you fill out this bind-her request form?
1. D
2. A
3. A
4. B
5. A
6. A
2. A
3. A
4. B
5. A
6. A
Before entering the room, there’s a changing room for you to put in a red silk blouse, black skirt, and nude pantyhose. Once changed, there’s a pair of red high heels in your size to wear. You’re then brought into a closet where you’re sat on a chair and tied to it with rope around your wrists, elbows, chest, and legs. After stuffing your mouth, I place strips of duct tape over your lips to keep you quiet. Once secured, I lower the lights and close the door. I’ll be back for you when I feel like it.
1) D - randomly chosen
2) B - tape
3) A - tape
3) B - no
4) B - tickled
5) B - sportwear (but barefoot
2) B - tape
3) A - tape
3) B - no
4) B - tickled
Smoke me a kipper, I'll be back for breakfast
Ooooh this looks like fun...!
Hopefully multiple picks are allowed?
1. D
2. A+B
3. A
3.1. A
4. B+C
5. C
1. D
2. A+B
3. A
3.1. A
4. B+C
5. C
Thank you for choosing bind her. To start, please remove your current attire and dress in the contents of this garment bag. Based on your preferences, inside is a set of red lace lingerie with fishnet stockings. To start, one of our technicians will tie your arms behind your back in a reverse prayer, following that with a pentagram shaped chest harness that will end with a length of rope going down your stomach, through your legs, and pulled tight and connected to your arms. Then your legs will be frog tied with your calves tied to your thighs. You will then have a thick wad of cloth stuffed inside of your mouth, which is then sealed in with multiple layers of duct tape. A few additional wraps of duct tape will be wrapped around your chest for security reasons. After tying a black silk scarf around your eyes, you technician will sit behind with various tickling and teasing devices. You will remain tied until the vibrators run out of battery. Of course, some of them plug into the wall so it might be awhile.LayersOfLau wrote: 9 months ago Ooooh this looks like fun...!
1. D
2. A+B
3. A
3.1. A
4. B+C
5. C
Hello, I Wonder if this form also can be signed be a minor. If so, I‘d like to ask for the following things:
1-D (randomly chosen)
2-D (leather)
3-C (cleave gag)
3.1-B (no blindfold)
4-A (left alone)
5-B (sportswear)
Greetings
2-D (leather)
3-C (cleave gag)
4-A (left alone)
5-B (sportswear)
Greetings
1C
2A
3A
3A
4B
5D
2A
3A
3A
4B
5D
Very interesting service you got there~
1.) How long do you wish to be tied up for?
D.) randomly chosen.
2.) Which type of restrains do you want?
D.) Leather
3.) What gag do you request?
B.) Ball
3.) Blindfold
B.) No
4.) How do you want to spend your time tied?
D.) Tortured
5.) What outfit do you want to be tied in?
A.) Formal Attire
D.) Leather
B.) Ball
3.) Blindfold
B.) No
D.) Tortured
A.) Formal Attire
- Chloe Badelaine
- Location: Usually tied up in basement or in my office...
A.) Rope / Tights/ Scarves / Silk ribbons / Cloth strips
C.) Cleave with stuffing and OTM
3.) Blindfold
A.) Yes
A.) Left Alone / with my friend@SashaMoh
C.) Teased with my friend@SashaMoh
Big oversized turtleneck sweater, woollen tights, thigh high socks
3.) Blindfold
A.) Yes
I believe now is the time that you tie me up ? But i think that you are going to need much much more rope mon cher...
A.) xxxx
B.) xxxx
C.) xxxx
A.) Rope
B.) xxxx
C.) xxxx
D.) xxxx
A.) Tape (Stuffing please if possible
B.) xxxx
C.) xxxx
D.) xxxx
3.) Blindfold
A.) xxxx
B.) No
A.) xxxx
B.) Tickled
C.) xxxx
D.) xxxx
A.) Formal Attire (Can I wear pantyhose and stays with no shoes on?
B.) xxxx
C.) xxxx
D.) xxxx
A.) xxxx
B.) xxxx
C.) xxxx
A.) Rope
B.) xxxx
C.) xxxx
D.) xxxx
B.) xxxx
C.) xxxx
D.) xxxx
3.) Blindfold
A.) xxxx
B.) No
A.) xxxx
B.) Tickled
C.) xxxx
D.) xxxx
B.) xxxx
C.) xxxx
D.) xxxx
Well thank you for enlisting our services. You can start by striping your clothes, other wise our technician is more than capable of wrestling you down and stripping you, if that’s what you’re into. Once naked, we will bind your arms together behind your back in a reverse prayer, with more rope above and below your breasts. Your mouth will be stuffed with a special device that fills your mouth and forces you to bite down on it, which will be secured with duct tape. After putting your legs in a hog tie, your technician will spend the next few hours ticking you with everything that they can find that stimulates you.
