THE UNDERGROUND BUNKER: TEAM-BUILDING GAME (M/M) *BONDAGEFREAK EDITION*
@Ossassin
BUNKER COMPOSITION: Nick, Zack, Hunter, Big Mike, Steven & you
POTENTIAL FOR CONFLICT: LOW
COMMENTS: A nicely varied team with excellent potential for good chemistry. I foresee very little potential for conflict here. As you've noted, Nick and Zack work very well together. Hunter and Big Mike would most likely get along well, and Steven tends to do fine around everyone (save for Phil). Zack would most likely be instigating most of the mischief, while also assuming a leadership position, aided by Nick. Hope you and Steven survive the footwear, though! Both of you would each have two Doms to contend with.
PREDICTED TEAM LEADER: ZACK
Bonus points for keeping Nick and Zack together!
@Volobond
BUNKER COMPOSITION: Erick, Andrew, Big Mike, Steven, Jeremy & you
COMMENTS: Definitely a nicely balanced team. Kudos for the detailed explanation! I foresee no trouble here. Erick would clearly be in the lead, with yourself, Andrew and Big Mike all acting as supports + helping keep Steven & Jeremy in line. Erick and yourself would most likely be instigating most of the fun. You and Big Mike would surely get along great. Low to non-existent potential for conflicts. Definitely a drama-free team.
PREDICTED TEAM LEADER: ERICK
Bonus points for keeping Andrew and Big Mike together!
@Volobond
I realise we're still early and that many haven't created teams yet, but it's still interesting to compile the preliminary results.
I'm definitely seeing a trend so far, with some characters being snubbed and others dominating popularity-wise.
So far, the five frontrunners are as follows:
ZACK, NICK, HUNTER, ERICK, ANDREW
@GoBucks
BUNKER COMPOSITION: Zack, Shawn, Chad, Brody, Mitch & you
POTENTIAL FOR CONFLICT: MEDIUM
COMMENTS: Yikes! This one spells, trouble. Especially for you, seeing as how you'd be the only sub for five of the most hulking and demanding Doms around. I put this team down as Medium in terms of potential for conflict. My money would be on Mitch assuming leadership, supported by Zack. While I do think there's a fair chance Shawn, Chad and Brody see nothing wrong with this arrangement, there remains a fair bit of unpredictability due to the amount of uncompromisingly dominant spirits and raw testosterone floating around.
The potential for peaceful coexistence is definitely there, especially due to Mitch being a natural fit and leader for high testosterone groups, but the potential for conflict should not be dismissed out of hand. The hazing would be quite extreme (often led by Mitch himself), and you would quite naturally end up being the butt end of it most times. Don't expect Zack to come to your aid. As you know, he tends to get carried away with teasing/hazing quite a bit as well. Good luck! You'll need it.
PREDICTED TEAM LEADER: MITCH
Bonus points for keeping Chad and Brody together!
@Guardianbound
BUNKER COMPOSITION: Zack, Nick, Erick, Ethan, Jeremy & you
COMMENTS: An interesting and smartly built team! I say smartly built, 'cause unlike many of your colleagues who went 'full horny' you seem to have opted for liveablity and balance. Combining Nick, Zack and Erick in the same bunker would be interesting. I honestly do not know how that would play out leadership-wise. Had your team composition been different, it might've posed a problem. But the fact that you've included Jeremy and Ethan (one sub per Dom) changes everything and greatly reduces the unpredictability of this combination.
My gut feeling tells me that, if crammed together in one bunker with three subs, Nick, Zack and Erick would end up stalemating and shelving the idea of a leadership position. Seeing as how there are no younger jocks to mentor and keep in line, there wouldn't necessarily be a need for a team leader position. All three of them could work in unison and decide everything together and with equal influence.
It would be really interesting to see how the Doms would split Jeremy, Ethan and yourself up. I wonder who you'd end up with.
