(18+) Self-Bondage Ideas, Challenges, and Reports (18+)
- CaptiveDan
As someone who enjoys tying myself up and trying to escape, I wanted to make this thread for people to share their ideas for how self-bondsge enthusiasts and escape artists could tie themselves, and for those who try said suggestions to report back about their attempt.
An example Bondage Challenge:
(Requires rope, locks, and some form of lockable cuffs)
Tie a chest harness with rope, making sure the knot that finishes the harness is on your front. Then tie your ankles with rope cross so your legs make an ‘x’. Run the extra ankle rope (or a new rope) up and loop it around your chest harness. Pull the rope backwards until your legs are bent back in a hogtie position, then reach your arms back and tie off the rope down as close your ankles as possible. Finish by cuffing your hands in handcuffs or wrist cuffs behind your back, making sure to lock the cuffs to your rope harness to prevent you from moving them down far enough to untie the ankle knot.
An example Escape Report
(Replying to the above suggestion)
I tied myself pretty tight and quickly realized this position wouldn't be one I could stay in for too long. That said, it was a very fun and restrictive way to be tied. It took me a while to get free, but I eventually managed to stretch far enough to touch the knot at my ankles. I had to really stretch and struggle for a bit, but I eventually got my ankles untied and was able to stretch out, stand up, and walk over to the cuff keys.
Or
This one stumped me. I kept trying to reach my ankles but my arms couldn't get far enough down since they were hooked so high up on the harness. I struggled on the floor for awhile until eventually my gf had to come and release me.
Stipulations
It should go without saying - be safe. It is best to have someone nearby who will let you out if you can't get free. Alternatively some sort of failsafe - like nearby keys or scissors that you will only use in case of a complete escape failure - make alone play slightly safer, but are still very risky.
Because self bodnage (even done with safety measures) poses inherent risks, this thread is going to be for adults only .
When giving suggestions, give ones that require as little extra help as possible. The goal is for us to be able to challenge each other to escape challenges and share self bondage ideas and share our results.
Or
Stipulations
Bound Down
Not sure if this 100% in the idea. But my favorite way to tie myself up is to run a chain roughly midway across a bed.
I lock on leather cuffs on my wrists and ankles. For the collar, I lock it on with a time lock set to x hours. Then for the base bondage, I tie my ankles spread out at the bottom, and lock my collar to the head of the bed. This way I can't untie my feet until the time lock unlocks.
From there I may try various short scenarios like nipple clamps, electro, or an edging machine, while locking my wrist cuffs to the chain as far out as possible at roughly waist height. I use another time lock for one wrist cuff and then half a handcuff for the second since it is easiest to use one handed.
This may just be a me problem/advantage (depending on your frame of view) with my small hands, but the way I normally escape is that once I've been tied long enough to sweat a little, I can slip my hands out of the leather cuffs.
I have one of those doorframe-mounted pull-up bars on my closet door. Incredible for self-suspension. Can’t recommend one enough, ordered mine off of Amazon for like $30.
As a big fan of stress bondage, I love to use it for a strappado. I’ll dangle a pre-measured loop of rope from the center of the pull-up bar. Strap leather cuffs onto my wrists, then roll my desk chair underneath. Sit/stand on the seat, use a carabiner to connect the cuffs behind my back and the end of the rope, then shimmy my way down to the floor, and kick the chair away. I can reliably get myself into a pretty extremely intense strappado this way.
Escape is as easy as getting free of the cuffs. If they’re not locked, it’s pretty trivial. Which is why I’ll lock them, and tie a looong piece of string to one of the cuffs, with the key tied to the other end. A long enough string and it takes hours. The slightest fuck-up while the key’s dangling in the air as you pull it up towards your hands will annihilate ages of work.
You could leave the bondage at that, but I never do. Where’s the challenge if you’re not at your wit’s end?
Obviously, a good gag and blindfold for starters. Love a used sock/underwear gag, personally. I just have to frogtie my legs, forcing me to stand balanced on my knees. I’ve also figured out the lengths of rope to have my nipples clamped and balls stretched, ruthlessly pulled up/back above me. I’ve more recently gotten a head-hardness muzzle, too, with a D-ring on top to have my head pulled up.
