Stuck in Self Bondage (self/m)
myaltbob2
Post by myaltbob2 »
This happened to me a few months ago. It was a night where I was home alone so I decided to do some self bondage. The way I tie myself up is by making two belt handcuffs and tying a piece of string from one cuff to the other, so when I put my legs and wrists through the cuffs, I can tighten my wrists by pulling up legs away from me.
Normally I wear a jacket so that it’s easier to pull my arms out of the belts and it hurts less, but I couldn’t find my jacket this night so I decided to not worry about it since I thought it would be fine. I set up everything, taping my legs together, shoving a sock in my mouth and putting a piece of tape over it, and finished it off with a blindfold I took from my parents’ room. After that, I put my wrists in the loop and that’s when I got stuck.
I enjoyed struggling for a bit, but I got bored pretty quickly. When I went to pull my arms out, I realized then that I couldn’t. I cried out into my gag and started panicking, pulling as hard as I could against the belt. My own self bondage system working against me, as the string I used to connect my legs to my wrists wasn’t long enough to allow me to stand up or move around. In fact, if I wasn’t careful and moved my legs too much, it would tighten the belt even more.
I tried to spit out my gag, but the tape was surprisingly strong, and I couldn’t do anything about it. With some effort though, I was able to get the blindfold off. I found my emergency scissors and tried to cut the string, but I wasn’t able to reach it. I resorted to the next best thing, cutting the leather belt itself which also didn’t go well. Eventually, after lots of struggling motivated by the thought of my parents seeing me like this, I managed to pull my wrists out of the loop and immediately untied myself.
I was probably only tied up for about 15 minutes, but it felt way longer. Getting stuck really shook me, but I’ve since came up with better and safer ways of tying myself up.
hope you enjoyed!
Gino
Post by Gino »
Cool story, and lucky to have you back on track...please tell us about your new methods :-)
myaltbob2
Post by myaltbob2 »
now i just use a belt that has less friction so it’s harder to get stuck. i also don’t tie myself up like that anymore. this graphic (https://sta.sh/016xugcyz3if) i made a bit ago shows how i normally do it. the only difference between this way and the one in the story above is that instead of hooking the string on a doorknob i tie it around my leg bindings.
silvertejp590
Post by silvertejp590 »
Fun story! I definitely got into a situation like this a time or two in the past during my experiments with self-bondage.