PREDICTED TEAM LEADER: UNKNOWN
Funny, being the "Butt end" of hazing is exactly what I was going forbondagefreak wrote: 6 months ago The hazing would be quite extreme (often led by Mitch himself), and you would quite naturally end up being the butt end of it most times. Don't expect Zack to come to your aid. As you know, he tends to get carried away with teasing/hazing quite a bit as well. Good luck! You'll need it.
@Pup Wingletang
BUNKER COMPOSITION: Nick, Andrew, Joshua, Zack, Steven & you
COMMENTS: Another very smartly composed and balanced team. Kudos for the detailed answer and explanation of your choices. As usual, you have the characters down to a T. I foresee no chance of conflict in this group. Yourself, Steven and Joshua would undoubtedly get into lots of minor mischief. Andrew would be the no-nonsense, strict enforcer, keeping close tabs on all three of you and making sure all rules were followed to the letter. Zack would most likely assume leadership, with and supported by Nick. Friendships would be great in this group. A very balanced team with great potential for fun and mischief.
Bonus points for keeping Joshua and Steven together!
@4toes
BUNKER COMPOSITION: Nick, Zack, Shawn, Andrew, Erick & you
COMMENTS: Holy Moses. A beefy Dom fest! I think the potential for conflict is definitely present, seeing as how you have five Doms, four of which would instinctively attempt to assume some sort of leadership position. Zack, Erick and Nick should, theoretically, be mature enough to realise that there is strength in unity. But with the glaring absence of subs to relieve some of the tension, jealousy and ambient aggression, things may occasionally boil over. In such a scenario, Shawn may prove a destabilising element. Either way, the demands on you (both physically and otherwise) would be enormous. I hope you kept that in mind!
Bonus points for keeping Nick and Shawn together!
@Subboi
BUNKER COMPOSITION: Erick, Nick, Zack, Corey, Bob & you
COMMENTS: Beefcake-fest. Normally, combining all these assertive Doms together would be problematic and leave room for open conflict. However, Bob's presence greatly offsets things in that he would assume natural leadership of the group, in large part due to his profession and greater experience. The younger Alphas would undoubtedly look up to him and respect him, much like they would Mitch. Still, the physical and mental requirements you'd be faced with would be enormous. These five supremely beefy guys would undoubtedly have no choice but to converge on you for relief. Perhaps hot on paper, but IRL, this would quickly pose a serious problem for you. You'd be busy! That's for sure.
PREDICTED TEAM LEADER: BOB
- WhereAmI
- Location: Admiring You Artistically HogTied As The Centerpiece, Squirming On My Thanksgiving Table.. 🪢🤗🪢
Whoever is in charge of the ice
cream, DR PEPPER
, Snickerdoodles
, Ice
Cubes, and cats
, get my votes.
To tie you up is human, to tie you up and tickle you is divine. ME
@noarmgr
BUNKER COMPOSITION: Erick, Bob, Hunter, Big Mike, Joey & you
COMMENTS: An interesting combination with no predefined friendship bonds. You're right to predict that Bob would assume leadership, supported by Erick. Conflict potential remains quite low, but the lack of submissives would still pose some problems and entail a certain risk. Joey's assertive character would make him an ideal (though somewhat harsh) enforcer. Both Hunter and Big Mike would most likely also serve in this capacity. All in all, you would be in for a serious challenge. Dealing with these five and their needs and expectations would be a serious feat. Good luck!
@Bradstick
BUNKER COMPOSITION: Ryan, Matt, Brody, Joshua, Andrew & you.
POTENTIAL FOR CONFLICT: HIGH
COMMENTS: Yikes! An explosive team if ever I've seen one! Joshua tends to be a useful pivot in many of the teams assembled so far, but in this team, I'm not sure he'd be doing you much of a favour. Joshua would undoubtedly work in your favour in relieving some of the tension, but I fear he may also contribute to the group's unstable chemistry and exacerbate things. More importantly, Ryan and Brody would be an unpredictable duo.