This one’s a little weird, but I also like to wear underwear and have the back of them connected to another rope to the pull-up bar. If I get it just right I’ll just barely be fully suspended, with my body in a brutal backwards arch, and my knees just barely grazing the floor. The wedgie ofc crushes my junk, but I’m enough of a shameless masochist that this basically forces me to eventually climax.
Tl;dr: get a doorframe pull-up bar for suspension bondage and make your entire body SCREAM for mercy.
Gag slut. Pec whore. Relentless glutton for punishment.
- CaptiveDan
Sounds like a fun setup! Bed bondage is great, relaxing but also quite secure.Bound Down wrote: 3 months ago Not sure if this 100% in the idea. But my favorite way to tie myself up is to run a chain roughly midway across a bed.
I am also cursed with the ability to slip out of wrist restraints lol. Does you having your collar locked make it so even when your wrists are free you're still locked down by your neck and ankles until the timer goes off? Or is it game over after you get your wrists free?
- CaptiveDan
Wow that sounds like a super brutal and super hot strappado! The string key thing is a really good idea, I might try something like that.Kishi wrote: 3 months ago I have one of those doorframe-mounted pull-up bars on my closet door. Incredible for self-suspension. Can’t recommend one enough, ordered mine off of Amazon for like $30.
I don't have a pull-up bar, but I've done something. Similar with the hinges of my bedroom door. If the door is open I can tie rope around the hinge and use that as the starting point for the strappado. I usually just tie my ankles together though so I'm standing, but after hearing your method I should definitely start frog-tying my ankles or finding other way to force myself to sit or kneel.
Head harness muzzles are fantastic, having my head forced into a certain position is like, one of the most helpless feelings I can have.
How long do you usually stay in the strappado/wedgie? Do you have any method to keep yourself from reeling all the string in just a few minutes?
Bound Down
CaptiveDan wrote: 2 months ago
Yeah. I'm stuck on the bed until the timer goes off for the collar.
Thank you! I’m always trying to go as brutal as possible. Just make sure you tie one crazy fucking knot to keep that key where it needs to be.CaptiveDan wrote: 2 months ago Wow that sounds like a super brutal and super hot strappado! The string key thing is a really good idea, I might try something like that.
I used to do the door hinge strat all the time too! Still do once in a while. It’s just nice to have the extra real estate for heavier ties.
You should definitely try the frogtie and forced kneel, lol. It really brings the restraint and immobilization to a new level. Personally get a humiliation kick out of it too. Maybe lay down a pillow or folded-up blanket if you’re going to be standing on your knees for too long tho.
I use a 200ft length of clothesline, which takes a couple hours to reel in if I’m fully focused and don’t make any mistakes. Which obviously doesn’t happen. It’ll last til morning if I let the frustration get to me. Not to mention the “distractions”, lol. Might have to try something longer………
- blackbound
For bonus pain, connect two clips to the string and clamp them onto your nipples, forcing you to slowly pull them off as you reel it in.CaptiveDan wrote: 2 months ago Wow that sounds like a super brutal and super hot strappado! The string key thing is a really good idea, I might try something like that.
Oooh that is EVIL! Definitely going to have to try that outblackbound wrote: 2 months ago For bonus pain, connect two clips to the string and clamp them onto your nipples, forcing you to slowly pull them off as you reel it in.
latin-self-bound
Thanks for all the ideas you have posted here!! I've used scissors tied to a long string, but I've never thought about connecting that string to the nipple clamps. That's wicked, evil and nasty! And I'm probably doing it in my next self-bondage sessions.
backwardshood
Used to put my jacket on backwards, put a belt around my waist real tight and then pull my arms into the jacket. Sometimes had a hard time getting at least 1 arm back into the sleeve. Made it more exciting to use the hood of the jacket.
- CaptiveDan
Tested out a new self bondage position I wanted to tell y'all about!
So my couch has little 1-inch "legs" or something on the bottom, kinda like these but smaller:
I wanted to tie myself so I was sitting, essentially spread eagle and exposed so my bf would would have free reign over me while we watched a movie.
