skybird137 : 01 - Cassidy's Kidnapping (FFF/F)
“KÇŽodÇŽ, KÇ’ngbù, I require your assistance in helping to prepare our entertaining captive so that she will be able to walk around the warehouse.†The helpless lady looked on as Madam SÇwáng’s two catsuited assistants walked over to where she was standing, while she tried to maintain her balance, and they turned to face her with KÇŽodÇŽ on the right.
Are you planning to inflict some dire new torment onto my body? The spot between my legs has become so sensitive that it is already torturing me to a degree that I had never thought possible, so I don’t see how you can make it any worse.
“Ladies, if you would be so kind as to take hold of the ankles of our helpless victim, then I will remove the bonds that hold her legs together.†As the immobilised prisoner looked down, each of the younger collaborators went down on their knees and grasped one of her ankles, just above the rope that bound the bottom of her legs together while the leader who was facing her bent over. It didn’t take long for Madam SÇwáng’s skilful hands to remove the ropes that bound the captive’s legs together, and she untied the mid-thigh cords before moving onto the ropes above and below the knees with the ankle cord being the last to be removed. After these cords were coiled up and placed on the floor, the madam straightened up so that she could put her arms around the waist of the bound lady before her, with the hug being very firm.
“While I am holding up Cassandra, each of you will pull the ankle that you are holding out to your side so that it is just over eighteen inches away from underneath her body.†There was a shuffling sound as the two women moved backwards on their knees, and the helpless woman ended up experiencing two disconcerting feelings in the process. One was that her feet were moved wide apart to an extent that she had never spread them before, and the other was that she was suspended in the air with only her captor supporting her around her waist.
I feel like the wishbone of a turkey, and two children are planning to make a wish by pulling me apart. I hope that this doesn’t end up hurting me in some way, but I doubt that you would want to do that to me now that the situation has changed.
“I will enable our helpless prisoner to be able to stand on the floor now, but you two must remain in position with her ankles held after I have let go of her.†Madam SÇwáng said, and the bound woman was lowered to a point at which the soles of her boots touched the floor, with the hug around her body being released just a few moments later. Although the captive did her best to see what the madam was doing as the leader walked around the restrained woman, her arms behind her head prevented her from seeing anything until the madam returned with the second bag which was long and thin.
Knowing my luck, there is a horrible torture device inside the bag and you are going to use it on my legs in some way. No, No, NO! Even though what was inside was not what could be described as an implement of torture, the item appeared to be so when the woman pulled it out of the long bag. It was a three feet long piece of bamboo which had a diameter of two inches, and there were three large holes drilled through it, one at each end and one in the middle of the pole, with Cassidy having seen something similar to this on the internet. It’s a spreader bar! It’s not enough to have me tied up like this at the moment, you are going to force me to walk around with my legs apart as if I’m some disreputable lady of the night who is ready for work.
“The four ropes that I have removed from our captive’s legs should be sufficient for this stage of her torment.†Madam SÇwáng said as she laid the pole so that it was lengthwise between the legs of the defenceless lady, before double stranding two of the ropes which were each threaded through one of the end eyelets, until there were two equal lengths sticking out from either side of the hole. After the improvised spreader bar had been prepared, the madam picked up the end by Cassidy’s right foot and wrapped the cord ends several times around the prisoner’s right ankle in opposite directions with the ends being tied off with a secure knot. It didn’t take long for the other end of the pole to be bound to the captive’s left ankle in the same way, and the helpless woman was starting to feel very vulnerable with the tenderest part of her body almost being on view.
I can’t even pull my legs together now that I am tied like this. How am I supposed to move around, as I am unable to even hop with my feet wide apart?
“Thank you ladies, you can go now and make further arrangements for later while I get Cassandra ready for a nice little walk.†After the leader had spoken, she picked up the other two coils of blue rope and went around to the back of the captive while the aides walked away to another part of the warehouse.
I’m already tied up enough at the moment, so what can you possibly do to add to my present discomfort? As Cassidy looked down, she noticed that the end of one of the blue ropes was threaded through the centre hole of the bamboo post with it tied into place and a few seconds later, she couldn’t avoid crying out as the crotch rope pressed harder against her body. You must have tied the other end to the rope running between my legs, which means that more torment will be inflicted on me when I try to walk anywhere. It’s almost like an arrow, pointing to where my most teased location is. Madam SÇwáng walked back around to the front of the prisoner, and she tied one end of the final cord to the top of the vertical part of the crotch-rope which was just below the waist loop before uncoiling the rest of the cord as she stepped back. That will make me feel even worse if you tug hard on the other end, which means that you will use this on me as an incentive for me to move.
“The rope that runs from the centre of the bar is tied to the vertical part of the crotch-rope above your waist loop at the back, so it should provide you with a few interesting sensations as you move around. Walking will require a little practice, but you should be able to get used to it after a few minutes. Lift one foot up, swing it around in a little arc so that it ends up being further forward than your other foot, and then place it back down. You won’t lose your balance if you move your foot quickly, so there will be no problems in remaining upright. However, if you decide not to move, then this will happen.†There was a hard pull on the rope held by the leader, which caused her captive to shriek as the rope bit against the area of the body that was so sensitive that the feeling was best described as excruciating.
I wonder what is going to cause me the most suffering, walking around with my new bondage, or having you play ‘tug of love’ with me when you pull on the rope. At the moment, I feel as though I’m some kind of love slave being made to suffer an erotic torment at the hands of my mistress. What am I thinking? That’s exactly what is happening to me right now. Cassidy realised that if she made no attempt to move, her captor would again provide more suffering in the form of another sharp pull of the rope which cause her place of heat to be rubbed, so she decided to take a step forward. This is going to be harder than you said, as my mobility is extremely limited in this bondage and I have never done this before. When the captive made her first try at lifting her right foot up, she ended up underestimating the amount of effort needed, and it felt to her as if her boot was glued to the floor.
Cassidy’s second attempt was successful in raising her foot into the air a little way, but she was only able to move her leg forward a few inches before her foot had to be put back down, and this made her yelp when the rope between her legs was pulled tight. Her left foot moved further forward by six inches, as she understood how much effort was needed, but the biting of the cord into her body again elicited an audible response from the helpless woman when the foot landed. The torment to my body isn’t as bad as SÇwáng pulling me along, but it takes a lot of effort to move forward and I wonder how long it will be before I will be too drained to make any more steps. As the bound woman pondered her current predicament, she ended up shouting out through her gag as her captor gave the leading rope another sharp tug.
“I would advise you to start moving, if you don’t want to experience another little piece of persuasion.â€
This was more than enough encouragement for Cassidy to walk forward as best she could, and she was surprised at the fact that it didn’t take long for her to feel more confident in her actions. She followed the madam for quite some time around the warehouse, but there were periods when she had to stop for a few minutes so that she could get her strength back, and it appeared that her captor did allow her a decent leeway before tugging on the rope to make her start again. However, even these short periods did not provide her with enough recovery to maintain her efforts over a long time, and the captive found herself standing with her back to one of the pillars when her captor released her grip on the rope.
“You can rest for a while after you do one more thing. Keep your back to this column while looking at the next. If you can do that, I won’t make you walk far after your long break. It will just be up to that column and back here.†The woman noticed that she only had to move a little to the right to achieve this, and she soon found herself facing a second column with the first one right behind her. “I’ll be back in about ten minutes, so just rest and conserve your energy.†Although Cassidy did her best to see where the madam was going to, she was unable to turn her head enough to keep the woman in view for more than a few seconds.
I really doubt that this is for my own good, as this session so far has been turned into one long act of erotic torture, so I think that you have more of the same planned for me. I just wish that you would allow me that moment of sweet bliss before we continue with this, but that is not going to happen until we are in a private situation again. How are you going to make my torment any worse, as you have already made my crotch rope so tight. As Cassidy stood there, waiting for Madam SÇwáng to return, she felt the strength increase in her legs, and the captive realised why she had been allowed this time to recuperate. Just walking back and forth would not be too difficult, even without a rest, so it is not just about that. There’s going to be something else, and this is going to require me to have more energy to perform. Wait, what’s happening? There was a brief moment of panic from the helpless lady as a strip of cloth was taken around her face from behind her which covered her eyes, but when the ends were tied together at the back of her head she realised that she had been blindfolded.
“This will be removed in a few minutes, but we want to prepare your new surprise first.†Madam SÇwáng said, and Cassidy could feel the removal of the cord that had been used to lead her around the room. There was a sound in front of the helpless lady that she had trouble recognising, but it appeared to be noise made by a length of rope as it was dragged across the floor. This was followed by a fumbling which may be connected to the column that she had been facing, and she was surprised by what felt like a thick piece of rope being feed between her legs before there was more fumbling behind her.
I can’t see how another length of rope is going to make any difference to my torment, as the one pulled between my legs affects me so much anyway. It’s not going to be much of an addition to my torment if I just have to walk forward and back with this rope touching me. After a few more seconds had passed, Cassidy yelped as this rope also started to press against the part of her body that had been tormenting her for some time, and the fumbling ended which suggested that the rope tying had been completed.
“Now my slave, let me show you what you are going to do next.†The leader said as she removed the blindfold from the face of the helpless lady, who let out a shriek when she opened her eyes and saw what was prepared in front of her.
You’ve stranded a long rope so that there are four parts instead of one, and there are a series of five large knots put into the length! As the bound woman looked to her sides, she could see that the two assistants had taken position on either side of her with Kǎodǎ on her right.
“Your task is simple Cassandra, as you only have to walk to the next column, and then walk backwards to the one you are at. If you stop just before a knot, and refuse to go over it, my assistants are instructed to remove your bikini bra. Should you still continue to stay still, your briefs will be taken off as well and you will be forced to move forward. It might be a good idea if you started to walk forward, before my aides decide that you are taking too much time.â€
Those knots are huge! With the way that my ankles are bound, I won’t be able to move over them, and they will press into me worse than any strand of rope. If I don’t move, I will be stripped naked and forced against them anyway! You have found a way of making things much worse for me, and I have no choice but to make the attempt. Cassidy began to whimper when the cord rubbed against her as she started to move forward at a slow rate, which was the maximum speed permitted by the spreader bar, and soon she was just before the first knot. This is going to be horrific, as the previous teasing has left me so vulnerable between my legs, but I have to try.
As the helpless woman pressed the front of her body against the knot, she bit hard into her gag while her face changed into a grimace, but once she had managed to force herself to be above the knot, the feeling became too much for her and the lady threw her head back as she screamed. After Cassidy made one more step forward, she was able to move past the knot and the feeling subsided back to being tormenting. If this is bad enough now, how is it going to be when I have had to move over all of them. When the tormented lady reached the second knot, she was already dreading what it was going to do to her, and she cried out even louder as she forced herself over the obstacle that tortured her more than the first one. By the time that the prisoner had made her way to the third knot, she was starting to sob as she knew that the torment would only get worse with each new encounter. Her sobbing grew in strength after she had passed the third knot, and her eyes started to well up as she approached the fourth knot in the sequence of torments on the rope. Cassidy managed to get over this but she spent so long waiting before the final forward hurdle, that the two accomplices stepped closer to her with them reaching out to her bra. This was more than enough encouragement for the captive to push herself over the final knot.
I’ve managed to get to the end, but this has been sheer torture for me. The worst part of this is that I have only gone half way, and I have to walk backwards over the knots which will make this even more difficult. Again, I have no choice but to do this, and if I don’t move now, I could find myself having to do it naked.
As the helpless lady took a step back, she could feel the knot press against her bare bottom and this caused her to experience a new and rather unpleasant sensation as she cried out while forcing herself over the tormenting section of rope. Even though Cassidy discovered that reversing over the knots was almost as bad as when she moved forward, at least her sensitive front didn’t add to the erotic torture. However, the new sensation was bad enough that it had a major effect on the suffering captive and by the time she finished the tears were rolling down her face at the additional humiliation that she had to endure. I just hope that you don’t force me to go through this torture for a second time.
“You have done well Cassandra, some other ladies have ended up having to do this naked, but you managed to hold onto your nerve. I’m quite impressed, and I think that you need to have a nice rest on the floor.â€
I doubt that it is going to be that easy, and you will use this as another way to make me suffer...
The leader went behind the defenceless Cassidy, there was a fumbling sound and the bound woman breathed a sigh of relief a few seconds later when the pressure from the knotted rope against her body ended. It wasn’t long before Madam SÇwáng pulled the improvised torture device back through the helpless lady’s legs, and coiled it up at the bottom of the opposing column before turning to her assistants.
“I am going to have a rest for a little while, so I would like you two ensure that Cassandra can get some decent rest as well before long. I will see you again before too long, in order to continue the entertainment of our captive.â€
Before the bound victim even had a chance to protest at this decision, the lady who had arranged her kidnapping was already walking to the rooms which were used by Cassidy’s captors. The prisoner did her best to call for the madam to come back as she was more than a little worried about her situation, but she realised that either she was being ignored or the gag was sufficient to muffle her cries for help. You can’t leave me hear like this, Madam SÇwáng, I am in greater danger from these two now that you have walked away. As Cassidy looked back towards the two accomplices who were now in charge of her, the worry grew into a state of anxiety when she saw the malevolent smiles on their faces. You two are going to take full advantage of her absence and I am going to suffer as a result.
“KÇŽodÇŽ.†KÇ’ngbù said as she walked closer so that she was in front of the helpless lady “That rope from the bar must be causing poor Cassandra quite a bit of inconvenience. Perhaps you should untie the cord from her back so that she can be more comfortable when she moves.†Cassidy looked on as KÇŽodÇŽ went around to behind her back and while there were touches at the back of her waist, she noticed that the smile of the captor in front of her had warmed, making her think that she had jumped to conclusions about how they would react. “We want you to be able to walk with less difficulty, so you can go to a place where you can rest on the floor. KÇŽodÇŽ, have you finished untying the end of the rope so Cassandra can be taken to the suitable location?â€
“Yes KÇ’ngbù, I had finished while you were talking to our captive.â€
“In that case Cassandra, you can follow me so that we can carry out the instructions that were given to us by our Madam.†Kǒngbù said before turning around and taking very small steps away from the bound woman, so Cassidy decided to start walking after her captor in her own unusual way.
I really must not let my imagination run away with me, as this is much better now that I don’t have that cord from the bar pulling on my crotch rope. Things have changed since Madam SÇwáng’s momentary breakdown, and I should have realised that the sisters would not be the same after- NO!
As Cassidy took step after step, she was getting comfortable with the way that she was moving forward and this was the reason that the surprise was complete when the bar became immobilised while she was half way through moving her right foot. Because Cassidy’s body continued to move forward when the pole came to a halt, she started to topple in the direction that she had been moving and the tied up lady was in a state of sheer horror. Not only was Cassidy unable to do anything to prevent herself from falling, but the way that her arms were locked behind her face ensured that she couldn’t turn her head, which meant that her face would smash against the hard concrete floor.
A scream of terror escaped the woman’s gagged mouth, which was the only reaction available to her as she started to tip over, and she knew that a horrific fate awaited her within a second of her crying out. However, within a moment of the helpless lady’s scream, arms went around her body as Kǒngbù reacted with a speed that was amazing, and the prisoner sobbed a little as her fall was halted.
“KÇŽodÇŽ, that was a very mean trick to tie the other end of the rope to the ring at the bottom of the column.†KÇ’ngbù said, lifting the terrified Cassidy up so that she could stand on her own two wide apart feet. “The poor lady could have broken her nose if I hadn’t caught her. Untie the rope and put the end on Cassandra’s waist cord so that we can be on our way.â€
You could have caused me a terrible injury, Kǎodǎ, and I am so very thankful that you sister managed to save me in time. Cassidy could here noise behind her for a few seconds which she presumed was the end of the rope being untied, and something was tucked into her waist rope at the back. At least you can’t use that rope on me again.
“Follow me again, Cassandra.†KÇ’ngbù said “At least you can’t be tripped over by the bar again.â€
The kidnap victim waited for a few seconds so that she could take in a deep breath before taking a first step after the woman who saved her from falling, but it wasn’t long before the lady was managing to keep up a steady forward gait, even with the bar restricting her mobility. However, after a minute or so following Kǒngbù without any problems, the bound woman ended up shrieking as she stumbled mid-step with her nearly losing her balance in the process.
“What happened, Kǎodǎ?†Kǒngbù said, halting and turning around to look at the other two.
“Cassandra managed to trip up while trying to walk, but she was able to remain upright. I think that we can continue on though. Get moving, prisoner.†There was a slap on the bottom of the helpless woman who squealed while expressing her feeling with an indignant look on her face, but she started to walk forward so that she could avoid another such blow.