You're correct when you mention that Brody and Matt can follow orders. But don't forget that Brody is kept on a figurative leash by Chad. Remove Chad from the equation and you have a fully unleashed Brody. Ryan is also extremely assertive and has been shown to be crafty, adept at manipulation and smooth. I seriously doubt he would capitulate to Brody's authority. And I very much doubt Brody would agree to do the same by submitting to Ryan's. Matt's presence would only further embolden Brody. Andrew may prove the bigger person and attempt to keep things from devolving, but even taking his imposing height and stoic non-sensical personality into account, I seriously doubt he would be able to keep Brody, Matt and Ryan from coming to blows for long. If Andrew and Joshua side with Ryan, which they might, seeing as how Ryan comes off as outwardly more reasonable than Brody, it might stalemate things. But then again, would a stalemate be a good thing? Not necessarily.
Though I cannot tell you for certain the outcome of such a confrontation, if open conflict erupts, my money would be on Brody overpowering Ryan, and assuming control of the group through brute force. He would dominate and control you with an iron fist. Even should a truce be reached between the two, Brody would be most assuredly still dominate you. This would definitely make for an interesting story - one filled with drama, power plays and jealousy-filled love triangles. Who wants to write this?
Bonus points for keeping Matt and Brody together!
bondagefreak wrote: 6 months ago @Bradstick
I can’t tell whether I fucked myself in a good way or a bad way. I would absolutely love to be in this scenario though, let Brody and Ryan fight over me, keeping me gagged and unable to offer my own option. I regret nothing with my choice, maybe I should have taken Corey instead of Ryan to truly even out the odds but still, I love my choice!
Corey & Ryan vs Brody & Matt.Bradstick wrote: 6 months ago I regret nothing with my choice, maybe I should have taken Corey instead of Ryan to truly even out the odds but still, I love my choice!
Now THAT would be an interesting matchup!
You would be the prize, of course
For extra added chaos, replace Andrew with Corey and then Joshua with Phil. That fucker would absolutely cause tension between the two sides, leaving me to get fucked in the process!
Or if you really wanted some chaos, how about Ryan, Brad, Shawn, Brody and Phil in the same bunker?
Wouldn't that be fun?
@Bradstick
Either way, I think you and @OrdinaryWorld have assembled the most potentially explosive teams (so far).
@Bradstick
Thank you for this analysis. I was probably a little horny when I shortlisted the crew. I would still like to give it a try as I am sure there would be some sort of hierarchy establishing itself there.
bondagefreak wrote: 6 months ago @Subboi
The ones I have selected for my bunker mates would be as followed.
Nick, Zack, Mitch, Ethan, and Andrew.
Yes! I got a 100% mark on my predictions for you.Stormee wrote: 5 months ago The ones I have selected for my bunker mates would be as followed.
This is actually the team I suggested to our good friend @OrdinaryWorld.
The only doubt I had in my prediction was whether you would choose Corey over Andrew.
Anyways, will post my comments about it in a bit.
cataylor93
Andrew - The hairy legged jumbo footed heart-throb is a MUST for my bunker! He is my favorite character and I would enjoy being his captive for late night gaming. Hell, maybe I can even join him for some gaming too! I imagine multiple scenes of him deep into his element of gaming while I sit across from him, my face planted in front of his huge soles and toes, sniffing the rank stench. It would turn me on something fierce! And then the apathetic gamer would glance at me with unfeeling eyes as I look back at him with genuine affection and submission. Perhaps he gives me a small smirk or even a subtle expression of approval…perhaps he merely keeps up that stoic apathy and turns his attention to the next round of his game while I give his sweaty socks a good washing in my mouth. Either way, I'm in heaven!