I tied a long length of rope to one of the back legs, then pulled it up and over the top of the back of the couch. I tied a bunch of loops along the length of the rope so that I could decide how stretched out I wanted to be. The knots were tied in such a way that they could easily be untied UNLESS something went through the middle (ie a padlock) at which point the knot couldn't be untied until the thing running through it was removed. Then I ran the rope down the other side of the couch and tied the other end to the other back leg.
Kinda like this (sorry for the rotated picture):
Then I stripped, and gathered a bunch of supplies close to me. I tied each of my ankles in a single column rope cuff and tied those ropes off to the two front legs of the couch.
I tied a sock in a knot and put it in my mouth, then used my head harness to gag myself. The head harness had a built in collar
I looped an unlocked padlock to the d ring in the back of the collar.
I put leather wrist cuffs on both my wrists. For my left wrist I mean a padlock through the ring on the cuff but left it unlocked. I locked my dominant right hand in a fist mitt. I stretched my right arm as far as it would go, then used my free left hand to padlock the mitt and cuff to the furthest rope loop I could reach that ran along the top of the couch.
I used my left hand to lock the padlock I'd left on my head harness to a rope loop right behind my neck, then reached my left as far to the left as I could, and (after a few minutes) managed to padlock my left wrist to a the furthest rope loop I could reach.
Here's a (really bad) drawing of the setup.
The position was immediately effective. I was properly stretches and exposed. There was enough room for my bf to sit beside me as we watched our movie. I could adjust and wiggle enough that I was able to stay in the position for the full 2.5 hour run time (though he did remove my gag after about 30 minutes) but also secure enough that I couldn't escape my bf when he decided to have fun with me.
I tried to escape, always looking for a ways to improve. Without the keys (which i'd left on the table in full view but out of reach) I couldn't unlock the wrist restraints or muzzle. I couldn't reach the knots on the legs of the couch so I couldn't move the rope attachment points I'd set. I did find I could give myself a bit more slack by untying nearby rope loops that didn't have a padlock through them, but that was only possible for one loop close to my un-mitted left wrists, so I gained maybe an inch of wiggle room at most.
All in all a very fun and effective bondage position. After a full movie tied up, tickled, edged, and breath-controlled, I was absolutely exhausted and super pumped to try a similar couch tie again.
If you want to try something like this all you need is a couch with some sort of leg or attachment point. I can go into more details about the rope that ran up and over the back if people have questions. I'm sure there's ways to improve/add to this couch bondage position, so let me know if you have ideas.
I still need to try the long string method. It was a super hot suggestion, but I'm honestly a little nervous lol, I need to be brave if I'm gonna try a strappado on a string timer!
► Show Spoiler
► Show Spoiler
► Show Spoiler
- CaptiveDan
Tested Kishi's strappado and key-on-string method of self-bondage. It was a lot of fun!
I wrote about it (and some other bondage positions that night) here:
viewtopic.php?p=213910#p213910
Holy shiiiiit! That’s so cool! I feel so honored, like you gave me the privilege of tying you up with my own hands hahaCaptiveDan wrote: 1 month ago Tested Kishi's strappado and key-on-string method of self-bondage. It was a lot of fun!
How long were you able to stay in the position? Is it something you could see yourself doing again?
- CaptiveDan
I was such a wimp lol, probably only lasted 15-20 mins. I definitely didn't make the sowing string as long as I should have. I'm in awe of your endurance/bravery with such a stress position.Kishi wrote: 1 month ago
How long were you able to stay in the position? Is it something you could see yourself doing again?![]()
Absolutely would try something like it again. I actually recently tied my self up so I was balanced on one foot (did a chicken-wing ankle-to-thigh tie on one leg) with my hands locked above my head to the top hinge. I did the same string thing so I was forced to stand on one foot until I could unlock myself. It was quite fun, but I quickly got uncomfortable/sore on one foot and was very glad I kept the string short.