It had only taken a moment after Cassidy stumbling to work out what had happened, as she felt a hand push against her back between her shoulder blades which nearly pushed her off-balance. You did this to me, Kǎodǎ, you nearly forced me to fall face first on the floor and I have no doubt that you are going to repeat this before long. The worst part is that I have no way of letting Kǒngbù know what happened, which leaves you free to try again. Every step by the bound woman was accompanied by severe apprehension, as she wondered if this would be the time when she would be pushed again, with her crashing to the floor. Her fears proved to be well founded, when she felt the hand of the captor behind her shove against her back, and she emitted a loud yelp as she almost failed to stay standing. You monster, you are torturing me with this!
“There’s no need to worry, KÇ’ngbù, our captive appears to be getting a little clumsy. Perhaps she needs to have a few minutes rest, so I will stay here with her while you prepare where she will be on the floor.â€
No Kǒngbù! Please don’t leave me Kǎodǎ as she has gone insane! Cassidy tried to shake her head as best she could and attempted to beg through though her gag in the hope that Kǒngbù would notice, but this proved to be futile as the lady walked away. You must stay here, she’s going to push me over!
After KÇ’ngbù was out of site, her sister walked over to a grey bag and pulled out a roll of wide grey duct tape, before returning so that she could stand in front of the frightened captive. “Listen and listen well, you slut! I can see what you are trying to do to my Mothe-, my Madam, you are trying to seduce her so that you can turn her against us! There is no chance of you succeeding, especially with what I have planned for you. If I push you over now, my darling sister will know what I have done, and there is no doubt that I will get into trouble. If you cry out while falling when we are walking, she will catch and save you. Therefore, my best option is to ensure that you will be unable to scream when you do fall. After that, KÇ’ngbù will either have to support me or take equal blame.â€
You can’t be planning to make sure that I remain quiet when you smash my face in, that’s horrible! Cassidy’s eyes widened in fear as her captor unrolled a strip of tape before tearing it off the roll, but there was nothing she could do to stop the piece from being placed over her gagged mouth with it running from ear to ear. Two more lengths were separated off the roll and they were placed above and below the first one, so that her face was covered in tape from just below her nose to her chin. This means I can’t eject any saliva so that I’ll have to swallow any that I produce.
“I also know that this is not enough to keep a prisoner quiet if she really wants to make a sound, so one more extra length needs to be applied to ensure your silence.†Kǎodǎ removed a strip which was placed over the apex of the nose, and it was pressed down hard so that the captive’s nostrils became very flat.
I have to fight to even breathe in and out which means that it will be impossible for me to scream out through my nose.
“Please remember that if you try to cause any trouble, then it will be a simple matter for me to do this.†A moment later, the captive’s world became one of sheer terror when Kǎodǎ pressed a little harder on the tape, which caused the helpless lady’s nostrils to seal shut.
You’re suffocating me, I’m going to die if you don’t stop this! There was nothing that Cassidy could do but struggle in her bonds as her chest heaved while her lungs burned, but she was able to suck in much needed air a few seconds later when the tape was loosened.
“You cannot help but show how you are feeling when you are scared, so I will have to do something to prevent my sister from seeing your eyes.†One last piece of tape was torn off the roll, and it was held up to the wide eyes of the helpless woman. “You can keep your eyes open if you want, but I have heard that it can do a lot of damage if this happens, so it might be advisable for you to keep your eyes shut.†After the bound lady heard this comment, she shut her eyes as tight as she could and she felt the material press against her eyelids.
I can’t see, I can hardly breathe and at any time, this insane lady is going to push me forward so that my face will impact with the hard floor. It was impossible for the bound prisoner to do anything other than stand in place and wait for the other sister to return. When Kǒngbù comes back, she’ll realise that something is going badly wrong, and I will be saved. Relief replaced fear as the lady heard footsteps approaching, which meant that Kǒngbù was returning and the tape would soon be removed from her body.
“KÇŽodÇŽ, what have you done to Cassandra? We need to take her to the rest area.â€
.â€Our slut of a prisoner was being a whiney little bitch, so that I decided that she should be punished. Her mouth was sealed, but she continued to moan through her nose so I had to deal with that as well. After that, she gave me such evil looks that I had to cover her eyes to teach her that such behaviour comes with consequences.â€
“Well, it does seem a little extreme, but seeing as Cassandra has misbehaved then our bad lady needs to be taught a lesson in humility. Just keep an eye on her as we head to the place where she is going to rest.â€
Can’t you see what Kǎodǎ is planning? You must know that something is wrong with tape covering most of my face and the fact that I am struggling to breathe. Aren’t you going to do anything about this? You must really be that foolish.
“You should have no trouble walking behind me by listening to my voice or footprints, as I have seen others do it, so follow me now or get into trouble.†Cassidy listened to the humming noise that Kǒngbù started to make, so she knew which direction to go in and she started to make steps that were more careful than usual because of her inability to see. The lady had been fearful before, but now she was in a state of continual sheer terror as she knew that the woman behind her could push her at anytime and there was no way of alerting Kǒngbù as to her fall.
The first push came after she had taken just a few steps and even though she did her best to scream, she wasn’t able to make so much as emit a whine owing to the tape over her nose. It wasn’t enough to push her over onto her face, but judging by the lack of reaction, Kǒngbù didn’t even realise that this had happened.
This was how it went while the helpless victim continued to walk, with a shove happening to her every few steps and a few almost forcing her off her feet, but she was just about able to recover. Before long though, there was a push that was strong enough to force Cassidy forward so that she would be unable to prevent herself from falling, and she knew that there was no hope for her. However, a hand gripped the crotch rope that ran from between her legs to her hands and she was pulled back enough so that she could remain in an upright position.
You’re doing this to torture me! I cannot control what is happening to me and you are pushing me forward before pulling me back just to prolong the agony! If this continues for much longer, I’m going to end up losing my mind from the fear. Is this what you want? Do you actually want to drive me insane in the hopes that Madam SÇwáng will not show any interest in me anymore?
Every continuing moment added to the psychological anguish of the captive, and she wondered if she would be taken past her breaking point whenever she was forced off-balance by KÇŽodÇŽ, who held onto the crotch rope so that she was prevented from falling.
“KÇŽodÇŽ, what on earth are you doing to our prisoner? It looks as though you were trying to push her over. Is that you were trying to do?â€
Oh yes, I’m saved! You can put a stop to this now, Kǒngbù, please help me.
“Yes, that has been my plan from the beginning as I want to see the little whore suffer for trying to seduce our Madam. I have been making her think that she is going to fall, just so that she can be tortured by the feelings of horror.â€
“KÇŽodÇŽ, that is absolutely monstrous behaviour, we had no orders to do something like this to the poor captive. Cassandra, would you like me to put an end to this and rescue you from the terrible treatment?â€
Oh yes, rescue me from your deranged sister and put an end to my torment. Cassidy’s fear changed in a moment to relief as she heard the comment that was made by the lady, and she realised that her situation was going to improve as she did her best to nod her head. At least you are being sensible, Kǒngbù.
“Well, this is the time when you find out that I knew what KÇŽodÇŽ was doing all along, you slut! Guess what your chances of being rescued are now.â€
To say that the helpless Cassidy was stunned would be an understatement, as her relief vanished in an instant when she heard the truth of her situation. You are a part of this! Her legs were trembling as she realised that her predicament was very real and that the two ladies had been playing games with her from the start. Soon, I’m going to be pushed over, and this time there’ll be no one to break my fall!
“KÇŽodÇŽ noticed how you were affecting our moth- Madam, and she suggested that we should teach you a lesson about how trying to seduce her with your wiles will only end in a bad way for you. There are a lot of things that we would love to do to you, but our leader would get very angry with us if we did it.†A hand stroked the right cheek of the victim and she could only scream in her mind at the way that she was being treated by the two captors. “If we were to actually push you over, Madam’s wrath would be dreadful, and we would suffer for a long time. However, if you were to fall over by your own action, then she would see it as being an accident.â€
It was KÇŽodÇŽ who spoke next. “You see Cassandra, I have got a wonderful idea for making you fall to the floor by your own actions, and soon you are going to do this to yourself.â€
OMG! Madam SÇwáng, please come back!
“KÇŽodÇŽ, I do not think that Cassandra will make herself fall over, so perhaps we should think about doing something else to our captive just in case we cannot successfully encourage her.â€
“Well, I do have another idea about what we can do with our slut if she wishes to disobey us, as she should be punished for her act of rebellion. However, we should first see if this whore who is trying to seduce our madam, is worthy of redemption by following our orders.â€
You must be planning something even worse for me if I fail to obey your commands, but how can I fall forward when I know what the consequences will be when my face smashes against the floor? I just wish that I could speak to you right now and convince you that I have no intention of taking Madam SÇwáng away from you, but this gag prevents me from saying anything. The sad part is that I understand that she has been your mother ever since you were orphaned by those monsters, and the irony is that I am still sympathetic towards you even though you are torturing me.
“Now whore, it is time for you to push yourself over so that you can entertain us by your suffering. Please do so now, otherwise we may inflict a special punishment on you.†Kǒngbù said and although Cassidy attempted to move herself forward, she discovered that her own self-preservation took over when her sense of balance went past a certain point, which meant that she was unable to go any further.
I can’t do it, I just can’t do it! Can’t you see that this is impossible for me as I am just too afraid of going falling over. Please have mercy on me, and bring an end to this torment.
“KÇ’ngbù, look how bad our prisoner is by being so rebellious. I think that it is time to make her suffer for this act, and this time we will be able to justify this with our Madam as we can truly say that this is a punishment for her bad behaviour.â€
What are you planning to do to me?
KÇŽodÇŽ continued “That is the best thing as she will not be able to complain about what we are about to do this time, as she did tell us that we may deliver any correction that we see fit when she refused to obey us.â€
“So, KÇŽodÇŽ, what suitable action do you have in mind for our stupid slut?â€
“Nothing that would cause her any physical harm, but her humiliation would be far beyond anything that she has had to cope with so far. After all, just look at these four lovely locations.†Cassidy felt fingers touch her neck before they moved to half way down her back before the captive realised that hands were on either side of her hips, and after a few seconds the full horror of what was going to happen to her.
These are the places where the strings of my bikini are knotted together! OMG, you can’t be thinking of untying the bows as that will mean my clothing will fall to the floor! That’s what you are going to do to me; you are going to strip me naked in front of the entire world! There’s nothing I can do to stop you, and your leader may even accept your comments about me not following your orders.
“KÇŽodÇŽ, if our captive does not do what we ask, then we can only assume that she wants her bikini to be removed from her body. If the slut continues to behave in this manner, which knot shall we untie first?â€
“KÇ’ngbù, let’s keep that as a surprise for our helpless harlot, so that she will not be able to prepare herself for this fun. However, we should give our piece of trash one last chance to follow our instructions, so that we will be able to justify our punishment of this thing to our leader.â€
“Actually, I want to remove the tape from our captive’s lower face as I want to hear this slut scream as she hurtles towards the floor. I’m sure that her cry of fear will provide us with a lot of pleasure.â€
“Go ahead Kǒngbù,, and I am sure tht our useless bound woman will appreciate a reprieve from her punishment, however short it will be.†As Cassidy attempted to struggle in her bonds, the tape over her nose was pulled away which at least allowed her to whimper again and once the material was removed from over her mouth, the helpless lady started to beg and plead through her from her ball-gagged lips.
“Listen to the whore moan, KÇŽodÇŽ. Oh, sorry, that was not intentional but it was good. We are going to give you one last chance to follow our instructions, or face the consequences of your failure to act.â€
This time, Cassidy tried her best to lean forward in the hope that she could avoid the cruel fate that awaited her, but just like before it was her own survival instincts that prevented her from being able to what the two captors wanted. No matter how much I try, it’s something that I’m just unable to achieve, as it would be just like forcing me to jump off a cliff No, please don’t, I don’t want to be naked in front of millions of people! After a few seconds of hesitation, there were nails touching the back of the helpless woman and they seemed to move around which caused her to squirm in fear of her impending nudity. You’re going to remove my bikini top first, I’m sure of it! After all, if you remove my briefs then there is nothing more you can do to me, but by exposing my breasts you can add humiliation to humiliation. Cassidy’s worst fears were confirmed as she felt hands on either side of her neck with the fingers inching towards the spot where the top bra knot was, and she twisted her body as best she could in the hope that she could stop herself from being exposed to anyone who may be watching on their computers.
However, the captive was twisting and squirming so much in her terror that her sense of balance was ignored, with the result that the bound woman did not realise that she had lent too far forward until it was too late…
NO! NO! NOOOOOOO! There were two short shrieks from the doomed prisoner, once she realised that she was going to fall and there was nothing she could do to halt her inevitable impact with the hard floor. For a moment, it seemed to her as if she was hanging in the air as she started her long scream, and the beginning was almost in slow motion as the change was slow. However, before any time had passed, the angular change in the position of the terrified woman started to accelerate, and the image that filled her mind was that of her mangled and bloody face after her features were ruined by the fall…
In an instant, the scream of the woman stopped as her face was covered by the soft material that she had fallen onto and the first thing that she noticed was the shrieking laughter from the two ladies that had fooled her into thinking that she was going to end up with a disfigured face.
“Oh that was just so funny, KÇŽodÇŽ. Our whore was screaming all of the way down in sheer horror, even though she wasn’t going to be hurt in the process. This is just so priceless.â€
“Plus the fact that we did tell her that she was going to do this to herself, and this is exactly what happened to the stupid slut. Pretending that we were going to strip her naked in front of everyone was enough to make her forget about her situation, so that she would end up toppling over and landing face down on the very soft and thick mattress.â€
You monsters, this is what you had planned for me all along! You had no intention of causing me any injury or stripping me naked, but you wanted to make sure that this is the result. The worst part of this is that I was completely fooled by you, and everyone will have seen it. Oh no! It was at this moment that the helpless woman realised that something was very wrong about her current situation when she tried to breathe in, as the material was so soft and thick that it had moulded around her face in a perfect fit/ I can’t breathe! I CAN’T BREATHE! She started to struggle as much as she could once she understood the nature of her predicament, but given her level of bondage the best she could manage was a little squirming on top of the mattress. Help me, can’t you see that I am suffocating?
Any hope of immediate rescue of Cassidy from her peril by her captors, were dashed when she heard another bout of laughter from the two women which meant that they were taking even more pleasure in her torture.
“KÇŽodÇŽ, we forgot to take into account that the bindings of her arms prevent her from being able to turn her head. Plus, it forces her face forward so that it is buried into the mattress, which means that there is a perfect seal around that silly face of hers.â€
“KÇ’ngbù, much as this is entertaining to us, I doubt that our Madam will appreciate us allowing our prisoner to asphyxiate, so perhaps we should let her breathe. Could you be so kind as to lift her up a little?â€
By this time, Cassidy had become frantic as her chest was heaving while her lungs felt as if they were burning, and she screamed as the rope running from her wrists to her crotch was held before it was pulled up. At least her face was free from the mattress, even though her shoulder joints were on fire, but she only managed a few breaths before she was dropped back onto the mattress which meant that her face was covered again. “I am sorry KÇŽodÇŽ, but I was not able to hold our captive up for long, so we may have a problem in keeping the slut safe.â€
Please, do something! I don’t think that I can last much longer!
“Kǒngbù, just stay there and lift when I tell you to, as a dead Cassandra will be more trouble than she is worth.†There was a pause for a few seconds with the captive continuing her futile struggling while she hoped that something would happen to bring an end to her latest torture. “Lift!†A screech escaped the muffled lips of the helpless lady as the crotch rope was pulled again and her body was raised up, while it seemed as if something was moved from under her body. When the lady was lowered back onto the floor, she had never thought that she would be so grateful to feel the cold, hard concrete surface underneath her body.
There was a cry of surprise from the helpless lady as the last strip of tape was ripped away from over her eyes, and she blinked for a few times before her eyes adjusted to the light with her noticing that one of the columns was on her left side. There was touching at her wrists which was followed a few seconds later by the loosening of the tension of the rope that ran between the prisoner’s legs, but this brought her attention back to the ache that was at the centre of her erotic torment.
“What should we do with our helpless whore, KÇ’ngbù? After all, we want to do something different to her concerning her restraints.â€
“Perhaps we should make our tart a bit more highly strung and make sure that she remains tense. I think that I have an idea for this if you will help with the pulling.â€
Can’t you just let me rest for a little while? After all, I would have thought you two would have had your fill of tormenting me at the moment. She noticed that someone’s fingers were at the back of her waist for a second before they went up to her hands and a cord was taken between her arms above her wrist ropes. Why are you putting the crotch rope back on me? You did remove it in the first- no! As the cord was pulled harder, Cassidy discovered that it wasn’t the crotch rope as her feet were lifted off the floor and soon her knees were bent at an angle which caused a strong discomfort to the defenceless woman. The rope that’s tied to the middle of the bamboo pole, that’s what you have pulled around my wrists! If you pull any harder, it’s going to cause me some major problems.