Bob - I want someone older and more experienced in the hazing and TUG fiascos; someone I can trust to keep the more extreme and animalistic guests in check. Bob is a great fit for the title of Bunker Daddy. Not only do I find his physique irresistibly burly and buff AF, but also his father-like demeanor brings comfort to me sharing this space with some seriously capital A alpha males. I could see Bob tying up the younger bunker bucks like Ryan and Corey when they get too mouthy or undisciplined. As the token twink of the group, I expect to be preyed upon by the muscle-bound hunks of the bunker, so having a cool headed cop here to keep things from getting out of control will give me the courage to permit more extreme behaviors from the more aggressive guests we will see later. I imagine a very comforting scene where Bob holds my bound hands and ankles body to his chest and lets me use his pecs like pillows while stroking my hair and petting my shoulders, affectionately calling me a “Good Boy”
Nick - I recently completed the Bondagefreak match game and while Andrew was my match, Nick was a close second. Upon reading through the first few parts of Bound n Gagged, I can see why he might be a good fit for me. He strikes that right balance between dominating and having done lite teasing fun with me while showing some degree of empathy and care. He will bring a degree of adventure and lite hazing to the mix and offer me some variety over the next five years. I can see Nick going through with an elaborate kidnapping adventure, capturing me in those strong arms, binding me tight till I'm helpless, and gagging me to absolute silence. However…things may get a little out of control and I could end up emotionally hurt like Steven. Yet I remain confident that I can forgive Nick and our relationship can develop into one built on trust, attraction, and my role as his Twink. I could spend many nights kissing his body all over, especially his big feet.
Corey - While he has a body type a fair bit larger than my usual taste, Corey is a gamer like Andrew and like my hairy legged favorite character, I could see Corey and I bonding over games in between him literally BONDING me up in a web of ropes and silenced with a fresh cum sock. God just thinking about that makes me so hot and bothered! *Hand fans my Twink face* Anyway, Corey displays the apathetic side of my fantasies and he seems very kind and respectful. I see him acting as a mediator between myself and Ryan while also becoming a great accomplice to my many kidnappings at the hands of the gym rat Ryan. I can think of an amazing scene of myself bound head to toe in rope with Corey barefoot in just his undies above me in his computer chair. As I struggle in the ropes and try to bargain for him to release me, the apathetic hunk covers my mouth with his big foot, silencing me with his goliath soles. I sniff them and become dizzy, calmed by the funky scent, muffled by his feet as Corey ranks up his K/D rating and I rank up my Foot Fetish rating!
Ryan - Ryan is a strange choice for me. He is notorious for dabbing in verbal degradation and mean spirited teasing. And I have to confess that during my reading of How I Became the College Doormroom Slave, I found his verbal treatment of his step brother to be appalling…BUT there are some distinct qualities about Ryan that I would be remiss to not bring him to the bunker. For starters, he probably has the second most perfect body type for me, only losing to the hairy legged gamer himself. Ryan seems to share some similar qualities to Chad whom while I do find more than exceeds my ceiling of hazing tolerance, he still shows a degree of affection and enough intelligence to recognize when things have gone too far. Ryan at a similar moment of clarity with his own step brother and went out of his way to do something very nice for him and even showed some signs that he was beginning to understand his gay step-brother. I believe Ryan and I may take some time to get to know each other and become comfortable around each other as well. The advantage that I have over Ryan’s step-brother is I have greater control over my baser urges and desires to sniff and partake in socks and clothing of the hunky jocks I'll be staying with. I can see Ryan respecting me because I will respect his boundaries to a T. I value comfort and respect for everyone and I think Ryan will appreciate that and, when he is ready, I would drop to my knees and accept being bound and gagged to his liking and kept prisoner by him and his buddy Corey, sniffing all their smelly shoes and socks! I'd accept a little teasing and I am not opposed to some forceful language from Ryan, but like him, I have boundaries and with time, he’ll come to understand them.
So that is my explanations for each pick! Ryan's description was definitely longer than the others, but he was a wild card in this situation and I felt it necessary to explain him more since it was a contingent between him paired with Corey…or Chad paired with Hunter. In the end, Ryan and Corey won. I also realize that I am the only Twink in this bunker with five alpha males of varying dominance, but I must confess myself to be quite the jealous type. Having another Twink who might be more lenient on certain things or might be more preferable than myself will undoubtedly send my ego into a fit of derangement and possibly lead to some conflict. Funny how I have often said that I don't like feeling like I am a possession, but I do like the feeling of being possessed...yet the thought of sharing these bunker jocks with another Twink insights my own desires to posses. I guess in one sense, my complicated feelings on bondage and dom-sub relationships are a give and take on possession. I am theirs... but they are also mine. This means I will have to keep myself well hydrated and in good health to handle all these men who want a piece of me…and I look forward to it! I'm curious what the verdict from the expert will be!