Nahhh, the fact alone you were up for trying such an intense and restrictive position is super impressive! That standing position sounds really tough too, balancing on one foot for any real length of time is no joke. I gotta say the string release method is my #1 fave at this point, really helps me push my limits.CaptiveDan wrote: 1 month ago I was such a wimp lol, probably only lasted 15-20 mins. I definitely didn't make the sowing string as long as I should have. I'm in awe of your endurance/bravery with such a stress position.
I’ll have to see if I can come up with any more predicaments, lol. Definitely will leave a write-up under this thread if I have the time, give you something really challenging to try out ;P
So I actually have a twofer for you ;P
First, an Escape Report from something pretty recent:
So I can't believe it never occurred to me to connect a pair of nipple clamps to the freedom string like @blackbound suggested a month ago. I just HAD to incorporate this into something really good and intense.
I'm a sucker for a good hogtie, so I used my doorframe-mount pull-up bar to create a pretty severe stress hogtie.
I stripped down to my briefs, locked a pair of cuffs onto my wrists, and cuffed my ankles. I wrapped a blindfold over my forehead, at the ready. I stuffed my mouth with a pair of my bf's boxers I'd expropriated, and put on my muzzle harness gag to seal it in.
I used 2 pairs of clover clamps for my nipples. I wrapped a rubber band around each pair of clamps together, so what I essentially had was 2 double-wide-clamps that each had a loop of chain hanging from the end.
I figured the most straightforward way to do this would be to secure the string to the clamps' chains, and the key to one of the clamps. So essentially what I have is the cuff<->string<->chain<->clamp<->key in one long linear path. I stuck my keys on a little keyring that I secured to the clamp on my right nipple, and tied one end of the string to both of the chains, connected behind my back. I tossed the rest of the looped string to the other end of my room, before tying the other end to my left wrist cuff.
Next I tied off 3 lengths of rope dangling from the pull-up bar, and dragged my nightstand underneath. I balanced lying on my stomach on the nightstand, and started working on the hogtie. I tied one of the dangling ropes to my ankle cuffs, one to the D-ring at the top of my muzzle harness, and finally slid the blindfold down before tying off my wrist cuffs. IF YOU DO THIS, TEST how much slack each rope needs to leave you in a strenuous but not injurious position.
This left me in essentially a very loose hogtie. But by wriggling my way forward and kicking/kneeing the nightstand over behind me, everything violently tightened as I fell to the floor. I was extremely mean to myself this time. Only roughly from my hips to my belly button were actually touching the floor. Everything else literally from head to toe was wrenched back into the air in a brutal stress hogtie.
Reeling the string in was a process. I was in pretty serious pain from the get-go. And with the clamps set up like they were, I eventually had to pull HARD to rip them off of me. Ended up being about 8 hours from stripping to release. Ended up being sore about all week. So basically 10/10 violently climaxed and dropped the string 6 times.
Second, a direct Bondage Challenge to YOU @CaptiveDan specifically (but also in general to anyone who wants to):
Obviously no pressure if you don't want to do this, but Part 1 of your recent story (especially with the illustration) made me think of something I think could be really fun(ny). The position almost reminded me of a bitchsuit, where your arms and legs are doubled-over so that you're forced to crawl on your knees and elbows. That gave me an idea for a co-op challenge for you and your bf.
Before the challenge, take your keys and hide them somewhere, ideally really high up, really tucked away somewhere extremely hard to find.
Ready a blindfold over your forehead, so you can pull it down over your eyes when the time comes. Use your head harness muzzle to gag yourself. Dealer's choice as to whether you put your ballgag or mouth stuffing underneath -- or both. As long as you're completely silenced.
Now start tying yourself. Frogtie your legs like in Part 1 of your story: cuffs around your ankles, rope around your thighs to press your heels to your butt. Slap a cuff around each of your wrists, and put another pair of cuffs on your upper arms. When you padlock your wrist cuffs to their corresponding upper-arm cuffs, you're all done: the classic bitchsuit position. The challenge is to help your bf find the keys however you can, blind, gagged, and bound. ;P
I noticed you put on only one fist mitt sometimes. I want to suggest putting athletic/knee-high socks over your hands/forearms as a middle-ground. I'll usually leave my arm bonds for last, and pull the socks over my arms before putting on the cuffs and locks. I've found this leaves me with juuust enough leeway to manipulate the cuffs and locks shut, but becomes massively restrictive afterwards.