It wasn’t long before the rope was pulled tighter and the bound woman cried out as the limbs at her hips and shoulders were forced back, which started the aching in her joints. Soon the tension in the rope increased and the aching become more severe until it felt as if a flame had been lit in her hips and shoulders, with the woman moaning from the torment. One more quick pull on the cord elicited a scream from the captive and there was more touching at her hands which she thought might have been the rope being tied off. This is horrible! My arms and legs are stretched again, and this time my knees are in torment because my lower legs are at an angle, as well as being pulled back.
“KÇŽodÇŽ, I think that we have got our kidnap victim well and truly tensed with that rope, but what shall we do with the crotch rope?â€
“I have got a good idea for that, seeing as we have a rope running through the upper ring on this pillar. This can be put to good use for adding an extra torment to this harlot of ours.â€
Aren’t you two ever satisfied? It’s already bad enough with my limbs bent in this way, and now you two want to add more to this.
“I will just tie one end of this rope to the crotch rope of this helpless lady and then pull on the other end.†Cassidy yelped as the cord between her legs became tight again and the pressure increased as Kǎodǎ pulled on the rope so that it became a torment to the prisoner. “That knot should hold it in place. Now let’s see if we can have some fun using this rope.†A moment later, the bound lady heard a twanging sound which caused the flame of her desire to be fuelled, when the crotch rope vibrated against the most sensitive area of her body.
Oh shit! This feeling between my legs was just starting to die down when you did this to me, and my suffering is going to start all over again. Twang after twang was heard as the captors flicked their fingers against the taught rope and soon Cassidy started to moan as the feeling of lust between her legs grew stronger. As the new teasing continued, a fresh suffering started as the woman started to writhe as a result of the heat between her legs and she started to cry out in pain as well with the extra strain added to her joints as a result.
At least you can’t make this torture any worse for me than it already is.
“I do not think that we can do any more to our slut of a slave at the moment, KÇ’ngbù. Cassandra is already stretched as much as possible and this crotch rope cannot be made any tighter.â€
“Actually, that is why I have bound the pole to her wrists in this way, as I had an idea how to add more torture to her already strained bondage. I will whisper in your ear how to make this thing at our feet suffer even more.â€
Just when I thought that my current predicament couldn’t get any worse, you have an idea to make it more of a torture for me. There was a begging sound from the woman on the floor as she responded to the comments that were made by Kǒngbù, but her pleas were met with derisory laughter from the duo who delighted in making her captivity a misery.
“Thank you for the information, KÇ’ngbù. I notice that our whiney whore is back to her pathetic self in hoping for us to be kinder to her. Well, you useless prisoner, it is not going to work on us, and we are going to take great pleasure in teaching you how it is wrong for you to steal the affections of our Madam.â€
No, have mercy on me, I don’t want to steal your Madam from you, and that is never going to happen. I just wish that you could understand me, but even if I could speak, you two would refuse to listen, and speaking to Madam SÇwáng may very well end up making the situation worse. AAAAHH! Another scream was emitted by the woman as the fire in her hips and shoulders was converted into pure agony, and it took a moment for the pain to weaken before she could realise that her new torture had something to do with the rope between her wrists and the pole.
“You were right, KÇ’ngbù. All we have to do is press down on the tight rope with our boots and we can make the slut scream out as if she was a stuck piggy. How about it little piggy, do you want to cry out for us again?â€
As the prisoner shrieked and shrieked again, her world became one of pure torment and it was only when her captors halted for a few seconds before continuing that she wondered when it was going to end…
Seeing as Cassidy had no means of telling just how much time had passed since she had been made to fall over, she wasn’t able to work out how long it would be before the lead kidnapper would return. The two assistants were revelling in the torment that they were inflicting on the helpless lady and the captive knew that it would only be brought to an end when Madam SÇwáng entered the warehouse area. You only said that you would be gone for a little while, but it seems like you have been away for hours while I have suffered at the hands of you assistants who regard themselves as your daughters.
“KÇ’ngbù, I doubt that we have long before our Mistress returns and when that happens we will have lost control over how we can torture this whore.â€
“In that case, we should make the most of our remaining time and put this slut into something really horrible. Just listen to this idea.†Cassidy tried to get her best view of what the two sisters were doing, but her restrictions allowed her to just get the merest glimpse of Kǒngbù whispering in Kǎodǎ’s right ear, with the words being inaudible.
How can you make things worse for me than they already are? I would have thought that you two have taken this as far as it can go, but by now I should know better than to make such an assumption about what is going to happen to me. A sigh escaped the gagged lips of the helpless woman as the tension of the crotch rope decreased when it was untied from the vertical rope, but this did little to lessen the flame that was burning between her legs. There was more relief for the defenceless lady as she felt hands going over hers and the torments in her shoulders, hips and knees were reduced to a dull ache as the rope from the pole was untied from around her wrists. Although the captive knew that this period of relative comfort was only going to be temporary, she straightened her legs out as best she could, seeing as her feet were still wide apart.
“KÇŽodÇŽ, I think that the arms of our captive need to be placed in a different position for the remainder of her time like this, which will fit into my plan.â€
I knew that this moment was too good to be true and it was only so that you can make my life miserable again. I don’t know how you can put my arms in an even worse position though, as this has been as bad as that reverse prayer that I had to endure this morning. As Cassidy lay there on the floor, a pair of hands held her own hands in a harsh grip, while the cord that forced her wrists together were untied and this was followed by the rope that bound her elbows in place. Any chance of the woman being able to fight for her freedom disappeared in an instant, as her arms were pulled around to behind her back with her palms being placed together, while one of the captors still held her hands. One of the ropes was looped around her wrists a number of times with cinches added, so that it would grip tight with the material biting into her skin and the knot was tied in a place that was out of the reach of the captive’s fingers. Her elbows were pulled close together before the second rope was wrapped multiple times around the top of her forearms and the loops between her arms forced her elbows to touch, with her lower arms becoming parallel to each other.
Why have you bound my arms like this if you are planning something worse for me? After all, this is just like the way that my arms were bound when Madam SÇwáng had me become her captive superheroine and that was uncomfortable but it was hardly a torture.
“Kǒngbù, we need to get our helpless victim onto her feet to prepare her for the next part of her horrible torment.†Kǎodǎ said and the prone Cassidy was gripped around her arms and body, before she was lifted up so that she was able to stand on her feet with her back to the post that her crotch rope had been bound to. As the prisoner looked up and stared ahead, she could see Kǎodǎ threading a very long blue rope through the bottom ring of the pillar in front of her.
I wonder how that will be used on me, but you have already made me walk along with a rope between my legs pressing against me, so I can’t see how this could be made any worse- OMG, what’s that? A moan escaped from the helpless lady’s gagged lips as the crotch rope rubbed against the most intimate part of her body and she looked over her right shoulder so that she could see what was happening to her. What the captive saw came as a shock, as Kǒngbù had threaded the end of the long rope that was hanging from the top ring through the bottom ring and it was bound to the end of the crotch rope. As the captor pulled on the other end of the long rope, Cassidy felt the pressure grow between her legs and to her horror, she had to lean her body forward as her bottom was pulled away from the vertical so that she could maintain her balance. However, once the helpless woman had done this there was an increase in the pull on the crotch rope, which that she had to bend over even more and the lady knew that if she stood upright, the result would be that she would fall over onto her back.
When the lady turned her head to the right in the hope of catching a glimpse of what was occurring behind her, she saw Kǒngbù tying the long rope tight which meant that the suffering captive was stuck in this position. It was impossible for Cassidy to remain still in her new stance and each little movement altered the pressure of the rope between her legs, which sent shocks through the most sensitive part of her body. It seemed that every exhale of the woman’s breath came out as a moan as her body experienced a continual teasing from the situation that she found herself in and she hoped that this would be all that was going to happen to her. Any hopes that the prisoner had disappeared when she was approached by Kǎodǎ, who was carrying the two ends of the long rope and she started to make muffled begging sounds as one end was tied to the cord that bound her elbows together.
“You are right about doing this to the woman who would steal our Mistress’s love away from us, KÇ’ngbù and we shall teach her just how bad an idea this is.â€
There was a scream from the defenceless Cassidy as her hands were lifted a little way up into the air and when she turned her head around, she could just get a glimpse of Kǎodǎ looping the other end of the rope around her wrist bondage. Oh please, not again! As the assistant pulled harder on the free end of the rope, Cassidy was forced to bend over until her body was parallel to the floor, but this didn’t end there with her hands pulled further up into the air. There came a point where the arms of the helpless woman were almost vertical, which put a horrendous strain on her shoulder joints and she cried out in her torment when the rope was pulled tighter which forced her to bend over even more. When the free end of the rope was tied off, Cassidy’s head was a little closer to the floor than her waist was and her arms were off vertical with her hands above her head.
“This should be a superb strappado torture for our slut, KÇŽodÇŽ.†KÇ’ngbù said as she retied the crotch rope, so that the pressure on the captive’s most sensitive area continued to be intense. “Any movement upwards that she makes will increase the pain in her arms and it will also cause the rope between her legs to rub against her body, which will create a double torment for her.â€
I should have known better than to think that you couldn’t make the situation worse for me. It’s going to be impossible for me to keep absolutely still like this and every time that I try to move my body, it will just amplify the pain that I am already having to endure. It wasn’t long before the helpless woman discovered that she was unable to avoid moving and her involuntary actions were enough to increase the stress in her shoulders so that she shrieked in agony.
“It is such a lovely sight to see the helpless harlot torture herself, KÇ’ngbù and we should watch this for a while. After that I have an idea to make the situation of this useless woman even worse. Let me whisper it in your ear, so that we can keep it a secret from our slut.â€
How can you- aaaah! Cassidy’s train of thought vanished in an instant as her body made another uncontrolled jerk and she cried out as pain shot through the joints of her shoulders. This also made the rope press against the area between her legs and the increased feeling there had a part to play in preventing her from keeping still. These little shocks in my hips are making me move against my will and creating a situation where pleasure is being used to inflict pain on me.
Each time Cassidy ended up moving in her bonds, she caused the lustful flame between her legs to grow and this is turn made her move more often so that she was caught in a form of torturous vicious circle. Before long, her world consisted of the intense desire and need for an erotic release, along with the horrific suffering that she was forced to endure as the spasms in her pelvic area forced her to move every half minute. Cassidy was either crying out in pain as her body jerked up a little, or she was moaning because of the fire of lust as the centre of her intimacy that needed to be quenched.
“Would you like us to untie the end of the rope that is looped around your wrists?†KÇŽodÇŽ asked and Cassidy was so consumed by her current suffering that she nodded in response without thinking about how dangerous it was to answer a question like this from her two tormentors. “I will just prepare you before I untie the rope.â€
There can be nothing worse than the torture that I am going through at the moment, so go ahead. The helpless woman closed her eyes and paid no attention to what was happening, until the feeling of rope around her neck alerted her to just how much danger she was going to be in. When the lady opened her eyes, she saw that the other end of the loose rope that was bound to the middle of the bamboo pole was being wrapped twice around her neck and she was in a state of terror as the loops were tightened, before a knot was tied at the front of her neck.
Oh fuck, Oh Fuck, OH FUCK, you’re going to kill me! If you untie the rope that goes around my wrists, my body will move up and the rope around my neck will strangle me! When Cassidy realised that she was in grave peril, she shook her head and started to beg though her gag in the hope that the two captors wouldn’t untie the rope to her wrists.
“Now it is time to untie that horrible rope that is keeping you all bent over, so that you can get some relief in your arms.†Kǎodǎ said as she stood upright and put her hands on the knot that held the rope fast around the wrists of the helpless woman who was becoming more frantic with every passing second.
Oh please no, don’t untie that knot, if you do this then I am going to die!.
“What is wrong, you useless slut, first you want this rope to be untied and now you want it to remain in place? You do not get to change your mind, so I am going to unravel this little piece of rope.†Despite the fact that the captor must have known what was going to happen when the rope was released, she started to untie the end while the horrified woman watched out of the corner of her eye. There was a scream from the captive when the last part of the knot was undone, as she expected her body to lift up, but she was very surprised when nothing happened. You are still holding onto the end of the rope so that my arms are still held in place, but this must be so that you can torture me a little more before you carry out my execution.
“Seeing as you appear to be unable to make your mind up about what you want, I think that it would be best if the matter was left in your own hands.†KÇŽodÇŽ said and the fear stricken Cassidy felt rope being pressed against her clenched fists. “It would be a good idea for you to take hold of the rope before I let go of it, unless you would prefer something rather unfortunate to happen to you. The choice is yours, but I would advise you to make your decision very soon if you wish to keep breathing.â€
As Cassidy took hold of the rope, she gripped it as though her very life depended on it and the woman had the terrible suspicion that this was the very situation that she was facing. You monsters! Instead of killing me yourselves, you have turned me into my own executioner as I doubt that I will be able to stay like this for much longer. Her worst fears about her predicament were confirmed when Kǒngbù whispered into her ear.
“Well slut, enjoy the rest of your life, which is going to be very short. If we decided to finish you off, then everyone would see it and we would be blamed by our moth- our Mistress. This way, it can be seen as a game that went too far and your death can be written off as an accident. Mistress will be all torn up about it, but we will be there to comfort her and make sure that all of her love goes to us in the future. I suspect that your arms already becoming weak and each spasm of your body will cause your grip to loosen or even release the rope.â€
Just at this moment, Cassidy’s body jerked again due to the caress of the cord between her legs and a little length of rope slid between her fingers as she screamed in both agony and horror. Somehow, she managed not to let go of the rope altogether, but the loops around her throat became even tighter and it felt as if the cold hands of death were gripping around her neck. Oh God, all I have to do is have this happen just a few more times and I won’t even be able to breathe anymore. It’ll probably only take five minutes at the most for my life to end!
“We’ll enjoy watching your last struggles as you fight against the inevitability of your own demise and when it happens, we will pretend to go into a panic and run to our Mot- Mistress for help. Once she gets here, however, it will all be over for you as it will be too late to provide any kind of help.â€
As Cassidy turned her head to the left, she watched on in despair as the two captors walked away from her, until they had travelled about fifteen feet where they turned around and they stood there laughing at the plight of the condemned prisoner. I thought that it would have been Madam SÇwáng who was going to kill me, but it is you two that are behind it and in a way I am being made to bring an end to my own life. The feeling of horror and darkness were becoming so strong in her mind that she was wondering if it was easier just to let go of the rope so that she could put an end to this terrible insanity.
There was another involuntary movement of her body, with the improvised noose around her neck becoming tighter still as more rope escaped from her grasp and her piercing scream was accompanied by laughter from the two women who were enjoying her suffering. “That’s it slut, keep fighting against it.†KÇŽodÇŽ said “You’ve got a lot of strength in those arms of yours.â€
You are even pretending to the world that everything is okay, when you both know that I can’t hold onto this rope for much longer. I have no doubt that you two will take great joy in watching the life being choked out of me. After a few more minutes had passed, Cassidy body had moved up three more times as her arms continued to weaken and the cord was biting deep into her neck. This it is, I might as well close my eyes and wait for my life to end. Even if I don’t let go of the rope, I’m sure that the pressure of the rope will be enough to stop me from breathing, so there is no point in trying to hang on as it will be useless.
There was a long, despairing cry from the doomed woman as she felt her arms weaken further and she knew that it would be just a few seconds before her grip would loosen again, which would lead to her death...
This is the end, I’m so sorry everyone, for letting all of you down. There was a scream from the captive Cassidy as one more spasm shot through her body and her fingers were no longer strong enough to maintain a grip on the rope which escaped her grasp. As her body lifted up, her cry was cut off as the rope around her neck tightened to such a degree that it sealed off her windpipe and the victim knew that it would only take a few moments for the pressure to cause enough damage so that removing the cord would be useless. Before these few moments were up, however, there was an agonising pull on the wrists of the helpless woman, which forced her body and down and this had the result of loosening the rope around her neck, allowing her to shriek out again. Cassidy was relieved to feel the flame of torment in her shoulders as the rope was bound once again around her wrist and even the sound that escaped her lips was less unpleasant than the silence preceding it.
Oh thank goodness, you were just toying with me and you two had no intention of killing me after all. As the defenceless prisoner turn her head left before opening her eyes, she was sure that the two assistants were the ones who had put her back into a position of relative safety, but as soon as the lady saw what was happening, she was surprised to discover just who had saved her life. Madam SÇwáng! The frightened looks on the accomplices’ faces told the prisoner in a second that they had not expected this turn of events and as the captor bent down, Cassidy saw that the woman was looking worried but relieved.
