie your hands behind you and lay you face down on the seat of my high stool and tie you there. I would spread your legs a little and tie them to each of the legs at the ankles and above the knees. That would make you very available for fun.
If you were to tie me or your Bf, then maybe a hogtie first followed by a spreadeagle tie to the bed.
DTbound
Post by DTbound »
Perhaps a chair tie? You could even use duct tape instead of ropes! I’ve always liked chair ties that connect the ankle to the wrists or a support beam, suspending them off of the ground for added helplessness.
I recall you mentioned you wanted to try stuffing for your gag, but were a bit nervous about it. If that’s the case, you could try a thin ankle sock or a small sponge to start you off small. Hope you have fun!
wannabetiedup
Post by wannabetiedup »
Why not both at the same time?!
I'd suggest you use your powers of persuasion to firstly bind and gag him. Bring him into the bedroom. It sounds like you need to go easy on him so tie his ankles together with rope, cuff his wrists behind his back and gag him with a couple of strips of duct tape. Set an alarm for 20 minutes and tell him to stay there until the alarm goes off, after which he's allowed to leave the room and come find you.
Whilst he is bound and gagged, you'll set about tying yourself up to a chair. Ankles tied individually to the front legs of the chair with rope or tape, your thighs tied to the seat of the chair and your upper body to the back of the chair. Gag yourself first with the ball gag, and then duct tape. Make sure there are several layers of tape, as in between the layers you will place the key for both of your cuffs. (Alternatively, you can put the key to the cuffs you will use within the layers of his gag, but make sure he doesn't see this as it'll ruin the surprise!)
Once he finds you, he will have to find the keys by removing your tape gag.
I love all things bondage. Always up for a chat
rtbw
Post by rtbw »
Nothing beats a good spread eagle TUG session!
TightsBound
Post by TightsBound »
If it’s not too over the top for you, try a little sensory deprivation/meditation. Tied to a chair, blindfolded gagged, and ear plugs. You can go a step further with a hood over all of it if you want. Bonus points if you’re put in a closet for real alone time.