Some addons if you're feeling brave: (weighted) nipple clamps, ear plugs, and a collar/leash (only if that's not triggering)
Alternatively, you could turn this into a solo adventure by putting the keys somewhere low down you'll be able to reach yourself! After your blind bitchsuit odyssey, that is.
- CaptiveDan
OMG @Kishi that hogtie position is so fucking hot! I'm in awe of your stamina… 8 hours??? That amount of strain would have had me tapping out/safe wording so my bf untied me in like 30 mins max. Thank you for sharing, what an incredibly hot and educational report.
I loved your idea for a challenge and did it! I also did a challenge @YourCaptor75 gave me.
@YourCaptor75 had challenged me to stay gagged twice as long as I had been before. I'd guessed I'd probably been gagged at most for a bit over an hour, so I decided to go for two hours + some change to be safe. Because I often start to freak out and feel like I'm choking/suffocating when I'm gagged and tied up, I decided to test if this was legit or in my head. I began my hours gagged unrestrained, but gagged and in my underwear, otherwise able to work and do things around the house.
I tied myself in a karada rope harness, just for fun. It was decorative and the ropes were a nice tactile sensation, but it didn't actually restrain me.
Then I got to gagging myself.
First I did the ball gag under the muzzle combo. I lasted a full hour with this, working on some creative projects on the computer as I wore it. I made A LOT of spit, so much it started to pool in the muzzle and flow down my chest. It had to really fight my urge to take the gag off, and definitely did start to feel that choking feeling.
So I switched to the sock under the muzzle combo. I took more time than usual to make sure all the straps were in the right position and tightened so I couldn't open my mouth and spit out the sock. Mission accomplished, I was effectively muffled.
I worked another hour gagged, and the coming feeling didn't happen. I learned a few important things: 1) the ball gag+muzzle combo I should only do for shorter scenes. 2) I can stay gagged with the sock+muzzle combo for longer than I think I can. 3) It's really hot to do creative work / house work while nearly naked and fully gagged.
I decided to roll my time gagged into your challenge @kishi.
I hid the key in a big pile of laundry I needed to put up. I prepped my blindfold on top of my head (great idea btw), then tied my ankles to my thighs. This was by far the most comfortable, effective, secure, and restrictive ankle-to-thigh tie I've done so far… practice makes perfect I guess. I added clothespins to my nipples as encouragement to find the key fast.
I attempted the sock over arm thing, but doing so made it so I couldn't close the locks. I'll try it again a different time, maybe with a thinner sock, but this time I returned to my classic one mitt technique.
I pulled the blindfold down, locked the wrist-arm cuffs and got to work.
First observation: holy shit this was humiliating. The awkward elbows and knees crawl across the floor, blind, gagged, and rock hard must have looked downright pitiful. I tried to stay quiet to not draw attention to myself so my bf wouldn't look at me.
Second observation: it is hard to walk/crawl on my elbows and knees. Even on carpet my knees quickly got sore, and my (lack of) muscles got pretty tired pretty fast. I tried to lay face down on the floor, but that only made the clothespins on my nipples hurt more.
I stumbled around blind for a bit, quickly losing track of where I was (I have horrible spatial awareness) and bumping into walls/furniture.
Fuck this could take a while.
Eventually though I figured something out, I could use the sounds of my apartment to orient myself. The washing machine came from one side, the tv from another, and the road outside from another. I remembered where I hid the key. I moved as far as I could from the laundry and TV sounds, roughly following the traffic sounds outside. I bumped into quite a lot of walls, and it took some time, but I eventually found my way to the clothes pile.
It was tough, but I used my bent right arm to search for the key, as I laid my body face down on the clothes. Surprisingly it only took like a minute to find the key, which was good as the clothespins were unbearable as I laid prone. I sat up on my knees, holding the key in my right hand, and began trying to unlock the cuff.