“Thank goodness you are okay, Cassandra. For a second I thought that I would be too late and that your windpipe was going to be crushed. If that had happened then I don’t know what I would have-.â€
This is surprising, you actually look as though you are going to burst into tears over the idea of me dying. You really must like me if that is your response to my situation. As the captive looked on, Madam SÇwáng’s faced changed into one of anger as she straightened up and the two younger women were trembling as the leader turned around to face them.
“Just what the hell do you think you are doing! I enter the room to see you two laughing at Cassandra while she was a moment away from dying and I had to run past you two just to save her life! I would like to hear your explanation for what has been going on in here!†There was a silence from the two prisoners, which just increased the level of anger in the leader who had just prevented the helpless woman from being killed. “Come on, unless you provide me with some kind of explanation for your behaviour, then I will have to assume the worst. Well, do either of you have anything to say about this?â€
Your worst is correct, although I have no means of telling you the truth at the moment with this gag in my mouth.
It was KÇ’ngbù who started to speak first, although her speech contained a little tremor as it was clear that she was very scared “We just wanted to play a mock execution game on our captive, just like the ones you played on her when she was dressed up as a superheroine.â€
That is a lie, but I wonder if you will believe it.
“That was planned out from the start, and there was no chance of Cassandra being injured in the process. What was happening when I walked in was so dangerous that it was obvious that the end result would kill Cassandra. I had just managed to get just behind you when the rope slipped from her fingers and both of you were just standing there instead of trying to help her. If I had arrived on the scene just a few seconds later, our captive would be a corpse right about now!â€
“We are sorry.†KÇŽodÇŽ said “We were caught by surprise as we expected the prisoner to hold onto the rope for a lot longer. It was just that KÇ’ngbù and I were getting very imaginative with the ropework and both of us got carried away with putting our prisoner in something new.â€
“In any case, what you two did was very dangerous, reckless and almost ended up in the death of our kidnap victim. Do either of you disagree with this?†Both of the assistants shook their heads at this comment as they knew that trying to convince Madam SÇwáng otherwise would be impossible. “Good. Now, I want to ensure that you two will think about how you place Cassandra in bondage for the remainder of her captivity and that there is going to be no physical danger to her in the future.â€
“KÇ’ngbù, KÇŽodÇŽ, if you want to convince me that your intentions were not to kill our prisoner, then you must swear on my life that you will not take any action that will cause Cassandra any physical damage from now on. If you do so, then I will let this incident pass.â€
There was silence from the two ladies for a second, but this was broken by Kǎodǎ saying “I swear on your life that I will not take any action that will cause any physical damage to Cassandra, nor will I by inaction permit physical harm to come to her should anyone here put her in such a position.†A few seconds later, this was repeated by Kǒngbù and it was clear to Cassidy that the Madam had accepted their promises as her stance relaxed.
“Good, now that you two have given your word concerning this situation, the matter can be considered over. Now, seeing as time is moving on, I would like you to prepare meals for everyone and I will take Cassandra back to her room so that she can rest and eat, before her getting changed so that she can be placed in her final restraints of the night.â€
As the girls walked away so that they could enter the office part of the building, Madam SÇwáng set about untying the other end of the rope that was wound around Cassidy’s neck and it only took a few seconds for the cord to be freed from the middle of the bamboo pole. “That should top you form being strangled while I release your from the rest of this death trap.†Madam SÇwáng said in a quiet voice. “I will talk with you about this, once you are in the changing room and have rested for a little while.â€
Even though you have told your assistants that the matter is over, you still want to discuss the incident with me, which indicates that you are not happy with what has happened. Once Madam SÇwáng removed the long rope that was bound to the captive’s wrists and elbows, the lady was able to move her body up without any risk of being strangled by the rope around her neck. However, Cassidy discovered that she could only lift her torso up only so far, before the rope between her legs pressed deep into her most sensitive flesh and this caused her to emit a long moan of pleasure as she felt just how intense the area was between her legs. This sensation lessened a little as the other end of the crotch rope was untied from the column, which also allowed the kidnap victim to stand upright.
“It is time to remove that horrible pole from between your legs as you must be fed up with being forced into such an obscene and open position.†Madam said as she started to untie the cord that restrained Cassidy’s right ankle to the pole and this allowed the captive to put her legs together while her left ankle was freed from the length of bamboo. As the leader went retrieved the blue bag with the rope in, Cassidy remained in place as she didn’t want to do anything that would cause her kidnapper to become angry with her in any way. When Madam SÇwáng returned, she took two lengths of blue rope out from the bag before coiling up the other free ropes which were placed inside the bag.
I think that my legs are to be bound together for my journey back to the changing room. As the captive looked down, Madam SÇwáng was already wrapping the first of the two ropes around the prisoner’s ankles and it was taken around her legs ten times before four cinches were applied, which tightened the rope so that it gripped against her boots. Once the ends of the first rope were knotted together, the second was looped around her knees about eight times and four cinches were used to ensure that the rope would hold fast.
“That should hold your legs together for your trip back to the changing room.†The leader said as she walked around to behind to back of the bound lady. “Now, if you would be so good as to bend your knees a little, I can add the final preparation for the journey back.â€
Cassidy responded without thinking about the order as she had become accustomed to obeying Madam SÇwáng, and even the feeding of rope between her lower arms didn’t give her any cause for concern. I doubt that this is going to alter what is happening to me in any way- AAAAAH! There was a loud cry from the gagged lips of the prisoner when she realised what was happening to her, as the crotch rope pressed hard against her flesh while the other end was knotted off at her ankles.
“That is good, as you are ready to follow me.†Madam SÇwáng said as she walked around to the front of the defenceless damsel, before picking up the end of the rope that was bound to the captive’s neck and tugging on it like a leash. “Follow me.â€
Oh please no, not like this. Although the prisoner wondered about putting on an act of defiance, the feeling inside her suggested that her captor would make good use of the present situation, so she straightened up before making a single hop forward. Cassidy couldn’t help but scream as the rope pressed deep into her intimacy and as hop followed hop her cries increased in volume as the only thing she could think was the erotic torture that was being inflicted on her. By the time she entered the changing room, the raging inferno that burned between her legs consumed all of her attention, as she need the release that could only be provided by an explosion of ecstasy.
“I am going to leave you for a little while and I will return with your meal.†Madam said as she placed her right hand on the door handle.
Oh no, please, you must do something about the flame that is raging within me. I don’t think that I can take this torment any longer. As the helpless woman stood there in the her sensual torture, she decided that she had no choice but to beg and plead as much as she could in the hope that the Madam would give her what she needed.
“Cass, I am sorry, but I told you that I promised not to lay a hand on any personal part of your body, and I will not act in defiance of that.†This response created such a feeling of despair in the helpless woman because she was unable to do anything about relieving her condition, that she started to cry with the tears running down her face. “Please Cass, I promised that I wouldn’t touch you in those places and I have to keep to that. If there was any other way that I could help you then I would.â€
There is a way, but you must have forgotten about it. I can’t speak to you with this gag in my mouth, so the only way I can get this message across is to show you. Cassidy shuffled around on the spot as fast as she could, given the limits that her restraints placed on her and she did her best to slap her bottom with her hands to get the message across to her captor.
Madam SÇwáng looked puzzled for a moment as she observed Cassidy’s behaviour, but after a few seconds the woman smiled as she realised what her prisoner was trying to communicate to her. “I remember, that is what was happening in the room with my assistants. Are you sure that you want me to do this to you?â€
There was a furious nodding from the woman in bondage as her tears halted and she hopped over to the right side of the chair in hope that her captor would help her in her need. Yes, I need this so much. Please help me!
“Okay, I will do this for you.†The kidnapper said as she sat down on the chair and the helpless captive found herself lying across the lap of the Madam who was pressing her right hand down against the prisoner’s back. As the captor started to spank the helpless lady with her right hand, the restrained woman cried out in pleasure as each jolt to her body took her one step closer to the ecstatic release that she would receive...
Cassidy was still in a state of reverie which meant that she was just about aware of the crotch rope being removed from her body and she was sitting on the lap of her captor who was cuddling her and placing sweet kisses on her face and neck. This situation continued until KÇŽodÇŽ came in with a large plate of sweet and sour chicken along with a bottle of water which was handed to the Madam who put it to one side before removing the large gag. Once the two women were alone again, Madam SÇwáng picked up the plate, but before she started to feed her captive she asked a question.
“Did my assistants try to kill you?â€
I’m going to have to tell them the truth about what happened, and I am sure that you may have further questions, so it would be better for me to volunteer further information first. “Yes, KÇ’ngbù told me herself that the idea was for me to end up being strangled by the cord around my neck once I lost my hold on the other rope. I think that they have noticed how you have been behaving towards me and they are terrified that this means that your feelings towards me will mean that you don’t love them anymore.â€
“Cass, that is crazy. These are two grown women, although they have not long become adults, and that is no way for a woman to behave.â€
“Madam SÇwáng, physically they are adults, but underneath they are the same frightened and emotionally scarred children that you rescued. This is something that you have to remember, as they must have reverted to that point in their lives.â€
“Maybe having them help me with this was a bad idea, but I never expected it to turn out the way that it has. At least they have given their word on my life not to hurt you and they would rather die than break this promise, so you are safe from them. Anyway, at least I understand why they have behaved the way that they did and maybe we should just enjoy the meal.â€
As the two women shared the meal, any conversation consisted of small talk and there were sweet little kisses interspersed between bites of food along with the occasional drink of water. It felt to Cassidy that the meal was finished all too soon as she was fed the last little morsel from the plate and she enjoyed a luxurious kiss from her captor who placed her in a standing position before rising from the chair.
“I am going take the plate and bottle to the kitchen and I will be returning with your next costume and I do hope that you will enjoy it, as I have often fantasised about seeing you in it. When I bring it in, you will be freed so that you can take a break before changing your outfits and I will head towards the other rooms so that I can change into my new costume, which I hope you will like.†After the Madam spoke, she left with the plate and bottle and returned a few minutes later with a large white bag which was put by the chair, before giving the helpless lady a gentle cuddle which was accompanied by a long and very sensual kiss.
It took a few minutes for Madam SÇwáng to remove all of the ropes that restrained the captive, but once this was done Cassidy was free to take a break in the toilet before returning to the changing room, while Madam SÇwáng left to get changed. Once the woman had removed the bikini, boots and gloves, she put on the new outfit that Madam SÇwáng had left for her. This is a very sexy outfit, and I am not surprised that she wants me to wear it. The patent black stiletto shoes were complemented by the black fishnet hose that covered her legs, and her body was covered by a black satin strapless body. This was added to by the imitation shirt cuffs around her wrists along with the collar/bow tie arrangement around her neck and the white fluffy tail on her bottom fitted in with the floppy rabbit ears which were attached to her head by a band. So, I’m to end up as a bunny girl in bondage...
Cassidy’s reverie at admiring her new costume was brought to a sudden end when there were several knocks on the door and she heard Madam SÇwáng’s voice coming from outside. “Cassandra, I have left a timer outside the door, which will beep when it is time for you to leave the room. By that time everything should be ready for the last part of the evening.â€
“Okay Madam SÇwáng, I will come out when I hear the noise.†Seeing as there was nothing else to do at the moment, the captive sat down on the chair which she had positioned so that she could look at herself in the mirror and she started to run her fingers over the fishnet hose. I have nothing else to do but wait until the timer finishes, but I suppose that I should be careful in what I do at the moment, as my last torment was very erotic, but not something that I want to go through again for a while. Perhaps tomorrow afternoon or evening I will be ready to go through it again, but I don’t want the risk of being left unsatisfied all night long. After a wait of some time that Cassidy was unable to determine as there was no timepiece in the small room, there was a faint but clear beeping sound which lasted for about ten seconds which was the signal for the lady to leave the room. I wonder what restraints are in store for me this time? At least I don’t have to worry about my physical safety at the hands of KÇŽodÇŽ and KÇ’ngbù, but some of the bondage I have been through in previous scenarios has been quite severe.
There was a moment of hesitation as the prisoner took hold of the door handle, but she knew that if she didn’t leave the room of her own accord, there may be some kind of forfeit to pay as a result so the lady steadied her nerves before turning the handle and opening the door. As she peeked out through the door way, there was no one in site and she noticed that part of the warehouse had been curtained off again which seemed to indicate that alterations had been made to the areas that had been used in previous scenarios. There is still a massive area at the end of the warehouse with I haven’t seen yet, so there must be something very special in that part of the building that is being kept hidden from me, but I doubt that I should be too worried as my release has been promised for Thursday morning, However, I don’t know if I will want to be free as my desire to remain a captive of Madam SÇwáng keeps growing and at this rate, I could end up begging her to keep me prisoner.
After taking a few steps outside of her room, Cassidy still couldn’t see any of her which made her wonder if the timer had been set for the wrong time, when one of the curtains parted and the two assistants emerged into view, with each carrying a white bag. They had white shoes on their feet which were almost the same as ballet slippers and their legs were covered with white fishnet pantyhose that consisted of a very fine mesh. A white glittering long sleeved bodysuit covered their bodies up to their necks and each sleeve was kept in place by a little loop of cloth that went around the middle finger. Cassidy was sure that she had seen costumes like this somewhere before, but the woman’s more immediate concern was about what was going to happen to her, especially as the bags must hold the restraints that were going to be applied to her body.
“Oh look KÇ’ngbù, a wild bunny girl appears! Shall we add it to our collection?â€
“We must obtain such a beautiful specimen, as our Madam will be very happy with us if we can capture such a prize.â€
This is where I get placed in tight bondage again. I doubt that I will have any success in escaping your grasp as I am wearing these high heels while you are in slippers, but I am not just going to let you take me captive without putting up a fight. As the bunny girl looked around, she could see that there was a large area to her right which seemed to be clear and the lady decided that this was the best place that she could go to, so she turned to her right and ran to the area as best she could given the limitations of her heels.
“Kǎodǎ, I think that the wild bunny girl does not want to be added to our menagerie, so force is going to be necessary to control her.†Kǒngbù said as Cassidy heard the soft but rapid impacts behind her which meant that the two hunters would soon catch up with her.
“KÇ’ngbù, this creature must be tightly restrained after we capture her, because wild bunnies can be very vicious. There is a chance that she could even be as dangerous as the killer Rabbit of Caerbannog.â€
I would have thought you would have needed no excuse to tie me up, but you are just playing with me. Although the pursued lady did her best to avoid being captured, her failure was a foregone conclusion as the ladies chasing her were faster on their feet and the helpless woman was soon forced into a corner. Within moments, the woman was forced to lie face down onto the floor and her hands were pulled up hard against her shoulder blades by Kǎodǎ who was sitting astride her back. Please, not so hard, you’ll end up pulling my arms out of my sockets! Cassidy did her best to struggle against the captor who kept her on the floor, but this just resulted in her hair being held and pulled hard, which forced her head back as far as possible. Please, no, my hair will come out by the roots!
“Kǒngbù, the first thing we need to do with this wild animal is cover her eyes so that she will be more compliant.†Kǎodǎ said as she gave another sharp tug on the hair of the captive, which caused the victim to yelp in response as an intolerable strain was placed on the joints of her neck.
“I have just the item to help with this situation.†KÇ’ngbù said, pulling out two white circular objects out of her bag and it appeared to the restrained woman that they were just the right size to be placed over her eyelids. “They are adhesive so that they will stick in place over her eyes and the pads can only come off when I removed them.â€
“Can’t you use a normal blindfold on me, or a scarf? These discs look very unpleasant.†As Cassidy spoke, she did her best to try to move her head to some degree, but Kǎodǎ’s grip on her hair ensured that she remained immobilised as the two pads adhered themselves to her eyelids.
“There is a reason for this, which you will discover in a few minutes.†Kǒngbù said as she pressed once more on the pads to make certain that they were glued in place.
“I think that this vicious wild bunny girl needs some muzzling as such creatures can have very nasty teeth. Have you got anything in your bag to prevent this nasty creature from biting us?â€
“In my bag is the best device to stop this wild animal from sinking her teeth into us.†Kǒngbù said and the immobilised prisoner heard a rustling sound in front of her , which might be some kind of gag that was being retrieved from the bag.
“You don’t need to gag me, I’ll be a well behave- ULM!†At this moment, Cassidy realised why the pads had been placed other her eyes to prevent her from seeing as she would not be able to stop them from inserting the gag into her mouth. As the object was pushed further between her teeth, it felt to her as if it was a very wide bar which forced her jaw apart to its fullest extent and there seemed to be a texture to the material along with a sweet taste.