Well, for you I think I’m going to handle this request personally. As CEO, I’m going to bring you into my office. After having you change into a white blouse, black pencil skirt, and thigh high black stockings, I’m going to strap a red ball gag with leather harness in your mouth and over your head. Next, a leather armband will be secured over your arms and locked tight. I’ll then cuff your ankles to either side of my desk in some leather cuffs. I’ll then spank you after pulling your skirt up, not stopping until your cheeks are bright red. Once done, I’ll then connect your ankles together and hog cuff you on my desk, occasionally playing with you while I work on some projects.Shanya wrote: 6 months ago Very interesting service you got there~
D.) Leather
B.) Ball
3.) Blindfold
B.) No
D.) Tortured
A.) Formal Attire
Mon Dieu, Chloe, someone of your caliber enlisting our services is an honor. As a huge fan, I’ll also handle this one personally. Once you and our fellow friend arrive, I’ll have the both of you knocked out with sleeping gas. Not wanting to waste any time, I’m going to remove your attire you can in with and replace them with thick black tights, an off white turtleneck, red thick thigh highs, and black socks. Out friend will be dressed similarly. While you’re still out, I’ll bind your wrists, arms, knees, and ankles. Pulling a crotch rope between your legs is the last thing I’ll do before gagging you. Stuffing a pair of white ankles socks in your mouth, I’ll stuff the crotch part of a pair of tights in on top of the socks, then use the legs to secure them behind your head. I’ll then pull your turtleneck up over your face, then add a scarf over it, then using another one to blindfold you. Once you and Sasha are throughly bound, I wait for you two to come to your senses.Chloe Badelaine wrote: 6 months ago 1.) How long do you wish to be tied up for?
3.) Blindfold
A.) Yes
Once the both of you are awake, I let you struggle for awhile with each other. However, once the rest of my staff arrives, I can let the next phase begin. I’m going to pick you up and carry you over to a large, overstuffed chair, sit down and have you take your place on my lap. After removing your blindfold, you see that six people have entered the room, all in thick sweaters, tights, and thigh socks. A wool mask obscures their face, and you’re unable to determine what gender they are. Using Sasha, they redress her just as they are, gagging her with her own socks. They then bind her before they take turns tying and teasing her and each other.
“You know†I whisper in your ear as you watch the show in front of you with my hand on your knee, “I haven’t told you how long you’re here going to be tied up for. With our lack of demand in the winter, I’ve decided that you’ll be here until the weather warms up. That is, unless you’re not satisfied in which case, I’ll find more rope.â€
Well, I’m happy to oblige you. I think a nice, short navy sweater dress with some sheer pantyhose would be a good starting point. I’d also have you arrive wearing white quarter socks over your tights. I’m going to start by box tying your arms behind your back, with more rope above and below your breasts, then I’ll complete the chest harness with a crotch rope. I’ll then tie your knees together, then strip off your socks and revealing your toes. Not thinking of anything better to do with your socks, I’ll gag you with them and tape them inside. I’ll then tie your ankles together and place you in a quick hogtie. After laying you on a couch, I’ll let you test your bonds for awhile before returning, undoing your hogtie, and proceed to tickle and tease your legs and feet, hearing you wail into your gag. Every time you get too loud, I give you a quick smack on the ass to remind you not to be too loud. I’ll let you free you’ve lost the energy to laugh.Silver_noro wrote: 6 months ago 1.) How long do you wish to be tied up for?
A.) xxxx
B.) xxxx
C.) xxxx
A.) Rope
B.) xxxx
C.) xxxx
D.) xxxx
A.) Tape (Stuffing please if possible)
B.) xxxx
C.) xxxx
D.) xxxx
3.) Blindfold
A.) xxxx
B.) No
A.) xxxx
B.) Tickled
C.) xxxx
D.) xxxx
A.) Formal Attire (Can I wear pantyhose and stays with no shoes on?)
B.) xxxx
C.) xxxx
D.) xxxx
- GwenGagged
1.) C
2.) A
3.) C
4.) A
5.) C
6.) C
Please feel free to do whatever you want to do…
2.) A
3.) C
4.) A
5.) C
6.) C
I didn’t realize I got roped into this but I’m all about itDioA wrote: 6 months agoMon Dieu, Chloe, someone of your caliber enlisting our services is an honor. As a huge fan, I’ll also handle this one personally. Once you and our fellow friend arrive, I’ll have the both of you knocked out with sleeping gas. Not wanting to waste any time, I’m going to remove your attire you can in with and replace them with thick black tights, an off white turtleneck, red thick thigh highs, and black socks. Out friend will be dressed similarly. While you’re still out, I’ll bind your wrists, arms, knees, and ankles. Pulling a crotch rope between your legs is the last thing I’ll do before gagging you. Stuffing a pair of white ankles socks in your mouth, I’ll stuff the crotch part of a pair of tights in on top of the socks, then use the legs to secure them behind your head. I’ll then pull your turtleneck up over your face, then add a scarf over it, then using another one to blindfold you. Once you and Sasha are throughly bound, I wait for you two to come to your senses.Chloe Badelaine wrote: 6 months ago 1.) How long do you wish to be tied up for?