@Stormee
BUNKER COMPOSITION: Mitch, Andrew, Ethan, Nick, Zack & you
COMMENTS: IMO, this is probably the overall best team for the average sub on here. Not only does it offer unparalleled safety, but it's hard to beat in terms of fun, bondage opportunities, social structure and chemistry. Add to that the fact that all five teammates would be very content to be housed together and you have a match made in heaven. I foresee no potential for conflict here.
Mitch would be the undisputed leader, supported by both Nick and Zack. Nick & Zack would both be real happy to be in the same bunker together and Mitch would be greatly relieved to be in the presence of his two sons. All in all, this would be a great team to be a part of, especially if you're the playful type who loves getting into mischief and getting hazed.
Bonus points for keeping Mitch, Andrew & Ethan together!
@cataylor93
BUNKER COMPOSITION: Bob, Andrew, Nick, Ryan, Corey & you
COMMENTS: That's quite a detailed explanation you shared with us. It seems as though you've thought this through quite a bit!
Interesting team! You're correct to assume Bob would assume a leadership role here. Nick would act as both a support and an enforcer. Normally, having so many Alphas in a confined space would create potential for conflict, but in this case, the Bob/Nick duo would greatly negate that possibility. Ryan would be quite pleased to have his buddy Corey around, and Andrew would get along with all of them really well. Nick would like Andrew a lot, and so would Bob. I foresee no chemistry issues here.
The only concern I'd have is for your well-being. I know you're still in the early stages of B&G, so I don't want to spoil anything for you, but you would undoubtedly find your tenure as the only sub quite gruelling. The demands on you would be great. I hope you realise that.
On the bondage/domination front, you have a nice mix of sadistic and stoic apathy here. The ropemanship skills of this team would be unparalleled, as would the number of potentially lethal gags hanging around. Good luck! You'll certainly need it.
Bonus points for keeping Ryan and Corey together!
cataylor93
I considered bringing Ethan as extra help, but if you recall my post from before...another Twink might actually cause conflict with me. I can both accept a degree of being possessed and I am also very possessive myself, but if I truly thought that I needed someone to take the pressure off of me, it would Ethan in and Bob would likely be out, making Nick the leader, which I think would be okay. The task would be difficult, but unlike Steven, I don't see myself provoking Nick's aggression. I'm far more confident and assured of what I want and what I can tolerate. I might need a day or two of recuperation in between some heavy handed bondage sessions with Nick, Bob, and Ryan, but I'm up for the challenge and eager to push my limits a little more on this adventure. Nick may be the only one that truly tests my limits, but I trust the hunk. Never back down never what!? XDbondagefreak wrote: 5 months ago @cataylor93
Thanks for the comment! I hope you respond to this one as you can think of it as a broader question of how my expectations are right or wrong or what possibilities I would have; as in could I establish meaningful and respectable boundaries with Ryan and Nick? Would they be receptive to my own mental limits? Would I get a day to recuperate if things go too far or be able to convince them of my necessity for a day to take a break? How accurate or inaccurate are my possible scenes described in my original post? I am moving on to building my kidnapper team next but I'm going to wait until I can get a little deeper into more of the lore.
Bye for now!
I gave this dynamic some thought and finally made my picks. First, I’m going with Mitch — his survival skills and personality really draw me in. Plus, he’s got experience dealing with other Doms, which is a huge plus. Second, I’d pick Ryan. He’s young, hot, and I feel like he’d be super active around the bunker. Third is Ethan — mostly to balance out the Dom/Sub dynamic in the space. I mean, five dominant guys locked up with just one Sub (aka me) sounds a little risky, lol. I also really like how Ethan’s such a reluctant Sub — the kind you usually have to take down by force (maybe I’m a bit of a sadist ). Fourth choice is Brody — he’s been growing on me these past few months, and I couldn’t leave him out. His muscles would definitely come in handy. And lastly, I’m choosing Hunter — I think his vibe would click really well with Ryan and Brody
Yes, it's me in the picture. What are you waiting for to tie me up and gag me?