Honey, they’ve put honey on the gag. That’ll cause me to start drooling before very long. It must be some kind of bit-gag, but the ones that I have seen on the internet all have smooth surfaces. As the blindfolded woman waited, the two main straps of the gag were taken around to the back of her neck, where they were buckled to the extent that the straps started to bite into her skin. When another strap pressed down on her face on either side of her nose, along with over her head, she knew that this was not just a plain gag, but rather that it was some kind of harness gag. This was confirmed when two more straps were taken together under her chin where they were attached and there were final adjustments to the sets of straps to stop them from moving about. So, that’s why you didn’t use a standard blindfold on me, as you would have trouble removing it once my gag was in place. Are you going to keep my arms like this and tie me up so that I’m held in another reverse prayer?
“I’ll hold her arms for you, KÇŽodÇŽ, so that you can sort out her binding.†An extra set of hands gripped the victim’s arms at the wrists before the first pair released her, but KÇŽodÇŽ stayed on her back which meant that the captive had no chance of freeing herself. “It is important for you to form each of your hands into a fist shape, unless you do want your fingers to be hurt or something even worse happen to them. It is your choice if you want to take the risk.â€
I doubt that Madam SÇwáng would take any action against her assistants if I disobeyed them while I was being placed in bondage and ended up getting hurt, as she would expect me to know better. At hearing the instruction Cassidy balled up her hands into fists as she was commanded, so that whatever was going to happen to her was not going to cause any harm to her fingers. After a few seconds had passed, something was used to envelop her right hand before her left was also covered with what might be some kind of leather item. This was followed by the application of pressure around her right wrist and the same happened to the other wrist, so Cassidy surmised that any chance of removing the items would be impossible. Even my fingers are in bondage this time, although I wonder why you would go to all of this effort just to add a little extra restraint. When the captive attempted to wiggle her fingers, she discovered that apart from a very small amount of give provided by the suppleness of the leather, her digits were stuck in place.
Once the helpless woman finished testing the limits imposed by the items over her hands, her forearms were bought down her back until they were parallel to each other and each wrist was at the other arm’s elbow. There was a sensation of movement at each wrist, before a length of cord was wrapped six times around her left wrist and right elbow which had four cinches added to tighten the rope, with this being repeated at her right wrist and left elbow. Cassidy expected the next part of the restraining to be around her upper arms and chest, so she was surprised when the end of a third rope was tied to the bonds at her left wrist. This was taken around and between her forearms in a figure of eight pattern and once each pattern was completed, it was tightened so that it pressed into her flesh before another figure of eight was added. While this continued, the woman in bondage wondered just how long the rope was and the looping only stopped when it reached her right wrist, where it was tied off.
My forearms must be in a state of complete bondage, as the restraints essentially go from hand to hand and as usual I have absolutely no chance of escaping. Another rope was also wound around her in a figure of eight pattern, but this was looped around her chest and at the bottom of her upper arms ten times before the ends were tied together which left her arms bound to her body. Another rope was applied in the same way over the middle of her chest, but to Cassidy’s surprise this was not tied off, which meant that the ends were still loose. I can’t believe that you have forgotten to finish this, so there must be something else planned for me concerning this particular restraint.
“KÇ’ngbù, we can’t have this wild animal running around without using some means of control, so do you have anything that can be used to stop her from getting away?â€
“Yes, but it might be preferable if we get the feral rabbit on her feet first.â€
I can’t see a thing, so how can I even consider running away at the moment. Hands gripped the defenceless lady on her arms and body so that she could be lifted up onto her feet and the captors continued to hold the woman until she managed to steady herself. Once the captive was in a balanced position, she felt something go around her neck above the bowtie and after a few seconds, this pressed tight against her skin. Although the prisoner could not see what was attached to her by her captors, the fact that it was a band around her neck left her in no doubt at all about what had just happened. It’s a collar, you’ve stuck a collar around my neck as if I am an animal to be kept on a leash. Even though I can’t feel anything else, there must be a leash attached to it and I am about to be taken somewhere. This whole process appears to be one of dehumanisation and I can’t believe that it will end like this.
“Come this way, you animal.†As Kǎodǎ spoke, there was a sharp tug on the collar around the neck of the victim and even though the prisoner was unsure about the precise direction in which she was supposed to go, she started to take short steps towards what she approximated was the correct place. There was no correction by the captor who was holding onto the leash, so the bound woman assumed that her guess was correct and she knew that she would continue like this until it was time for her to halt.
“Stand still.â€
What are you going to do to me now? There was pressure against the pads that covered the eyes of the defenceless captive before they were peeled away and the woman blinked her eyelids for a few times before her eyes became accustomed to the light so that she could look at the full-length mirror in front of her. Even though the first thing that she noticed was the black leather collar around her neck, along with the leash that was being held by KÇŽodÇŽ, it was the gag that first surprised her. Although it was similar in most respects to a standard harness bit-gag, with the top strap holding her bunny ear band in place, the actual wide bit between the two metal rings was different from any gag that she had ever seen. The colour of the bit was orange as opposed to the standard smooth black and there were small vertical indentations going around the bit which gave it an unusual texture. One end of the bit was rounded while the other was flat with small green streamers hanging from it and this was what made Cassidy realise just what it represented.
It’s a carrot! I’m a bunny girl in tight bondage, and I have been gagged with a carrot! Once the damsel had gotten over the shock of what her gag looked like, she turned her body around so that she could see what was covering each hand and it appeared to be some kind of small leather bag with a leather strap around her wrist. This removes my hands from view, which adds to my dehumanisation. It was almost impossible to see any clear area of her lower arms as the ropework covered her skin and this only left her upper arms on view. I wonder why you haven’t tied off the second set of chest ropes, or are you waiting until I’ve had a chance to look at this first.
As Cassidy turned back around so that the front of her body was shown in the mirror, Kǒngbù took hold of the end of the leash while Kǎodǎ went around to the back of the prisoner and a moment later, the bound lady discovered why the ropes had been left untied. When Cassidy exhaled, Kǎodǎ pulled the end of the ropes so the cords were as tight as possible over the ribcage of the defenceless damsel and the ends were tied off before the captive realised what was happening. The next time she tried to inhale, the restrained lady discovered that she could only take a little breath into her body and she had to take quick, short breaths to compensate for the new restriction.
You’ve forced me to pant like a frightened animal!
“Such a helpless, frightened bunny.†KÇŽodÇŽ said as she walked around to the front of the captive and Cassidy started to become scared when her cheek was stroked in a slow manner by the assistant. “I’m sure that we can have some fun with you. After all, there is one thing that rabbits are renowned for.â€
What are you going to do to me?
“Stand still.â€
“Why are you looking so confused, Bunny?†KÇ’ngbù said “I would have thought that even you would know what bunnies are famous for and it will be interesting to see just what we can do with you.â€
Cassidy’s level of fear increased when she began to comprehend what her two captors meant and she started to wonder how she could get out of this predicament, or even if it was at all possible. You can’t injure me physically after your promise, but the only thing this has done is forced you to become more imaginative as to what you two will do to me. Your reference is to mythic rabbit sexuality which suggests that you are going to treat me in a way which will not harm my body, but will harm my mind by humiliating me. Whatever you have planned, I’m not going to just stand here and let you hurt me without putting up some kind of a fight. No! Although the bit-gag prevented the captive from speaking in an intelligible manner, the bar did nothing to stop her from shrieking when Kǎodǎ put her arms around the bunny girl in bondage.
“You are such a sexy bunny.†Kǎodǎ said as she started to move her hands up and down the back of the prisoner in a slow manner and although the helpless woman did her best not to show just uncomfortable this was making her, there was a slight shiver in response to the touch of her captor. “The poor cute bunny appears to be a little cold, even though I’m doing my best to warm her up. I can only think that I am not trying hard enough and I will have to put more effort into stopping her from getting a chill.†There was a gasp from the bound bunny girl as she felt the arms of her captor tighten around her and she cringed inside as she felt Kǎodǎ’s breasts press against her own.
Stop it, please just stop it!
“This is a wonderful idea and we should have done this earlier.†Said KÇ’ngbù “After all, there is the saying about make love, not war.†As the other sister who was holding the leash spoke, she walked around to behind the captive and the lady was hugged so tight that she could feel the sister’s front force itself her back. “This feels so good sister, I just love cuddling our cute and constrained bunny girl as it gives me such a warm feeling inside.â€
You two are doing this just because you know that I don’t want it to happen. The worst part about this is that in a way you two are Madam SÇwáng’s daughters, even though none of you comprehend it consciously. However, you can see how much your leader likes me, so in some way you know what to do in order to inflict some kind of humiliation on me. Cassidy twisted and turned her upper body as best she could, her actions were futile against the grip of the two sisters who she was sandwiched between and the only thing that she succeeded in doing was rub her body against theirs. It would have been better for me if I had just remained still.
“I think that we have ended up frightening the poor helpless bunny even more, KÇ’ngbù." KÇŽodÇŽ pulled away from the helpless captive. “Perhaps we should let our timid woodland creature have a few minutes rest before we continue.â€
“We want the restrained rabbit to like us, so I agree.†Kǒngbù said as she walked around the defenceless lady so that she could stand to the left of her companion and the prisoner noticed that the sister’s grip on the end of the leash was very loose.
If I give a harsh pull with my neck, I should be able to dislodge the leash from Kǒngbù’s hand and make a run for it, even though I will be captured in the end. The only thing to worry about is whether or not you two will make things even worse for me once I am caught and subdued. However, if you take too long before you bring me in front of your leader, she may end up becoming suspicious and bring an end to your fun. One thing is for sure, things will become worse after this break, which is just an extra tool to torment me as I stand here waiting. Cassidy knew that whichever decision she made was fraught with peril, but just doing nothing would make her predicament worse anyway, as the situation would more unpleasant in a few minutes. There is nothing to do but try, as you two are going to make me suffer anyway.
“Look at the poor little animal KÇŽodÇŽ, it’s still a little scared, even after all the love we have given her.â€
“When we start again, we will have to be even closer and work harder at taming the timid beast. I’m sure that we can soothe her all over in some very special areas in an effort to reduce her tension.â€
I really don’t have any choice as you are going to torture me in a way that won’t cause me any visible injury. My only hope is to use up time by causing you trouble and hope that I can delay you long enough that Madam SÇwáng will notice that something is wrong. After Cassidy took a deep breath so that she could steady her nerves, the defenceless woman jerked her body to the left as she turned in that direction and she didn’t even check to see if the leash had been pulled out of KÇ’ngbù’s hand before she started running, but within a moment she realised that her action had been successful. If this had failed with KÇ’ngbù continuing to hold onto the leash, I would be on the floor right now and the most likely result of that would be that I would have hurt myself in some way.
“Cassandra, you’ll pay for this! KÇŽodÇŽ, you chase after her while I get the bag.â€
“Okay KÇ’ngbù. You are going to suffer for your misbehaviour, you disobedient creature!â€
As the defenceless woman continued to run, she could hear one soft set of footsteps following behind her and they were joined by a second pair just a few seconds later which meant that both of the ladies were following her. Given what you have planned for me, I am going to suffer anyway, so there isn’t any incentive for me to remain in place or stop running. With two against one, I know that I am doomed to failure in the end anyway, but every second that delays you could prevent something horrible from happening to me. When the bound captive glanced over her right shoulder, she could see that the two women were gaining on her with Kǎodǎ closer than Kǒngbù who was carrying the equipment bag. I notice that you two seem to be focusing on me to the point that you are ignoring anything else. Perhaps I can use this to my advantage, but I’ll only have one chance at this, which I will have to time it just right and you will not make the mistake a second time as you will be more cautious from then on.
It was just a few seconds later when the woman looked behind her again for a moment and Kǒngbù was right behind her sister, with the two captors catching up so that they were close behind her. However, while Cassidy was being chased, she had changed direction a little to her left so that the next wide column was going to almost brush against the upper part of her left arm and just after she had gone past it, she made as sharp a turn to the left as possible. This action did have the effect that Cassidy was hoping for, as the two pursuers ended up changing direction so that they went straight towards the column and it was too late for them to avoid the structure. Although Kǎodǎ managed to stop just short of the pillar, she was unable to go around it because her sister was unable to stop in time and pressed her against the structure which left her unable to move.
It worked even better than I expected as you two are going to need to take a few seconds to sort themselves out before they can even think of chasing after me again, but you are not going to be fooled by this again so I have to make the most of this one opportunity. The helpless woman managed to maintain her speed as she put some distance between the her captors, but when she checked on what was happening a few seconds later, they had got themselves into a position which would allow them to chase her again and they were side by side as they set after her for a second time. You are going to catch up with me again before long, so I should aim for somewhere where I at least have a chance of getting a minimal defence. While the two ladies were starting to close the gap between themselves and the woman they were chasing, the prisoner saw that she was running straight for the wall and she realised that this would be the best place to make her stand.
If I keep away from the wall you will be able to keep on opposite sides and it will be very easy for one of you to grab me, which means that I can be overpowered in seconds. If my back is to the wall, I can at least force you to come at me from the front and this might give me a few more seconds of relative freedom before I am restrained further, with you proceeding with your humiliation. As the captive approached the wall, another glance let her know that the two women were getting close and she slowed down before turning around so that her back was pressed against the wall. Kǎodǎ and Kǒngbù also slowed down as they came closer to the woman that they were pursuing and they stopped about two yards away from the captive in bondage.
“Your attempt to escape was futile in the end, but because of your misbehaviour the situation is going to be much worse for you.†Kǎodǎ said as she moved so that she was on the right of the helpless woman while the other sister went in the other direction.
“Yes Cassandra.†KÇ’ngbù said, moving to Cassidy’s left. “We were going to only take your suffering up to a certain level, but actions like this call for a very severe punishment.â€
As if you two weren’t going to do this to me anyway. You two are trying to make me cower so that it will make your work easier, but it isn’t going to happen this time. That’s why you are staying at a distance at the moment, because it might not be so easy to charge at me while I can face you, even though my arms are bound behind my back. Although the other two ladies were apart from each other by about four feet, Cassidy did her best to monitor her captors’ actions as timing would be of the essence when one of them made their move and it was a surprise to her that she still wasn’t attacked a quarter of a minute had had passed. You are far more unsure than before as you are unable to get on both sides of me like previous captures. For the first time, you two are on the defensive.
It was Kǎodǎ who rushed forward first, but seeing as the captor gave no indication that she was going to move, the action took Kǒngbù by surprise which left them unable to act as a team. This proved to be an advantage for Cassidy at this moment as she only had to deal with one of her captors and as Kǎodǎ moved, the prisoner lifted her right leg up in an instinctual act of self defence which left her foot about mid thigh height. In previous situations, this would have been the most foolish thing that the captive had done as she would have just fallen over, but seeing as the lady had her back to the wall the circumstances were very different. As Cassidy’s leg was almost straight, Kǎodǎ ended up forcing herself against the shoe of the helpless woman because of her momentum and the stiletto heel dug deep into her muscle of her right thigh.
There was a loud scream as the captor stepped back and she collapsed on the floor just a moment later, as she held her thigh in both hands while shouting something in what seemed to be Mandarin. I can’t believe it, my arms are restrained and I’m gagged, but I actually managed to stop you in your tracks. For the next few seconds Cassidy stared in her surprise at the lady on the floor and this proved to be a mistake as it allowed Kǒngbù to move before the captive could react. It took just a second for the second captor to reach the prisoner and take hold of her around the waist, which meant what the helpless lady was unable to use this moment to run.
“Keep hold of the whore. Do not let her escape!†Kǎodǎ screamed out as she still rolled around on the floor while clutching onto her leg and Kǒngbù responded by forcing her body against the prisoner so that she was pressed against the wall.
Damn, I should have started running instead of standing here staring and now KÇ’ngbù has got a grip on me which I may not be able to escape. Cassidy struggled as much as she could given her present state of bondage and she did her best to kick at the woman who held onto her, but she was unable to land any effective blows with her feet. I might be able to force you to let go of me though and I don’t think that KÇŽodÇŽ is going to do any running for a while. If I only have one person chasing me, I may be able to prolong this for some time and Madam SÇwáng will be wondering what will be happening.
“Kǒngbù, you have to force this harlot to the floor and sit on top of her, otherwise she is going to escape!†Kǎodǎ said as she managed to sit still on the floor for the first time since her leg was hurt and Kǒngbù positioned her legs so that Cassidy was forced off her centre of balance.