3.) Blindfold
A.) Yes
I am not happy with this company so far! I didn’t even get a response…TuggyMale wrote: 7 months ago Hello, I Wonder if this form also can be signed be a minor. If so, I‘d like to ask for the following things:
2-D (leather)
3-C (cleave gag)
4-A (left alone)
5-B (sportswear)
Greetings
A.) Rope
A.) Tape + stuffing
3.) Blindfold
B.) No
C.) Teased
B.) Sportswear (leggings and short-sleeved top)
Sounds fun!
A.) Rope
A.) Tape + stuffing
3.) Blindfold
B.) No
C.) Teased
Sounds fun!
Well thank you for choosing our service. I love your profile pic and think it would be best if you arrived dressed as such. Let’s start by stuffing ankle socks in your mouth and taping them shut. After quickly hog tying you, I’d stuff you in a trunk of my car and drive off to a second location. After brining you inside, I’d strip you down to your bra, panties, and socks and tie you spread eagle on the bed. I’m sure I’ll find some way to spend the next three hours that we’ll both enjoy.GwenGagged wrote: 6 months ago 1.) C
2.) A
3.) C
4.) A
5.) C
6.) C
You’ve got to be careful with friends like this. You’re bound to end up like this every so often.SashaMoh wrote: 6 months agoI didn’t realize I got roped into this but I’m all about itDioA wrote: 6 months agoMon Dieu, Chloe, someone of your caliber enlisting our services is an honor. As a huge fan, I’ll also handle this one personally. Once you and our fellow friend arrive, I’ll have the both of you knocked out with sleeping gas. Not wanting to waste any time, I’m going to remove your attire you can in with and replace them with thick black tights, an off white turtleneck, red thick thigh highs, and black socks. Out friend will be dressed similarly. While you’re still out, I’ll bind your wrists, arms, knees, and ankles. Pulling a crotch rope between your legs is the last thing I’ll do before gagging you. Stuffing a pair of white ankles socks in your mouth, I’ll stuff the crotch part of a pair of tights in on top of the socks, then use the legs to secure them behind your head. I’ll then pull your turtleneck up over your face, then add a scarf over it, then using another one to blindfold you. Once you and Sasha are throughly bound, I wait for you two to come to your senses.Chloe Badelaine wrote: 6 months ago 1.) How long do you wish to be tied up for?
3.) Blindfold
A.) Yes
“You know†I whisper in your ear as you watch the show in front of you with my hand on your knee, “I haven’t told you how long you’re here going to be tied up for. With our lack of demand in the winter, I’ve decided that you’ll be here until the weather warms up. That is, unless you’re not satisfied in which case, I’ll find more rope.â€great work!
Well thank you Sara for reaching out. Let’s start by tying your arms together behind your back with a chest harness to follow. I’ll then add rope to the rest of your body, gliding down your grey leggings and naby blue top. After stuffing your mouth with a sponge, I’ll tape it shut. Then I’ll place a kiss on your forehead while we spend the next couple of hours finding ways to make you enjoy your experience.SaraInRopes wrote: 6 months ago 1.) How long do you wish to be tied up for?
A.) Rope
A.) Tape + stuffing
3.) Blindfold
B.) No
C.) Teased
Sounds fun!
Sounds wonderful thank you! I don't think I'd be getting out of that for a while so you'd have plenty of time to find something I enjoy!DioA wrote: 6 months agoWell thank you Sara for reaching out. Let’s start by tying your arms together behind your back with a chest harness to follow. I’ll then add rope to the rest of your body, gliding down your grey leggings and naby blue top. After stuffing your mouth with a sponge, I’ll tape it shut. Then I’ll place a kiss on your forehead while we spend the next couple of hours finding ways to make you enjoy your experience.SaraInRopes wrote: 6 months ago 1.) How long do you wish to be tied up for?
A.) Rope
A.) Tape + stuffing
3.) Blindfold
B.) No
C.) Teased
Sounds fun!
I’m glad we could satisfy! Feel free to reach out any time, we’d love to help you again.SaraInRopes wrote: 6 months agoSounds wonderful thank you! I don't think I'd be getting out of that for a while so you'd have plenty of time to find something I enjoy!DioA wrote: 6 months agoWell thank you Sara for reaching out. Let’s start by tying your arms together behind your back with a chest harness to follow. I’ll then add rope to the rest of your body, gliding down your grey leggings and naby blue top. After stuffing your mouth with a sponge, I’ll tape it shut. Then I’ll place a kiss on your forehead while we spend the next couple of hours finding ways to make you enjoy your experience.SaraInRopes wrote: 6 months ago 1.) How long do you wish to be tied up for?
A.) Rope
A.) Tape + stuffing
3.) Blindfold
B.) No
C.) Teased
Sounds fun!
I might just have to!DioA wrote: 6 months agoI’m glad we could satisfy! Feel free to reach out any time, we’d love to help you again.SaraInRopes wrote: 6 months agoSounds wonderful thank you! I don't think I'd be getting out of that for a while so you'd have plenty of time to find something I enjoy!DioA wrote: 6 months ago
