Though I have done many different self bondage scenarios over the years, nothing quite gave me the stuck BUT I know il get out (not on demand) feeling than using ice in a sock. I have done quite a few tied to bed scenarios to success (inescapable but ice release always worked) and a few different hogtie scenarios, but I wanted to try use this ice in a sock so i could really amp up my hogties whilst knowing il escape when ice melts.
It was not long after midnight on Saturday night, my parents and brothers were in their rooms sleeping. I had been particularly horny for awhile just thinking and planning this session throughout the day, so i wanted to go all out (thinking because ice, I can do my bondage without much fear of being stuck)
I laid everything I thought i would maybe use on the bed, 4 dressing gown belts, 2 scarfs, a leather belt, shoe+boot laces, socks, a bigish beanie hat, a couple of paper binder clips, a couple of solid rings/hoops(from a curtain rail), over the ear headphones connected to my computer with binaural male orgasm beats ready to go, scissors, a Gillette fusion vibrating razor(with head off)..I then went downstairs to the freezer to retrieve a cup of ice cubes.
First thing i did was strip to my boxers, poke my penis through the front hole, and put a tight ankle sock over, I thought since this is a hogtie I might make more mess than when on my back, so i put another sock over. I put on my leather belt around my hips just above the base of my penis and tightened the loop back through itself, so i could slip my penis in and tighten, pinning it to my body. I got this idea from another story here, i then ran a dressing gown belt as a crotch rope attached from the back coming to the front of the belt, with a knot pushing on the 'taint'. Feeling very turned on by this point, i unhooped my penis from the belt, took the socks off, and tied my Gillette fusion vibrator razor to my penis using a bootlace so the top was against my fendulum, replaced the socks and slipped my penis back in the front loop tightening again.
I tied my ankles together using a dressing gown belt, my knees together using a scarf, tied big toes together using a shoe lace, leaned over to press play on the video so the sounds were running, grabbed the ice cubs and started putting them into a sock, i then tied the sock of ice to another dressing gown belt and tied it as close to my ankles as possible while comfy. I was acting on pure excitement by now, i made a wrist coil using the last dressing gown belt that i quickly guessed using hands in front and my chin to whether it would be too tight, then i rubbed my nipples with some spare ice, and clipped them with the binder clips.
I laid on my stomach, put the headphones over my ears (all i could hear was bassy pulsing and sucking/licking sounds) then i put a beanie hat over the headphones and my eyes/nose, and tied the other scarfs around my eyes further locking my blindfold/headphones on. Getting into position, even though my bed was soft the binders were digging into my nipples, i reach around and after a little trouble found the button to set my vibrations off on my penis (shame its a 5min only vibrate)
I felt around to make sure scissors were near, wrist coil in hand, and a hoop. I reach for the sock of ice by my feet and kinda turned it into a U shape on itself and put the hoop over it ( like the bottom of the U) i passed my wrist coil through the bottom of the 'U' d sock of ice, put both hands in and pulled. The hoop would act as the cinch and my hands would be bound together tightly until the ice passed througg the ring.
So I usualy cum instantly once in bondage, even without any vibrations, and thats what happened..as soon as i pulled tight the sensations overwhelmed me and i exploded. Clarity hits, im blind and listening to those sounds and im tied so tight i try to get my blindfold and headphones off and realise i cant, the vibration gillete is so senstive vibrating away, my nipples hurt , and i cant get out..i have a mini panic attack and surge of horniness and adrenaline and manage to just grab the hoop on my wrists and move it towards my feet to allow my hands to slip out.
I rush to take my nipple binders off and turn the vibrations off , then angrily i untangle everything and pack everything away. I wanted to be trapped without choice, while the ice in a sock works so well for individual wrist ties, i could losen it using the method i used. Is there any other ice in a sock technique that could work as a guaranteed escape method? Or a different way i could of done it? Not using keys or anything as i would panic trying to unlock i bet.
Recent hogtie (m/self)
I wish I could finish tied like that! Sounds fun!
It is actually pretty annoying
Great self bondage session.
Nice session and nice story :p
Great story. Hogtied is difficult. I’ve used a bourbon big ball ice cube to freeze a handcuff key in and have it drop from a doorway. On the bed you you probably need to tie the sock under the bed so it didn’t release for awhile.
Thanks
Thanks
I have done hogties where I tied a solid ring to each wrist/ankle, and padlocked them together while the key was frozen in ice. But I get panicked if im going to be able to get out, like its hard getting the key in and opening it fast, or if my hands went numb or something. Stops me from going all out with blindfold/headphones and stuff, Id prefer an auto release that's kinda foolproof. Ice in a sock seem to work like that if i use it to keep my hands away from eachother separately like in a spread eagle. I did a tie to the bed recently in a Y shape, hands together and i managed to get the slipknot lose and escape early.Boundguy800 wrote: 6 months ago Great story. Hogtied is difficult. I’ve used a bourbon big ball ice cube to freeze a handcuff key in and have it drop from a doorway. On the bed you you probably need to tie the sock under the bed so it didn’t release for awhile.