It’s too late now, if I don’t let you force me to the ground with some degree of control, I am going to fall to the ground and I will probably be injured in the process. I can always continue my struggle on the floor as Kǎodǎ is still hampered with that thigh and I may be able to delay this a little longer. Knowing that she could end up getting hurt in a fall if she continued to struggle at the moment, Cassidy halted her fight and allowed herself to be made to lie face down on the floor by Kǒngbù. Once the bound woman was on the floor, however, she put up as massive a struggle as she could muster, even kicking her feet backwards and forwards as hard as she could, but the captive was unable to dislodge the woman who was sitting on her back and facing her feet.
“Thank you KÇ’ngbù, Now we can apply the first part of Cassandra’s punishment. Just hold onto her right foot and keep it in place. I doubt that I will be able to stand for a few minutes, but I can still use my hands.†Although the prisoner did her best to keep kicking with her legs, her right ankle was held in a vice-like grip as her foot was pulled towards her bottom. “Here’s a little something to punish you, whore.â€
What are you going to do to my legs? As the helpless woman was face down and Kǒngbù was in the way, the captive was unable to see what was happening but she felt something being placed right behind her knee before a rope was wrapped ten times around her right thigh and ankle. That’s a relief, I thought that whatever they put behind my knee was going to be used to torment meEE! Four cinched were applied around the rope between the thigh and ankle and when this was tightened, the steel ball that had been placed behind the captive’s knee forced so much pressure on the joint that Cassidy cried out through her bit-gag. You’ve lit a fire in my knees with this frog-tie! Once the ends of the rope were tied off, her left foot was held by Kǒngbù who pulled it so that it pressed against her cheek, before another ball was placed behind her knee and another rope was used to bind her left leg in the same way as her right, which caused her to shriek out for a second time.
“I am so looking forward to this, you piece of scum and making you suffer is going to bring me great pleasure. KÇŽodÇŽ, now that the whore’s legs are bound and she is unable to put up an effective fight, I want you to turn her around so that she is on her back, and then kneel with your legs on either side of her head while holding her shoulders down.â€
There was nothing the restrained lady could do to prevent herself from being placed onto her back by the captor and once KÇ’ngbù was in position with her hands on Cassidy’s shoulders, the captive knew that she was in a position of complete helplessness. Her fear turned into terror as KÇŽodÇŽ knelt down, placed a hand on each of her knees before forcing her legs wide apart and the look on the captor’s face left Cassidy in no doubt as to what was going to happen. “Now, your body is mine to play with.â€
No, for the love of- please NO!
The grip on the knees of the helpless woman was released as KÇŽodÇŽ leaned forward, but Cassidy found that her legs pressed against the sides of her captor in what was almost a parody of intimacy. I can see by the look on your face that you are enjoying every moment of this and I have no way of delaying you any further. I haven’t managed to cause enough time to be lost, so you will be able to violate me before Madam SÇwáng manages to intervene. As KÇŽodÇŽ leaned forward even more, the defenceless lady was unable to prevent herself from trembling when she felt the pressure of the other woman’s abdomen against her own.
“It is so delicious to feel you shake with fear, my delicious victim and I am sure that I will have enough time to plunge you into a living hell which will affect you for the rest of your time with us. There is no doubt that you will want no further contact with our Mistress once this is over, as you will be too traumatised to want to see her again.†While KÇŽodÇŽ was talking, she leaned on her elbows which were on either side of the captive who had become almost frozen at the prospect of what was going to happen to her. “If I started at your most intimate place, then I would not be able to escalate your psychological harm, so it would be best for me to first begin further up your body.†There was nothing that Cassidy could do but watch as the woman moved her hands above the captive’s breasts, with the tips of her fingers hovering above the bodysuit and the vulnerable lady begged and pleaded for mercy which she knew that she was not going to receive. “Once you are exposed, I am going to waste no time in turning your existence into one of horror and our revenge will be achieved.â€
Although Cassidy attempted to steel herself for the oncoming violation, she knew that there was no preparation that would provide any defence against the damage that was going to be inflicted on her as her captor’s hands gripped against the soft material. I wasn’t successful in slowing you two down for long enough and I will never be the same again after this. As the gripped tightened at the top of Cassidy’s bodysuit, her begging changed to quiet sobs as she knew that nothing could prevent herself from the assault and she was never going to be the same again.
“KÇŽodÇŽ, KÇ’ngbù, where are you in the factory?†Cassidy cried out in relief as she heard Madam SÇwáng’s voice booming out through a loudspeaker and even though she was unable to understand the Mandarin words that the two assistants said as they pulled back from her, it was obvious by the tone of their voices that they were a series of expletives. “Where are you two and what are you doing with Cassandra?†After a pause of a few seconds, the Madam spoke again.â€I can see all three of you on one of the cameras now and I need you two to take our prisoner to the appropriate location right away. Once she is in position, you must put the special blindfold on her before I appear before her so that she can be surprised by me in my new outfit.â€
I never thought that I would be so thankful for all of these cameras positioned all over the warehouse and I’m sure that someone must have been watching what was happening to me. It could be that one of them sent a text message over to the Madam and warned her about what her assistants were doing. There was an unmistakable expression of fury on Kǎodǎ’s face and for a moment the helpless captive thought that the assistant was going to lose control of herself with horrible consequences, before a malevolent smile appeared.
“This is only a temporary setback, you harlot, as I will think of some way to make you suffer. You are safe for the moment, but do not assume that this will last until the end of your captivity as we will get our revenge. However, seeing as our Mistress must be monitoring the feed, we will have to make sure that you are made to walk to the location without anything happening to you.â€
If my guess is correct, maybe Madam SÇwáng has already worked out what you are planning and she will be putting a stop to it. My concern is how am I going to get to where my Mistress will want me to be, are you two going to carry me there? I certainly can’t just walk there with my legs bound like this.
“KÇŽodÇŽ, I have the feeling from the comments that our Madam would like the whore to be made to move as she is, while she is being watched. It also means that we have to be very careful in what we do, as we do not want to get into trouble for doing anything to her, even though this creature deserves to be treated badly for the way that she has betrayed us.â€
“One lady before has managed to walk with her legs bound in the same way, so I am certain that Cassandra will able to do the same. The first thing that we need to do is to get this thing onto her feet so that she will be able to start moving. I will take hold of her lower torso while you grip onto her upper arms.â€
I won’t be able to stand while I am bound like this, as keeping my balance with my arms and legs bound in this particular way is going to be impossible. No, you can’t! A protesting squeal was emitted by the restrained prisoner as the two accomplices took hold of her, with each making sure that they didn’t place their hands anywhere that was intimate to the woman they were handling.
“Although we could get into trouble if we mistreat you physically in any way, our mistress knows that walking in these restraints is possible.â€Kaoada said “So, if you end up tripping or slipping while you try to move, it will be a result of your actions and nothing to do with us.â€
“Therefore, you should concentrate on making sure that your balance is firm when you are placed upright so that you do not topple over.†KÇ’ngbù said as she maintained a form hold on Cassidy’s upper arms, while the assistant worked with her sister to make sure that the bound woman was able to squat on the balls of her feet. “See, you can stand up on your feet. Personally, I would prefer it if you keep falling over as this would give us the excuse to drag you by your neck to where Madam SÇwáng wants you to be.â€
This is impossible, I’m never going to stay standing up like this and I just know that I am going to fall over if I make even the slightest movement. Once the helpless lady had been held for a few seconds in what was as close to an upright position as she was going to achieve at the moment, the captors released their grip on her. For a moment, Cassidy felt so precarious in her stance on the balls of her feet that she cried out as she was sure that she was going to topple forward onto the hard floor, but the bound woman recovered just in time so that she could remain upright. I can just about maintain my balance at the moment, but only because I am staying still in what is essentially a squatting position and it won’t be long before I am forced to move. Ooow! As the fear of falling over subsided, the retrained woman noticed the increased pain in her knees that was caused by her being on her feet, with her body forcing her upper legs down a little further. This in turn caused not only greater stress at the parts of the leg that touched the small steel ball, but the leverage effect increased the pressure on her knees which added fuel to the fire at the joints which were already tormenting the captive.
Even shifting my stance just a little alters the pressure on my legs and knees which causes me more pain, so this is going to make me suffer a lot more when I shuffle along as my muscles will start complaining before long. While Cassidy tried her best to get used to her squatting position on the balls of her feet, she watched as Kǒngbù helped Kǎodǎ get onto her feet and it was clear that the assistant needed support in order to stand up.
“I am going to find a way to make you suffer a nightmare beyond what you can imagine for doing this to me.†KÇŽodÇŽ said “We were only going to have a little fun with you, but now you deserve the worst torments that we can come up with.â€
“However, for the time being, we need to take you to where Madam SÇwáng needs you to be.†KÇ’ngbù said as she handed the bag to KÇŽodÇŽ who held it in her right hand, while the other assistant took hold of the end of the leash in her left hand before using her right arm to steady her sister. “We will have to satisfy ourselves with watching you, while your bondage causes you to suffer as you make your way to the place in the warehouse.â€
You can’t be expecting me to move anywhere like this, as I still haven’t got used to balancing while I am squatting like this. No! Cassidy found herself almost falling over when Kǒngbù tugged hard on the leather strap that was attached to the collar around her neck and it was only due to the fact that her instincts caused her right foot to move forward that stopped her from falling onto her face. However, this did not spare her from any suffering as the movement of her right leg, along with most of the weight of her body being transferred to this limb added to the strain on her bones and knee joint. This caused the helpless woman to emit a loud squeal, which was followed by another just a second later as an automatic reaction by the prisoner caused her to bring her left foot forward to make sure that she could keep her balance.
If this is what it is going to be like at the start, I am going to be in a terrible state when I finally reach the spot that Madam SÇwáng has decided on. There is no possible means of going any faster than a few inches at a time, unless I want to risk falling forward right onto my face and injuring myself. Another short step forward by Cassidy with her right foot caused the tormented captive to yelp a little, even though she did try her best not to make any noise which would show how much she was suffering. It only took the restrained woman a few steps to realise that keeping her legs in front of her was impossible and soon she was shuffling along with her knees getting further apart with each little movement forward. It won’t be long before the gap between my legs gets so wide that I will look very vulnerable and almost obscene.
To Cassidy, it appeared that any progress she was making was both slow and painful and in this case it was more than a metaphor as each little step was a jolt through her leg which caused her to cry out. As the helpless woman made her slow way forward, she wondered just how long it would be before she reached the right spot so that this particular punishment would be over. However, she also knew that when she got to the right point, there was no guarantee that this would be over as the leader may decide continue to keep her restrained like this. She might enjoy watching me in my torment, so I could be made to have my legs bound like this for a while longer.
It was impossible for Cassidy to know just how long she had been waddling forward in her squatting position, as her existence had narrowed down to one tormenting step after another and when Kǒngbù told her to keep still, it didn’t even register with her for a few seconds. When the prisoner realised what she had been told, she tried to bring her legs as close together as possible but it was as if her muscles just disobeyed her, so she just rested as best she could with her knees wide apart. I was so concentrating on putting one foot in front of the other that I didn’t even notice the white sheet in front of me until I was resting on the spot. I just hope that I won’t have to suffer like this for much longer.
“KÇŽodÇŽ, get the blindfold out and put it on the whore while I keep hold of the leash, as I do not want to give our seductress even the slightest chance of escape.†As Cassidy looked to her right, she saw KÇŽodÇŽ reach into the bag and bring out what at first seemed to be a wide brown leather buckled strap with an indentation half way along, before the bag was dropped on the floor. It was clear that KÇŽodÇŽ was able to stand unaided at this time, but as the assistant walked around to the front of the defenceless captive it showed that the captor had a very pronounced limp which meant that the kick was still affecting her. “Yes, you did hurt me that much when tried to impale my thigh with your heel.†KÇŽodÇŽ said as she lifted the wide strap up to Cassidy’s face and at this distance, the lady in bondage saw two clips above the indentation along with a pair of hinges that were spaced out from the centre. “This present situation is just a reprieve for you, but it gives me more time to consider how I am going to avenge myself.â€
I really hope that your leader works out what is going on, otherwise I am going to find my captivity turning into a living hell and the worst thing is that I know how you two are going to torture me. However, I should avoid thinking about this as I doubt that it will happen now. That is an unusual looking blindfold and it almost looks as if it is supposed to open up. One thing is certain and that is I am not going to be given any warning when this is pressed against my eyes, so it would be best if I close them now. The decision by the squatting women about shutting her eyes proved to be wise as it was a split second after she closed them that she felt the pads of the blindfold press hard against her eyelids. If I hadn’t acted quickly enough, my eyes could have been badly affected by this as I wouldn’t be able to close the lids. Cassidy could feel the straps of the blindfold going around either side of her head, until they reached the back where they were buckled together with the pressure increasing against her face. I should be thankful that you can only buckle this blindfold up to a certain point, otherwise the edges would have really bitten into my skin and that would not have been good.
Although the bound lady realised that the two assistants weren’t going to take any direct action against her, as if they did she would have ended up with her face hitting the floor, she discovered that the blindfold caused her an additional problem. Standing up straight and keeping my balance while blindfolded was one thing, but squatting in a precarious position like this is another proposition entirely as staying upright was hard enough when I could see. Now I only have my sense of balance to rely upon and I could end up falling flat on my face in I lean too far forward. This problem became a major worry for Cassidy as adjusting her stance became a constant action in the hope that she wouldn’t fall over and this meant that she was unable to rest as her movements added fuel to the fire in her knees.
After a short period of time, there was the sound of a curtain being drawn in front of the helpless woman and she sighed with relief as she knew that Madam SÇwáng must be there. “When I open up your blindfold so that you can see, you have to keep your eyes closed until I tell you to open them.†The Mistress said. “This is so that I can get into position which will allow you to look at me and see what I am wearing.â€
It is such a relief to hear your voice again, Mistress. At least I will be relatively safe while you’re around. There was an instinctual reaction by the captive when she looked up in the approximate direction where the voice was coming from and she felt what she thought was the clips above her nose being released, before there was a sensation at each temple as the pressure against her eyes disappeared. There must have been pads pressing against my lids and they are now swung out on the hinges on the blindfold, which means that I will be able to see when I am permitted to open my eyes. She listened to several hard steps against the floor, which suggested to her that Madam SÇwáng had walked away from her before a slight scuffing sound meant that the woman had turned around.
“You can open your eyes now, my cute bunny.†The Mistress said.
The first thing that Cassidy noticed when she opened her eyes were the blinkers on either side of her face which prevented her from seeing to her left or right, but after a moment the captive looked straight ahead at her kidnapper and her heart raced in response...
It seemed to Cassidy that she was drooling even more through her bit-gag as she looked at the wondrous sight of the woman whose latest costume was a metaphor for control and dominance. When the panels on the blindfold were opened, the captive was almost looking at the floor, so she first found herself staring at the boots that Madam SÇwáng was wearing. They were calf length with the material being black patent leather, the heels were four inch stilettos that went down to a point and they were secured with laces running all the way up which were wrapped around metal studs. Next were the incredible black pantyhose that consisted of a fine fishnet stitching which covered the visible part of her legs to the top of her thighs, as the woman was wearing a black satin bodysuit.
However, only the lower part of the bodysuit could be seen as the upper half was covered by what appeared to be a combination of a white waistcoat with the top of a shirt and there was even a black bow tie at the collar. Over the waistcoat was a crimson long-sleeved jacket which had a single gold button below her bust, black lapels and old-fashioned jacket tails which went down to her knees. A shiny top hat sat upon her head along with a riding crop in her right hand, which looked as if there was a short flexible whip attachment and this completed the outfit that the Madam was wearing.
I never thought that seeing someone dressed as a circus ring-mistress could be arousing, or that you could look so powerful in this type of costume. After a moment’s thought, Cassidy realised where she had seen Kǎodǎ’s and Kǒngbù’s outfits before and the captive wondered why she hadn’t worked it out when she first saw them. They are wearing trapeze artist costumes, which fits into the theme of this being a circus. However if this is true, where do I fit in? OMG, I’m the circus animal, a helpless bunny in bondage who is going to be made to perform for the viewing audience. As the helpless woman looked around, she saw that there was a barrier arranged in a large circle with two gaps, one of which she must have been taken through when her eyes were covered. It is a pity that there is no one here to see this, as it would be a great show. Wait, I’ve forgotten about the cameras showing this on the net, so the whole world could be watching. Just imagine the headlines for tomorrow “Kidnapped Cassidy constrained in costume as circus captive.†I just hope that everyone enjoys the show. When Cassidy glanced up, she saw a single trapeze with the ropes hanging from a web of cables which ensured a secure point so that it would be safe to use. There should be no problem in swinging on that trapeze, given that the base is as solid as a rock and my guess is that Kǒngbù would have no problems in using it. Kǎodǎ still seems to have a slight limp from when I buried my heel into her thigh, so she might not be ready to swing on it yet.