This is one of the more difficult of these little challenges- Aside from the ouside apocalyptic factors, the only issues and conflicts are purely interpersonal. 5 years stuck together, lots of potential for conflicts, disagreements, issues to arise. All that said, here is my list:
Andrew: I can't help continually choosing Andrew for these challenges. Not only does he have high compatibility with me, he's got lots of good qualities in these situations- generally calm and cool demeanor, medical training, willingness to participate in bondage games (even being on the receiving end, if only occasionally). I can definitely envision hanging out with Andrew in the bunker, playing video and board games, and having a nice time with or without the bondage aspects. His foot odor is a major concern, given the cozy living quarters, but we could work on that, force some cleanliness, or hopefully go nose-blind to it...
Hunter: Although he is definitely a new favorite of mine, I do have some practical reasons for choosing him. His scout/survival training makes him almost as useful as Andrew for situations like this. While we won't be venturing out or trying to survive out in the apocalyptic wasteland, his training will still be useful. Basic first aid to help Andrew when needed, rationing and preparing supplies, comfortable sleeping on the ground/floor in a sleeping bag if sleeping arrangements get a bit tight. Plus, he's used to surviving in close quarters with his dorm-mates, so he should be fine with the small bunker life. And those scout roping skills will come in handy when it is time for some bondage fun. I can envision Hunter giving some restraint and knot tying lessons during our 5 years in the bunker. I also think he'd be a fine hang with video and board games along with Andrew! Again, foot odor is a concern...
Jeremy: Here's where I had to forgo some of my preferred favorites in favor of group bunker cohesion. Stealing some reasoning from @Volobond, having Jeremy as willing domestic servant and consistent bondage slave will keep the bunker running smoothly. Having these him to look after most of the cooking and cleaning will be a godsend, as well would having him be dedicated bondage toy for necessary relief/entertainment will be vital. While he isn't particularly my favorite character, but I cannot argue with the skills he brings to this situation. And on the plus side, he is not notably stinky! (and perhaps could be put to work to make sure Andrew's and Hunter's feet remain relatively odor free!)
Joshua: This is definitely the wildcard pick. I understand he does nothing for bunker cohesion, and actively works against a smoothly running bunker. But that's the point. He's going to bring some necessary chaos/fun to an otherwise mundane 5 years. Plus, he's small enough that He can be easily taken down and made to join Jeremy as a bondage toy when needed. Plus, he's just so pretty!
Corey: Again, a selfish pick. I just love this giant hunk too much. He doesn't provide much in any particularly important skills for this bunker, but he is very chill and go with the flow, which is good. And like @Volobond also pointed out, he is very malleable, and with nothing but time, I suspect could be molded into a wonderful hunky slave. Plus, he'd be a great cuddle buddy! At the very least, he'd be perfect to help keep Joshua in line when necessary!
I know this isn't a perfect group. We are lacking a clear leader from the guys I suggested, and perhaps the ones I picked lean a bit too passive, but hopefully things will work out. I could have swapped some of them out for the likes of Steven or Ethan to help Jeremy, or Zack to offer some real leadership, or Matt instead of Joshua for another playful chaotic agent, etc. I also would have chosen Mark in a heartbeat to join along with Hunter had he been an option, but overall I am happy with this less than perfect bunker group!
@cataylor93cataylor93 wrote: 5 months ago I considered bringing Ethan as extra help, but if you recall my post from before...another Twink might actually cause conflict with me. I can both accept a degree of being possessed and I am also very possessive myself, but if I truly thought that I needed someone to take the pressure off of me, it would Ethan in and Bob would likely be out, making Nick the leader, which I think would be okay.
Hmmm, the jealous type I see
On that note, now that you are approaching the mid-point of B&G and getting to know more characters, it would be interesting for you to try this exercise again at some point in the near future.
@Tsuhaya and @gag1195
Awesome answers, guys. Thanks for taking a go at this.
I will be getting to your respective teams very shortly.
