Cost-Effective Bondage Devices You Wish Existed
Sometimes I wish there was a spanking machine for self bondage aficionados like myself. It seems like I've seen one before but the one I've seen cost near $1000. Also a motorized cart similar to the metal carts used for hotels that you could bind someone to and control remotely.
- JulieG
- Location: Tied up and spanked over your knee, or in the dungeon tormenting you!
I think it was Jon Willie who drew pictures featuring women in stockings pedalling bicycles with the rear jacked up and the back wheel attached to a third cycle wheel with floggers attached. The faster you pedal, the harder you are spanked.
A mummification machine like on that Japanese game show. It may need a "reverse" or "undo" action, for which you could set a timer!
I love all things bondage. Always up for a chat
A small electronic winch device that attaches to your person and can tighten the ropes on command, timed or otherwise. The biggest problem with self rope bondage is that when you tighten one rope, it loosens another. You need to either anchor to something or accept that some of your bondage isn't going to be totally tight. Not ideal for a perfectionist like myself.
- BlissfulMisery
Sounds like a really fun way to exercise! Includes plenty of motivation to not slack off tooJulieG wrote: 1 month ago I think it was Jon Willie who drew pictures featuring women in stockings pedalling bicycles with the rear jacked up and the back wheel attached to a third cycle wheel with floggers attached. The faster you pedal, the harder you are spanked.
One of those things that feels like it *should* exist (in a simple, affordable version), but I suppose the market for it is probably too niche to justify.
More magnet-operated self-bondage gear! Seriously…why isn’t there more stuff available like this? Specifically, I’d love for there to be cuffs and complete bondage systems that rely solely on battery-powered magnetically locking mechanisms with no visible wires. The magnets are super strong, and in the worst case scenario, you’ll be out in 8 hours (depending on how long it takes to drain the battery pack).
There’s one such lock that’s on the market (MagLock). It’s a cube with two attachment points connected to it. Attached both sides to cuffs, or one side to a cuff and another to the bed. It’s time-programmable with an app, but (again) if that fails, the worst case is that you’re stuck until power runs out of the battery. And, with no external wires (it has an integrated battery), you can’t just cut the power cord (or just pull on it really hard) to be released.
Why aren’t there complete systems that use this kind of setup? Beds, chairs, and other bondage furniture that have battery packs integrated into them, such that they’re are no visible/external wires that can be cut/pulled, and are user-replaceable (but are hard to get to…such as being in locking compartments in the furniture). Strong magnets would be integrated and placed at various locations on the bed/chair/furniture so all you had to do was apply your cuffs (which also have a magnetic integrated into it), then by simply placing your hands/ankles/whatever near the other magnetic, they would click together. After a session, just plug your bed into an outlet and it would charge all the integrated battery packs overnight.
Think of the possibilities! Whether spread eagle, hogtie, or chair tie (or whatever), the system could be designed with an app that tightens the restraint straps, and maybe even the cuffs themselves. You could really have a really technically advanced system here, but with complete (as is possible) assurance that you’ll at least be free in a few hours.
Oh…did you say, cost-effective? Hmmm…I could easily see this type of system into the hundreds (if not thousands) of dollars…but it would probably be worth every penny!