“So, you like what I have set up for tonight’s entertainment, my cute captive.†Madam SÇwáng’s words were accompanied by pressure against the underneath of the bound woman’s chin by the crop and the lady looked up at the face of the mistress who was in control of her. The smile on the Madam’s face was warm and genuine and the twinkle in her eyes showed that she appreciated Cassidy’s approval of her costume along with the current theme that was being played out.
As for Cassidy, having her head lifted up by the end of the crop being placed under her chin served to magnify the massive submissive feeling that was wound around her psyche like chains. To her, it was as if this one action with them in this situation added a lock to the chain that couldn’t be removed, even if Cassidy even wanted it to be and the helpless woman knew in her heart that she would always want to be a submissive in bondage to Madam SÇwáng. I know that you have planned to release me on Thursday morning, but I don’t want that to happen. I want you to keep me as your captive in bondage from now on, as I can only ever be truly happy with you.
When their eyes met, the look on Cassidy’s face became one of pure adoration and she found herself unable to turn her gaze away from the woman who had bound her heart and soul. Madam Siang also seemed transfixed at this moment, with her keeping her eyes on her prisoner and it became clear to the restrained woman that this lady had strong feelings for her as well. It was only when Kǒngbù emitted a cough that was intended to gain the attention of the Madam, that the two ladies’ cheeks blushed as they broke eye contact and the woman turned to face her assistant who handed over the end of the leash so that it was gripped in the left hand.
“Thank you Kǒngbù. I think that it is time to see how our new circus animal acts as she is paraded around the ring, but I’m sure that she will behave herself. So, my bunny in bondage, you are to walk around the ring with me so that we can complete one anti-clockwise circuit.†As the Madam turned almost ninety degrees to her left, Cassidy took her time turning to her right so that she could maintain her balance on her frogtied legs and when the helpless lady was in position she noticed that she was about two foot away from the circus ring.
At least the positioning had been done right, so I don’t have to move any closer to the edge when I start to move around the ring. Each red block is at the right height to sit down and the two assistants are already making use of the ring to rest upon. I do hope that you realise what your accomplices are planning to do to me, so that you can stop it from happening.
“Come on bunny, let’s take you around the ring so that you can be shown off to the crowd.†A sharp tug on the leash by the mistress using her left hand reminded the bunnygirl in bondage that it was time to start walking again. Each step was just as painful as before as the metal balls continued to put a severe strain on her knees, but the experience was somehow different while her mistress was in control.
Right now, it’s almost as if I am being submissive in two ways, one as your bound slave and the other as pet who has to walk alongside you on a collar and leash. This makes it wonderful to be in this situation and the strain on my legs doesn’t feel anywhere near as bad right now. Although Madam SÇwáng did take short and slow steps when she walked anti-clockwise around the ring, Cassidy was finding it hard to keep up with her and every so often, she would increase the stress on her legs to the point where she would emit an audible gasp. I hope that you are only going to make me complete just one circuit, as being made to squat like this with my legs frogtied is going to tire me out before much longer.
“We are half way around the ring and you are doing wonderfully, my bound bunny. You do look so cute with that drool running down your chin from the carrot that gags you. However, it must be more than a little uncomfortable for you, so would you like me to clean it off for you?â€
Yes please, Mistress. It can become very irritating and I have no means to remove the saliva while I am restrained like this. There was a nod from the helpless submissive in response to the question and the Madam pulled a white handkerchief from the left sleeve of her jacket, which was used to wipe the drool off the chin of the captive before it was folded up so that it could be placed back into the sleeve.
“Come along little bunny, we still have the remainder of the circuit to do and I think that it would be better for you if you finish it sooner rather than later. Taking a break now would only make you weaker and you might not be able to get back to your starting point.†There was another quick tug on the leash which meant that Cassidy would have to walk forward in the unique way that her bondage imposed on her and it was after she had taken a few more steps that the helpless lady realised just how weak her legs had become. “See, it is becoming very tiring for you, but I am sure that you will be able to get back to you began from.†It took even longer for Cassidy to get back to the part of the ring where she had began the circuit and as she took the final steps, her legs were so weak that the woman felt as if they were going to give way from underneath her at any moment.
“I am so proud of you to have made it all of the way around the ring, so perhaps you should take the strain off your legs by resting on the floor.†The Madam said as she removed the collar from around the neck of the captive, who wasted no time in dropping to her knees before taking care when she fell onto her right side. “KÇŽodÇŽ, KÇ’ngbù, it is time to tell me how you wish to attach our prisoner to the trapeze before you start on your acrobatics.â€
What? You’re going to hang me from the trapeze? That was never mentioned to me! When the helpless lady heard what was going to happen, she started to squirm in her bonds, even though the rational part of her mind was pointing out that there was no chance of escape. As she looked on, the two sisters rose from the side blocks and as they walked towards their leader it was clear that Kǎodǎ still had a slight limp with her left leg along with a visible bruise.
“With respect Madam, perhaps we should postpone the trapeze show for a little while as my sister needs a little longer to recover.†Kǒngbù said.
“What happened to KÇŽodÇŽ?†Madam SÇwáng said as she started to frown.
“We were far too aggressive in our comments towards our captive, suggesting that we would commit some very nasty acts on her which resulted in her becoming terrified of what we were going to do to our captive. At one point Cassandra became so scared that she ran away from us and this served to make us angry, so we escalated our comments.â€
It was KÇŽodÇŽ who spoke next. “We had trapped Cassandra against a wall so that she could run no further and in my haste, I rushed at her without thinking with the result that she managed to strike me in the thigh with her heel. I had been humiliated by this and we had both become very angry as a result which made the situation worse. We bound her legs so that she was frogtied and I was so angry that I managed to terrify our prisoner out of her wits. If it wasn’t for your intervention, I might have committed a most regrettable act against Cassandra. We are both sorry for our misbehaviour.â€
“I noticed both of you on the monitor with our and I did not like what I saw, so I thought it was best that I interrupted you before it was too late.†As Madam SÇwáng looked at her accomplices, her expression softened. “Seeing as the both of you volunteered the information about what you were doing and you have apologised, I can see no need to take this any further. However, that will mean a pause in our proceedings while your leg improves KÇŽodÇŽ.â€
“We do have an idea, if you permit it Madam and we have the equipment to set it up.†KÇ’ngbù said “KÇŽodÇŽ mentioned it when the operation was being prepared and we obtained the necessary items, just in case anything extra was needed. With your permission we can set up the captive for your entertainment.†KÇŽodÇŽ whispered into Madam SÇwáng’s right ear and the leader started to smile.
“If that is what you two have planned, then go ahead. It will be interesting to see how she looks once you have changed her appearance.â€
What have you two got planned for me? Kǒngbù walked over to the helpless Cassidy so that she could turn the captive onto her back, before bending over so that she could reach down and close the blinkers on the blindfold so that the prisoner was left unable to see. Not only does this make me more helpless, but the pair of you will be able to spring a surprise on me no matter how unpleasant it could be. Once the helpless lady had been robbed on her sight, she concentrated on listening to any movement but the soft shoes of her captors ensured that she wasn’t able to hear anything. As the seconds went by, Cassidy started to struggle in her bonds as she began to wonder if she had been left alone on the floor and that she would have to spend the night like this.
It was the touches against her thighs and ankles that alerted the bound lady that her captors were at work and she presumed that they must be untying the knots on the ropes that kept her legs frogtied. At least my legs won’t be tormented like this for a while, but I could end up being placed into something far worse. As the ropes were unwound from around her legs, Cassidy noticed the two assistants were acting in a synchronised manner which meant that both legs would be free at the same time. At least I don’t have to wait for my legs to be untied one at a time, so this part can be over with relatively quickly. The captive was puzzled when her legs were held in position as the last loops were undone with the ropes taken away and she was unprepared when both of her legs were straightened out at the same time which emphasised the fire in her knees, causing her to cry out. However, the helpless woman wasn’t allowed any rest as the two accomplices forced her to stand on her feet, which she managed to do although her legs were still trembling from the stress.
Once Cassidy seemed to be steady enough on her feet, there were sounds at the top of her head as if two items were removed from connecters that were acting as clips and this was followed by two identical noises which made her think that something new had been attached. Next, the lady ended up crying out from surprise as the bunny tail was removed from the clip at her bottom and another object was fastened there which tickled the back of her knees. After the prisoner was guided to a point in the ring, she was made to sit down onto a block and the black shoes were removed from her feet before it felt as if calf length boots were being put on each leg. The way that the boots are tightening around my calves must mean that they are lace-up. There must be something weird about these boots, though, as they are forcing my feet to be at a forty-five degree angle and you two must have some experience at lacing boots up like these, as you have nearly finished already.
When Cassidy’s captors had finished putting her boots on, she lowered her feet to the floor so that she could rest her legs and she was surprised to hear a metallic sound hitting concrete. These boots must have a platform of at least a few inches as the tips of my toes aren’t at floor level. Something was clipped to the metal rings on either side of her face that connected the gag in her mouth to the harness and the pull on this forced the prisoner to stand up on her unusual boots before taking a few steps forward. The sound that these boots does seem to be familiar, but where have I heard it before? Are there two leashes on my gag?
“Thank you KÇŽodÇŽ and Kngbu, you were right about how a few items have made an incredible transformation to our prisoner and I must admit that she looks wonderful like this. However, she is going to find her alteration to be quite a surprise when she gets to see what you have done to her.â€
The panels on the blindfold were pulled open by the assistants and the helpless lady noticed a mirror to her right which she looked at for a moment before letting out a shriek. Instead of the two bunny ears that had been on the headband, there were two black horse ears and a black horse tail ran down from her bottom to her knees. However, it was her new black patent leather boots that had shocked her the most, as the platform part of the boot was in the shape of a horses’ hoof and there was a metal horseshoe at the bottom. The sound was me going clip-clop, just like a horse as it trots. The blindfold might as well be my blinkers as they serve the same purpose and the harness bit-gag might is my bridle They just emphasise this new humiliation that I have been placed into and the leashes are my reigns.
I’ve been turned into a ponygirl!
To mention that Cassidy Bryce was preoccupied with her new appearance would have been an understatement of her state of mind, as she was staring so hard at herself in the mirror that she didn’t even notice the approach of her mistress who took hold of the long reins in her right hand. One sharp tug on the reins pulled the helpless lady out of her moment of extreme self inspection and she turned her ‘bridled’ head in the direction of her ring-mistress.
“I did like the idea of having you as a lovely little bunny girl in bondage, but it never occurred to me that you could be turned into a ponygirl.†Madam SÇwáng said as she stared into the eyes of her captive, whose cheeks were burning more by the second as she knew that she was going to be made to behave like an equine. “It is so sweet to see your face becoming a nice shade of crimson. I can do a lot more with you like this than I could while you were a bunny. I think it is best if I take you very slowly around the ring for a few times, so that you can get used to having these new boots on your feet and once I am happy that you are coping, you can be speeded up.â€
At least the person who made these weird boots managed to ensure that the sole is rock solid and that my lower legs are supported along with my ankles, otherwise I could end up hurting my legs. However, moving around in them could prove to be very tricky, as I’m finding a little difficult just to stand up.
“Come on my lovely horsey, it is time to make your first trip around the ring.†Madam SÇwáng said, moving forward a couple of yards at a slow pace while still keeping hold of the reins and although the there was some give, the captive knew that it would only be a few seconds before the reins would be pulled tight.
I should be thankful that you are going at this speed as it gives me a chance of being able to keep up even though I haven’t a clue about how to walk properly in these boots. Perhaps I should just try to place the hooves down flat against the floor at the moment. Cassidy lifted her right foot up a few inches before she leaned forward a little and placed the hoof back down, with it making the classic clop sound when the metal struck the floor. Well, I can move forward, but that felt unsteady, so it is going to take time to become used to walking like this. She repeated the step with her left foot, taking it a few inches further this time and although she was feeling unsteady again, the captive was sure that she would be able to cope with walking at this speed. My cheeks feel as like they are on fire at the moment, but that shouldn’t be a surprise with the world watching while I have to act like a horse. I should be thankful that you can’t make this situation any worse for me.
At first, the ponygirl kept herself to making very short steps with intervals that were as long as possible, so that she could learn how to perform the most careful of walks in her footwear that was half boot and half horses hoof. Once the woman had moved around a quarter of the ring, she managed to feel more secure in taking steps in this way, so she started to increase her speed while putting more distance between her footfalls. Although the changes were small, they were more than enough to allow her to keep up with her captor and she shortened the distance between the two ladies by a few feet. I wish I could hide the fact that I am doing better than at the start, but there is no way of hiding the fact that I am closer to you as the sound of my hooves will give me away. Also, the change in speed will also be audible to you, so once we have gone around the ring I have a feeling that you will quicken the pace.
As the two ladies continued with walking around the circle, Cassidy concentrated on making sure that she would have no problems in using the ponyboots, although she wondered if she was able to cope if her pace was quickened. I don’t have any trouble at this speed now that I am getting used to this, but if I have to move a lot faster I could still end up falling over.
“You have done well for a start, my pretty little pony.†The Mistress said as she came to a halt at the point where they started. “It was clear from the sound of your hooves that you had no trouble in maintaining enough speed so that you could keep up with me. Seeing as you have managed to cope so well, I see no point in going around the ring again at this pace, so I will go at close to a normal walking speed which should provide a decent challenge for you. However, I think that you should be able to maintain this speed.â€
I don’t think that I am ready to follow you if you go too fast and I need more practise with stepping in these ponyboots. No, wait! Any attempt at procrastination was denied to the ponygirl, as Madam SÇwáng set off at the speed which she had indicated and the captive know that within a second the reins would become tight. I have to go as fast as I can, or I could end up being pulled over flat on my face without any way of stopping my fall. Cassidy’s first step with her right foot was taken as a result of instinct, as she attempted to maintain her balance and move forward at the same time so as not to let herself be pulled over by the reins. Thinking about what steps she would need to take so that she could move forward was pointless, as this would just result in her not being fast enough to stay upright. After she took the first step at speed, the helpless lady realised that the momentum of her body was enough that she had to place her left foot in front so that she could maintain her balance.
As the captive followed her mistress around the ring, doing her upmost to keep up at this new pace so that some slack would remain in the reins, a worrying thought entered her mind. When I did the first circuit, I was going at a speed so that each step was slow enough so that I could stop instantly. However, it will be impossible to do that as my movement will not allow me, so how an earth am I going to be able to stop? I might have just exchanged falling over at the beginning for falling over at the end, unless I can work out how to slow myself down sufficiently. If you stop now, I am going to end up walking right into you and we could both end up on the floor. Maybe you are going to slow down first, so that I might have a chance at coming to a stop. Any hopes that Cassidy had of Madam SÇwáng slowing down were dashed once they completed a circuit of the ring, as the kidnapper increased her pace which forced the prisoner to push herself even harder so as not to lag behind. If you come to a halt now, it is going to be disastrous for me.
These thoughts were upmost in the captive’s mind as she walked behind her mistress and this preoccupation almost proved to be her undoing when the Madam came to a halt in front of her. I can’t stop! An involuntary cry escaped the gagged mouth of the ponygirl while she was continuing in her forward motion and her captor took took a few steps to the left while still holding the reins. Thank goodness! Knowing that it would be a disaster if she tried to make an immediate stop, the bound woman shortened her step a little at a time until she was confident enough that she wouldn’t overbalance on the last step That took me nearly a quarter of the ring, but at least I managed to come to a halt at last.
“I should have realised that it would be harder for you to stop, seeing as you are not experienced in walking with these boots. However, you managed just fine in the end, so I think that I should continue with the training of my mare.†Madam SÇwáng released her grip on the long reins so that they hung from Cassidy’s harness bit-gag before she put the riding crop down on the ring-side and stepped behind the prisoner, taking hold of the reins so that they went back on either side of Cassidy’s face. “I have one of the reins in each hand and I will be walking behind you this time, so that you can get used to starting, stopping and changing direction.â€
Oh no, now you are going to act as if you are my rider. Although the helpless woman felt even more humiliated by the idea of having a rider, it also added to her feelings of submission and it created a strong thrilling in her body at the level of control that she was under. How will I know when to start?
“Giddy up and do not be slow.†The mistress said in a bad approximation of a western accent as the ponygirl experienced a strong impact to the cheeks of her derriere and the sour taste in her mouth let her know that it would have hurt anyone else.
