magicboy (Josh) : 02 - Night of a thousand tie-ups (mm/mm)
magicboy (Josh)'s stories
By magicboy (Josh)
Night of a thousand tie-ups (pt.1)
When i left off Cody and i were returning to the room to face Jack once again. Jack smiled as we arrived.
"Great work with the cleaning", he said. "Now onto the next great escape opportunity." "but first.... Brad pat them down." I gulped in fear i knew that when this big gallut patted down cody's compression shorts that he would find the scissors he had hidden there. Sure enough my fears were soon realized.....
"Well,well,well....What do we have here?", Brad smirked as he removed the scissors from cody's shorts. "You guys are so predictable"j, laughed Jack. "I warned u before that u better not try to mess me over and now you're gonna pay."
After Jack patted me down to make sure i didn't have anything hidden he revealed his next plan of attack.
"I was hopping you'd give me a reason to really stick it to u guys, and u did. now pull off those biker shorts because you're about to get tied up in your undies."
"Come on Jack!" I pleaded. "i didn't try to cheat....It was Cody!"
Cody countered...."What????....It was your idea!!!!"
Our argument was interrupted immediately by Jack.
"I don't wanna hear it!" You're both gonna get punished now take em off! NOW!"
We sighed and for the second time that day pulled the sweaty shorts down.
Ttoss em over here", he ordered.
We kicked them in his direction trying to hit him but were unsuccessful. Cody and I resembled 2 cruiserweight sumo wrestlers thanks to the perma-wedgies Jack had given us earlier and our cheeks were turning even more red by the minute as we shivered.
"Okay,okay", I said "we're in our underwear, can you at least take these wedgies out?" i pleaded. Cody seconded the notion.
"And deprive you two of getting to know each other even better with some friendly male bonding? I don't think so", he gloated. "Now joshy-poo put your hands in front of you and let me get to work."
I watched as Jack removed a roll of black duct tape from a box and tightly wrapped my wrists and hands together into a neat little ball.
"Now Cody i want you to get behind him and put your arms around him, wrists together in front of his belly."
I sighed knowing that this was gonna be just as hard to escape as the last time....maybe even worse. As Jack secured Cody's hands the same way he had mine and then duct taped or shoulders and arms separately and then together i felt his belly being pressed tighter and tighter against my back. Next the tape was wound tight over our thighs and ankles then as before we were taped together tightly. The strange thing was that he hadn't used as much tape as last time (for the most part our bodies were still revealed) but the tape he had used was seemingly more secure than before.
"And now for the final touch"...laughed Jack."I told u guys not to mess with me."
I heard the ripping of the pallet wrap and suddenly felt Cody's crotch being pressed against my wedgied butt cheeks.
"ahhhh damn!" I cursed as the clear pallet wrap travelled around my belly over and over gripping it like a second skin.
Satisfied with his work Jack secured it with a few strips of silver duct tape. This bastard had every color tape and pallet wrap in the book and was turning us into some damn picaso with them.
"Boy you too look cute, but there's still something missing...", he remarked as he were held up by Brad.
Jack snuck up from behind moments later and wrapped a white bandanna through my mouth and knotting it tightly behind my head. Then he covered it with another wide white bandanna that covered my entire mouth.
"mmmppphh!" mmmppphh!" i cried. I couldn't believe he had got me again.
"What's that?" Jack laughed. "I can't hear u joshy-poo."
"MMMMPPPPPHHH!" I screamed with all my might but all that escaped the two cloths was a muffled whisper.
As they applied tickle torture to Cody to apply his gag i tested my bonds and couldn't move anything but my hips which only made it look like Cody was humping me, which pretty much he was. Jack and company got a good laugh out of us and laid us on the bed with me face down. As Cody struggled the humping continued. I had to get out of this!!!! Or i might end up pregnant or something! I tried to let Cody know that i wasn't very comfortable when he tried to wiggle and squirm but i couldn't make a peep. I rubbed my face against the pillow and after about 30 minutes got the first cloth off then managed to twist the second one out with my tongue.
"Cody...", i whispered as i worked my sore jaw.
"MMpphh?" he answered shocked to hear my voice.
"Stop squirming dude....when you do you're humping me man".
"mmmppphhh", he answered.
"Just try to get your hands loose", i said.
"Well you're mighty chatty!" said Jack as he appeared over me.
"Don't even try!" i exclaimed. "the rules say if we get loose we can go.... you can't re-tape us if we get a part of our body loose!"
"You're right." said Jack. "But the rules don't say anything about replacing gags."
"No!", I protested but i knew he was right.
He removed the 2 bandannas from around my neck and began to roll them into a tight ball. I had seen this before. I clamped my mouth shut and felt Brad begin to tickle my feet, but somehow i fought off the laughter. I knew that if Jack got that same gag on me as last time i was done!
"Turn him over!", ordered jack. Brad did so quickly.
"Tickle him everywhere!", said Jack.
Brad started around the arms but to no avail but when he made it to my tummy, which is by far the most ticklish place on me, I was done. I giggled uncontrollably and instantly felt the ball f cloth fill my cheeks again.
"Mmpphh"!"mmmphh!", next the oh so familar strip of shiny white duct tape was pressed skin tight and pressed din place for about 2 minutes by Jack's firm grip. 3 more pieces followed until i couldn't make a sound.
"And just for insurance..", said Jack. A white bandanna was neatly folded over the tape and tied tightly over it."If u need anything just let me know josh"....he smirked.
"If u want me to let u go just tell me".
As i tried to insult him my cheeks helplessly puffed out not producing a single sound. The cloth ball and tape were enough to make a sound impossible but the cloth on top of that was just demoralizing.... I knew it was over. Later they returned and blindfolded me with another white bandanna which they then secured with more white duct tape. I had never felt so helpless in my life. I squirmed hoping to perhaps just loosen my wedgie but even that was impossible..... 2 hours later we were covered in sweat again and still squirming when they released us and told us that we would be washing the kitchen next dressed as is. I will complete the story later.
magicboy(josh)
us