This actually was much easier said than done. With the angle my arm was in, and the blindfold, and my general clumsiness, it took upwards of 10 full minutes to get my right cuff unlocked. Once I’d done that I was home free. I unlocked my other cuff, removed the clothespins, took off my blindfold.
But I didn't untie my legs or take out my gag… I had a few new ideas to try out.
Thank you so much @kishi and @yourcaptor75, I love y'all's self bondage challenges, and kishi I'm constantly inspired by your creativity and stamina in bondage. I'll share some self bondage ideas I had and tested in the second part of my night soon.
YourCaptor75
Right on little buddy.
This is so fucking COOL!! Awesome work, truly! Genuinely in awe of your adventurousness. Really glad you liked the challenge, and my report. I might be somewhat of a masochist. Or an adrenaline junkie. Just immensely depraved in general.CaptiveDan wrote: 1 month ago OMG @Kishi that hogtie position is so fucking hot! I'm in awe of your stamina… 8 hours??? That amount of strain would have had me tapping out/safe wording so my bf untied me in like 30 mins max. Thank you for sharing, what an incredibly hot and educational report.
Really impressive to stay gagged for so long, especially since you haven’t gone longer than a hour until now. You think you’ll be up for doubling the time again anytime soon? Only 6 more doubles to go until you’re about where my current pb is, lol
I LOVE the humiliation of this position. I guess you do too if you were reportedly rock hard. Something to keep in mind for the future… ;P Super glad you incorporated the nipple clamps here. It’s a perfect built-in punishment for trying to rest flat on the floor, and pain is always a great incentive to hurry!
Seriously impressed and proud of you for pushing yourself and committing to the challenge(s)! Really love how much detail you put into this write-up. Now you’re ready to bring it to the next level with a pair of ear plugs, and having your bf hide the key from you ;P
You’re very very welcome @CaptiveDan! And thank you so much for the kind words! I’m so stoked that you’ve been enjoying these challenges, and I hope I’m able to help you push yourself limits even further!
Really excited to hear how the rest of the night went, and I’m always game if you have any challenges of your own! (Although you might want to dial up the severity if you’re after me specifically, lol)
- CaptiveDan
I definitely don't think I'm ready to double my time gagged again just yet... I'll need to work up to that!
I will totally think up some challenges for you @kishi! But yeah I'll definitely need to recalibrate to accommodate your level of toughness/masochism
Here's what happened the rest of that night...
And perhaps two positions anyone could try out if they wanted to
Pole-Assisted Hogtie
This is a position I tried out while I was still gagged, had my thighs and ankles tied together, and wrapped in a karada rope harness from my earlier challenges from @Kishi and @YourCaptor75
I laid on the floor, each ankle tied to my thigh. I added a rope between the two to also connect my ankles. I then tied the end of that rope to a chain, which I brought from my ankles to a sturdy wooden post on my coffee table. I locked the chain around it, which pulled my ankles up and forced my legs to bend in a classic hogtie setup.
Rather than cuff my hands behind my back, which often makes it too easy for me to untie my leg bindings, I brought my hands around the post and locked my cuffs together and to a link in the chain.
This was immediately very effective. The way my cuffs were padlocked to the chain kept me from behind able to scoot forward, while the post itself kept me from being able to pull back. The taught chain forced my legs to bend upward, and recreated that trapped, compacted hogtie feeling. My wrists were nowhere near anything they could untie.
I was trapped, or at least would have been if I hadn't kept the keys in my hand. I didn't want this to be my last position of the night, but I could have stayed there for a good hour if needed - there was no dangerous strain or breathing problems.
Thanksgiving Turkey
When I was done enjoying the modified hogtie, I unlocked my cuffs and flipped myself over.
I laid on my back, lifted my legs up, then pulled the chain taut so my tied ankles and thighs were forced into the air. I locked the chain back around the post and put a pillow under my ass and under my still muzzled head.
I put on clothespins, set up my tens unit to zap my thighs, then put a bandana blindfold over my eyes.
I locked my wrists cuffs around the post and to the chain on the other side, just as I had done before.
