DIY tickle torture (m/self)
Posted: Fri Nov 22, 2024 8:11 pm
So I found a way to tickle myself in self bondage, I tested it and it works but is it really is too ticklish that I dont think I'd be able to do a strict session quietly?
It was around mid morning and my family was out so I'd be home alone for a good few hours at least, though I wasn't going to plan a strict tie up as I prefer night for no unexpected interruptions. I had an idea about using a fan that moves left and right moving a thin stick or feather or something/anything on me to tickle me while im tied up.
So went rummaging round the garage for various things, come across tape, this reel of white 'cable' was thin with tight spring in with white coating, i assume its maybe a washing line kinda thing, and a ton of these about 1 foot length jagged edged plastic things that can loop into itself kinda like a less secure zip ties(i could easily bust them so no good for tying really)
I went upstairs to my room and put everything on the bed with some usual tying equipment (gown cords/scarfs/belts/etc) So i have a normal desk fan, and an adjustable height pedastal fan, i had also brought a second desk fan from downstairs. I was going to cut the 'washing line?' To about 1 foot peices and attach it to the front of the fan 'cage' and have them swivvle left and right running the cables on my soles (pedestal at the foot of the bed) and 2 desk at my sides (i would figure how to secure the side fans on the bed later this was mostly a test)
The line proved too tough to cut with scissors as i found it had a tightly wound wire spring going through it, rather than go downstairs for snippers i turned my attention to all these plastic jagged thing (imagine a zip tie, but the sides are jagged, and the end the tie goes in is bigger so the jagged bits go through the slot sideways and lock in by the jagged sides to tighten) these are quite rigid and stay straight in the air when held by a tip. I ran these along my feet and sides at they tickled even though i was doing it to myself, so first to test i taped 3-4 to the front of the pedestal fan cage positions so if my feet were locked still it would run them at my toes/centre feet/sides. So I got into position put the fan at the foot of the bed, tied my ankles together with a dressing gown cord for effect and pretended my feet were locked in that position as they could be in a real session. The feeling was soft, didn't really tickle...I looked and saw the 'jagged zip ties' were kinda moving on the face of the fan as it pulled them over my feet, i needed these to be secure and be one with the fan and rigid.
I took the face cage off the fan and removed all the tape, I figured out that i could weave the ties through the diamond gaps and the jagged bits would lock it in place, so i secured some in position and put the front back on. They were all facing out from the fan now and on secure and stiff, test 2 and its instantly better and noticeable. The ties would drag along my feet back and forth and sometimes the tip would poke under my toes and drag along a particular ticklish spot on the outer sides of my feet. I could imagine my feet being tied together in place and toes to restrict any movement would be fun, especially as on certain spots i would jerk my feet out the way(as they were only tied together and not to the bed at this point)
I repeated the same thing to the face of the desk fans, took my shirt off and laid down on my back. I put the fans on my bed either side on me, pointed them downward so the ties would brush my sides/little back/stomach. As I laid back to pretend I was locked in position with the fans I turned them on and oh my, instantly i jerked as the ties brushed my sides, every stroke i was jerking around out the way(couldnt happen if i was tied down) but turns out im super ticklish on my sides and it feels legit like someone else tickling me. I tried to put up with it to see what it would be like if i was really stuck and i jerk about so much and tense up i dont know if id be able to handle it if i couldnt swerve out the way or move
I am thinking about applying this to an ice self tie up soon, but need to figure a way of securing the side fans more as they could fall over or move. Though the feet one is tickling and I still jerk out the way at spots, i think i could be quiet about it at least. But really the side fans tickle so much i actualy fear id start screaming or something lol
Il probably try this soon for sure with the feet, but if i choose to go with tie side fans (il prob secure them to the bed with rope around their bases and the bed frame) I will probably go with minimal ice in a sock, and a good gag
After figuring that the tickling fans worked, i moved the desk fans off the bed(chicken). I thought id have a quick light tie up while I was home alone still. I tied my still tied together ankles to the middle of the bottom of the bed around a metal centre 'slat?' And tied my legs together above the knees. I used two shoelaces tied together to tie my big toes together snuggly and the tied them to my knee tie so it pulled my feet back and taut. I positioned the fan in place, tested and yeah that is for real ticklish. I didn't want a enescapable tie right now as i wouldn't have that long, so i just put a beanie hat over my eyes, tied a scarf around on top over my eyes again. Leaned forward turned the fan on and shimmied back up high to pull my legs straight. Reached for a dressing gowncord and just did double ended larks head knots to tie my hands behind my back. The feelings the tickling gave was really like someone tickling me, sometimes the ties would bend as they ran along my feet jagged side or a tip, and slide or poke between toes or just be a little random. I enjoyed myself a little then untied myself, took all the ties off the fans and added them to my tie up collection.
So i think i will using this in my future tie ups, maybe one on each foot if they are to the corners, but the side tickling from the fans is too much and im not sure id be able to go through with it. Or i would maybe wake my parents with violent jerking or it probably even could force a squeal if i was unable to move
part of the reason is i think the feet tickle is kinda off and on and each foot, while the sides there was always a tickle from above my hips to near my armpit and practically constant contact. So i don't get enough seconds to untense or relax.