The effect was me laying on my back, legs up in the air, ass and cock fully exposed. I was gagged, trapped, and starting to feel the pain from the shocks and clamps.
This position was incredibly fun. I felt helpless, hot, and securely held in place.
I enjoyed the position for a few minutes then decided to switch it up, I had an idea for some couch bondage I wanted to try. I started fumbling with the keys to unlock myself…
…And then accidently dropped them.
Fuck.
I tried to reach my bound hands to get them. Too far. I tried to pull my legs up to use my toes to grab them (something I've done to escape before) but my feet were too far away.
I made some muffled requests to my boyfriend who was working nearby. He pretended not to understand that I was asking him to free me.
I was now tied up for real.
I settled into my situation. I'd be here for as long as my bf wanted. I tried to adjust myself and found the position quite rigid.
As the true permeance of my scenario set in, the nipple clamps and electric shocks felt worse. Now they weren't a nuisance I could freely end, they were torture I'd accidently condemned myself to endure.
After 20 minutes the tens unit cut itself off (it does it as a failsafe). Unfortunately by now a new torture was front in my mind.
My lifted legs were starting to hurt.
The forced legs in the air position proved to be quite the predicament. To alleviate the pain on my legs and ass, I could flex my whole body up and make my feet touch the ground. But because of the tight chain, I had to do an awkward crunch to actually achieve this, which strained my abs.
Without intending, I'd created a predicament bondage scenario where I was constantly switching between engaging my weak leg muscles or even weaker core muscles.
30 minutes in (which I only could deduce from the show playing in the background ending an episode) I started to cough as the sock in my mouth, now fully wet from an hour and a half of my saliva, didnt absorb any more spit. In the last position the spit just dribbled out of my muzzle and to the floor, but here it pooled up against my face and in my throat.
I thought about safe wording / signaling so as to not choke, but thankfully before I did, my bf released my gag.
I asked him to let me go so I could tie myself up a different way. He refused, said he liked me in this position, commented on how sweaty I was, played with my exposed balls and taint, and then reblindfolded me. He did have mercy and take off my clothespins.
Two more tv episodes passed. Another hour tied up, my muscles and mental fortitude weakening more and more.
I struggled in vain, and found myself slipping into subspace.
Finally I heard my bf sit down by my feet. I felt his gentle touch on my cock.
Over the course of the next episode - another full 30 minutes - he edged me. I begged to cum, tried to thrust my core into his hand as he repeatedly brought me close and let go. He tickled my taint and balls, and pushed his finger ever so slightly inside my ass.
Then finally, he finished me off. I shot my load and caught my breath. He released me and we went to bed.
Next time I do this position I'll need to clean out; it would be a perfect position to bottom in.
Highly recommend it @kishi and any others who enjoy bondage!
► Show Spoiler
Thanksgiving Turkey
► Show Spoiler
Fuck.
YourCaptor75
Your boyfriend is a good dom. I'd like you to thank him for being so attentive to your needs and limits, and pushing you when you have further to go.
I also want to condemn you for going above and beyond with these challenges. Even if it's partly due to fumbling the keys
All things in due time, lolCaptiveDan wrote: 1 month ago I definitely don't think I'm ready to double my time gagged again just yet... I'll need to work up to that!
Really love your creativity! Those are some interesting positions. Predicament bondage is always so much fun. I'll have to give that second one a try after the holidays.
Love the incorporation of the tens unit! I'm a huge fan of electro too. Splurged on an Estim 2B unit last year and it's one of my absolute favorite pieces of gear.
Your bf is a real one for taking control and helping you push your limits after you dropped your keys. Totally agree with @YourCaptor75, you should find a way to thank him properly ;P
Super interested in what kinds of challenges you can come up with. Maybe you can help me push my limits too! Maybe. Haha
YourCaptor75
If me and Kishi both agree, then you basically have to do it @CaptiveDan
Yer next challenge is gonna be something your bf gives ya.
CaptiveDan wrote: 1 month ago Next time I do this position I'll need to clean out; it would be a perfect position to bottom in.
If you're up for tying yourself in that bitchsuit position again, I have an idea lol