You just whipped my bottom with the reins! That’s more of an embarrassment than anything else as it didn’t actually hurt me, but I don’t want the whipping of my body to continue in any way. I just hope that you allow me to slow down gradually. Cassidy set off in the usual anti-clockwise direction around the ring at what had become her normal walking speed and she was starting to feel more confident in walking on her fake hooves. Once she had completed two circuits of the ring, however, her head was pulled so that it turned a little to the left and after a moment she realised what was happening. It’s the rein that’s attached to the left side of my harness bit-gag, you must be tugging on it in order to make me turn to the left. As soon as the woman understood what her mistress wanted, she slowed down so that she could perform a safe turn and the tug on her side stopped when her new direction was taking her towards the centre of the ring. You are probably going to train me by making me go across the ring like this for a while, so at least I will be prepared for what you want. No matter what is going on, I will need to turn one way or another, unless you want me to walk into the side of the ring.
There was a tug on the right side of Cassidy’s harness which pulled her head in that direction and she responded in an instant as she turned to the right with the tug halting when the woman was parallel to the side of the ring. So I’m going in the other direction for once, which does feel a little unusual as I have been going in just one way until now. After spending a minute travelling clockwise within the ring there was another pull on the right rein, which encouraged her to turn so that she was heading across the middle of the ring and once she was nearly at the other side, a tug on the left side of her face made her go anti-clockwise so that the blocks that made up the ring were to her right.
As the ponygirl continued the circling inside the ring at her usual steady pace, her head was pulled back a little as a result of pressure being exerted onto the rings that were on both sides of the bit between her teeth. You must want me to slow down, as this is what riders do to horses when they want them to stop. I need to be careful though, as I don’t want to fall over with my hands bound behind my back. Seeing as this was only the second time that the woman had slowed down from this speed, she was careful how she altered her pace with the reins still pulling against her, but it only took a short period of time before she managed to stop. What are you going to do now? Has this come to an end?
What happened next came as a surprise to the damsel as there was a flicking on her ears, which was followed by another one only a few seconds later and it took a third for the helpless lady to understand the message. You must want me to start walking again, but I expected you to slap me on the bottom again. This is an easier signal to send to me though of you are further away from me. Cassidy started to walk forward again, but she wasn’t even halfway to her full walking speed when there was a sharp tug on both reins and she responded by keeping at that pace. I understand what you are doing now. The first part of the training was so that I would go in different directions when you pulled on one rein or the other and now you are teaching me to change how fast I move according to how you use both reins at the same time on me.
A fresh flick of the reins against the cheeks of the helpless woman let her know that she needed to speed up and she was just short of her maximum pace when there was another dual tug, at which point she maintained her rate of movement. After a few times making circles within the ring and changing speeds as her mistress decided, the captive found herself having to alter her direction of travel alongside coping with the commands to speed up or slow down.
We’ve been at this for a while now and you really seem to enjoy making me perform for you as a horse.
“Okay my prancing pony, go over to where I left the riding crop and stop there so that we can have a rest.†Within a second, Cassidy turned in the correct direction so that she was facing that area in the ring and she cut across the centre with her slowing down so that she stopped just short of the blocks.
Something has been added since I started going around the ring. There’s a small paper bag, what looks like a long black rod and two long leather straps. I don’t know what their purpose is, but I have a feeling that I am going to find out before long.
“You are doing well in your training, my lovely horse, but after this short break I will require you to learn a few new things.†Madam SÇwáng said as she brought the reins around to the front of her ponygirl. “However, I just want you to remain in place for a few minutes while get a few items ready.†As the leader spoke, she released her hold on the reins and lifted her hands of the face of her captive before closing the blinkers so that the helpless woman was robbed of her sight again.
I think that it is more than just stopping me from walking away as you could have held onto the reins, so there is something more planned for me. As Cassidy listened out for any telltale sounds, there was a soft swishing noise in front of her, which was followed by a gentle tug on each side of her face where the reins were connected to her gag. You didn’t remove my reins so my guess is that you took the pair of straps and attached them to the end somehow. Next, there was a clink of metal upon metal in front of the lady, but apart from thinking that it had something to do with the black rod, she was at a loss to work out what it meant. A few seconds later, there was another soft tug on her reins which and as she wondered what was occurring she heard an object fall onto the floor behind her. Even if you pull my blinkers open to the side right now, I will not be able to see what you just did.
As the helpless woman attempted to work out what had happened, she heard a rustling sound in front of her which she recognised as items being taken out of the paper bag. I doubt that they are some kind of torture device as it wouldn’t fit into the scenario of me being a horse. After all, you do not appear to be the kind of person who would hurt animals.
“Everything has been made ready, so before we start again, you should have a little reward for your behaviour, my pretty-pretty pony.†The blinkers were pulled apart by Madam SÇwáng’s right hand and after a second, Cassidy’s eyes adjusted so that she could see that her mistress’s left hand was closed around something. “Bend over for your sweet present.â€
It was awkward for the captive to bend over much, as her boots didn’t allow her lower legs to go back, so she had to bend her legs at the knees to compensate and as her head approached the left hand, it opened up to reveal what the mistress was holding.
As if it was going to be anything else…
For Cassidy, not only was it awkward for her to remain in this stance for more than a few seconds, but there was also the problem of picking up the two small white cubes that were being held in the palm of her Mistress. I’ve seen horses pick up sugar cubes with their lips while wearing bridles, but it’s going to be more difficult with this bit gag in my mouth. However, no matter how kind my Mistress can be, she is still my Mistress and I do not wish to get into trouble with her by acting in a way that can be thought of as disobedient. Oh no! As the pony-girl bent over a little more, she was just able to extend her lips so that she could pick up one of the cubes, but it was then that she realised that this was all that she could do. This is a full harness gag, which means that I have straps under my chin and they are buckled so tight that I cannot move my lower jaw at all, so I cannot take the cubes into my mouth.
“Oh dear, is my sweet little pony having problems with her little present?†Madam SÇwáng said and the helpless woman with the cube between her lips looked up, trying to look as pitiful as possible while hoping that her appearance didn’t make her look silly. “I think that I can see what the problem is with you trying to eat. Those assistants of mine have bridled you so tight, that you are unable to take the cube into your mouth. Is that true?†There was a nod from the helpless lady to show that it was correct and because the grip on the cube was so precarious, it slipped out from between her lips so it fell back onto the palm of the Mistress.
“This is an easy matter to sort out. I will unbuckle the straps underneath the chin so that you can take the cubes, but you must leave them alone in your mouth until I buckle you back up again. Is that clear?†After the restrained woman nodded her head, the Madam closed her left hand and worked on separating the straps that held that captive’s chin in place, taking just a few seconds to work them loose. Once this had been achieved, the woman held her palm out flat again and this time Cassidy was able to lift each cube up before depositing it in her lower jaw, moving them back behind the gag using her tongue. After the cubes were safely nestled on the space behind the bit, the prisoner closed her mouth as much as she could so that her captor could buckle the chin straps to the tightest notch.
“I will give you a few minutes to enjoy your present before we continue with your training.†The lady dressed as a Ring-mistress said while Cassidy straightened back up and the damsel started to roll the cubes around her mouth as best she could with her tongue, given the restriction place upon her by the gag.
At least I will be able to have a short rest before I will have to start running around, so I will need to make the most of this. Those straps were extenders to my normal reins, but why do you need all of the extra length? Also, what have you done with your riding crop? As the lady rolled the cubes in her mouth, she started to notice that there was more than just the flavour of sugar in her mouth and that the cubes were also laced with honey. While she was enjoying the cubes, there was a little build up of saliva in her mouth, but the release of honey onto her tongue drove her glands into overdrive and the captive knew what this was going to do to her. This is deliberate, I’m going to start drooling like crazy and with this gag locking my mouth in place, the only way that I can get rid of it is out of the corners of my mouth. This is yet another little torment which is being inflicted onto me!
There was a noise behind the helpless woman which brought her back to full attention and she noticed that her Mistress had gone around to her back, returning with the riding crop which had a long extension added to the base before picking up the ends of the extended reins. As the Madam walked to the centre of the ring, she pulled on the flexible whip part of the crop so that it was lengthened and Cassidy worked out what was going to happen. You are going to control me while remaining in the centre of the ring and the extended whip can be used on me from where you are standing. Although I won't feel any pain from being whipped, there is the embarrassment and humiliation of being treated in this manner. Oh no, I need to get rid of some of this drool!
The amount of saliva had built up to such an extent in Cassidy’s mouth that she needed to dislodge it if she was to start running around and the only way to do this was to shake her head so that the liquid would be forced out of her mouth through her gag. Now I’m acting like a horse in trying to clear my mouth.
“I see that my wonderful horse is champing at the bit for some more action. Come on horse, start running anticlockwise around the ring.â€
I really don’t have any choice in the matter, as you can use the whip on me if I refuse to cooperate. When the helpless lady looked to her left, she saw that Madam SÇwáng was holding the ends of the reins in her left hand while the end of the whip was gripped in her right. That will make it easier to control me as you will have no problem in reaching my bottom with the other end of the whip. There were a few hesitant first steps from the pony-girl as she started to go around the ring in the direction that her Mistress demanded, but she soon picked up speed as she regained her confidence in running while wearing the unusual boots.
“That is it, you are doing well my beautiful pony, but I think that you need a little encouragement.†As Madam SÇwáng spoke while turning on the spot, emphasised her words by flicking the whip so that the end impacted against the bottom of the woman in bondage. “This is just to make sure that you behave yourself.â€
The real reason is that you wanted to use your whip on me anyway and that was just an excuse. Even though the captive Cassidy knew that it was a little risky, she managed to run a little faster, although one of the side effects of running at this speed was that it encouraged a further build up of saliva which forced her to shake her head more and more often. This is forcing me to foam at the bit, just as if I was a real horse, but I can’t let my predicament distract me while I am running. However, I don’t know if I can keep this up for much longer.
“Slow down to a trot now.†With this instruction, the pony-girl slowed down to a speed which she found to be sustainable in her present state of captivity and the lady hoped that she would be allowed to stay at this pace for a while so that she could recover her energy. After a few minutes trotting, the helpless woman was ordered to run at full speed for a minute and this was followed by about ten minutes with the captive being made to run at various paces.
“You can stop for a rest now, my dear pony. I will allow you a break before the next part of training and then you will not have to move any faster than a walking pace.â€
Thank goodness for that, I was wondering just how much longer I could go on running for as i was getting more weary with each step. It is heartening that I won’t have to run around for the next part.
“You look all lathered up around your bridle, and I think that you need to be cleaned up.†Madam SÇwáng put the reins and whip down, approached the prisoner who was still breathing at a rapid pace and stood in front of her while pulling a large white handkerchief out from her left sleeve. “Here, let me do something about this mess on your face.†She lifted up her right arm and dabbed at the face of her prisoner so that the drool could be removed from the face of the defenceless woman before using the handkerchief to remove any other traces of saliva which was put on the side when it was finished with. “That is much better, now you look good enough to-.â€
Cassidy was taken by surprise as she was embraced be her captor who placed a tender kiss on her gagged mouth and this was followed by another and another. This is quite a surprise, as I am supposed to be a performing animal and you are the Ring-Mistress who is my owner. However, it is a very pleasant distraction from tonight’s activities and I love being held in your arms while you kiss me.
After a minute of intimacy, the Madam pulled her face away from her captive before saying “I do not know if such an act is permissible, but I kissed a horse and I liked it.†She took her mouth closer to the left ear of the restrained lady, saying in a low voice “I wish I could keep you as my helpless submissive forever, Cassandra, but I know this can never happen because you have your own life to live and missions to perform for your country. However, I do want to make the most of this time until Thursday morning comes, when you are released.â€
I just wish that I could convince you that I am not Cassandra, whoever she is and that I would be willing to remain as you helpless captive in bondage. However, I suspect that you might react in a bad way, if you discover the truth about who I am, so it would be best if I maintain the pretence while I am here. Maybe in a month’s time, I could reveal who I am and perhaps we could meet again. Oh wow. Another series of sweet kisses from the Madam served to distract the prisoner form her train of thought and she surrendered herself to the moment, oblivious to everything else.
“Well Cassandra, I hope that you have enjoyed your little rest.†Madam SÇwáng separated herself from the pony-girl. “This next task will be slightly more tricky than the previous one, as you will be ‘High-stepping’ around the ring.â€
High-stepping, what on earth is that?
Cassidy’s expression must have displayed her internal puzzlement as her kidnapper went on to say “I do not know if you have ever seen equestrian competitions on television, but I will try to explain. There is a part of the competition called dressage and in this the horse walks in a highly stylised manner by lifting its foreleg up so that the upper part is parallel to the ground while the lower half is vertical. So Cassandra, when you take a step forward, your leg has to go up high enough so that your thigh is sticking straight out while your calf is pointing down to the floor.â€
That sounds easy enough, so how hard can it be to move like that?
A nod from the pony-girl elicited a smile from the captor. “That is good. Now I will return to the centre and we can start the last part of your training.†Once the Ring-mistress returned to the centre, she again took the extended reins in her left hand, took the whip in her right and took a few seconds to compose herself before saying “Start.â€
As soon as she heard the command, Cassidy lifted her right leg up in the air so that her thigh was parallel to the floor, but she found out that doing this while trying to keep her lower leg vertical was harder than it had seemed. Bringing her leg back down wasn’t any easier as this method of walking felt unnatural to her and it was just as awkward when she brought her left leg up in the same way. I thought that this would be so easy when you described it to me and I remember seeing this being performed at the Olympics. However, it is taking a lot of my concentration just to get my legs into a position that is even approximately close. Hopefully, it will get easier as I continue to go around the ring.
“You are not doing badly at the moment, my helpless horse and you are putting a genuine effort into it. Do not worry, I am sure that you will get better before long.â€
I don’t think that I will be any good at this, it is so difficult. A grimace appeared on the face of the bound woman as she did her best to try and keep to the correct position and she wondered if getting it right was ever possible. After a couple of circuits around the ring, the captive was surprised to discover that it was becoming a little easier and it was starting to require less concentration as her body adapted to the new mode of movement. Once she had completed another few times around the ring, the prisoner was hitting the mark quite often and the encouraging sounds from the Madam made her feel as if she had achieved wonders in a short time.
Just a minute or so later though, the pony-girl discovered the true problem in high-stepping around the ring like a horse, as she started to feel the first suggestions of strain in her leg muscles. Although the damsel was hoping that the feeling was just a figment of her imagination, it grew stronger with each second that passed by and soon, she could also feel it in her joints. It’s because I’m using my legs in such an unnatural way. The strain on my muscles is being transferred to my joints and it is becoming a whole new torment as a result. Each additional step around the ring was making Cassidy suffer and her concentration on getting the position right was faltering as the joints of her legs were feeling as if they were on fire. If you don’t stop soon, I am going to collapse because my legs won’t be able to hold my body up for much longer.
“Stop!â€
Cassidy was relieved to hear the command and she came to an immediate halt, but the lady was still worried as her legs were trembling from the ordeal that they had been put through. I just need a few seconds before I can feel like my legs are strong enough as I don’t want to take another step at the moment. As the lady looked to the left, she saw that Madam SÇwáng was unscrewing the extension for the riding whip before removing the additional straps for the reins and the woman walked over to the side of the ring where Cassidy was so that she could put the items down on one of the boxes.
“You have put on a wonderful show this evening, my slave. However your training is over and there is nothing more to do with you as a pony-girl. Perhaps I should find out if KÇŽodÇŽ is ready to perform on the trapeze.â€
“I am, Madam SÇwáng, but KÇ’ngbù and I have a special surprise for you.†Cassidy was surprised to see the two girls enter the ring area from behind one of the curtains and KÇ’ngbù was carrying a large bag.
I must have been so preoccupied with being Madam SÇwáng’s horse that I didn’t even see you leave. I wonder what this surprise is, but knowing you two the likelihood is that it will be an unpleasant one.
“You have another surprise for me? That is very kind of you.â€
“Yes Madam.†Kǒngbù said as the two assistants walked towards Cassidy “However, we will need to prepare the pony. Kǎodǎ, the creature will need to be hobbled first, so that there is no chance off her running away.†Once the two ladies were in front of the captive, Kǎodǎ removed a long but narrow leather strap with a buckle at one end from the bag and the assistant wrapped this several times around the ankles of the prisoner before using the buckle to secure the strap in place. The pony-girl made her best attempt to dislodge the strap that bound her ankles together, but the only result was her making a squeaking noise as leather rubbed against leather.
I have no chance of stopping you two from doing anything you want to me, as you have removed my only chance of getting away from you when things turn unpleasant. As the immobilised woman looked on, Kǒngbù took what appeared to be a wide leather belt with several small buckles at one end and this was placed around her waist, with the belt being buckled into position so that it gripped hard but it wasn’t too tight. Is this some kind of torture device that you are planning to use on me? When Cassidy took a closer look at the belt, she noticed two large D-rings sticking out on the left and right side of her body. The rings must have something to do with making me suffer. What are you two doing now?
The two girls walked out of the ring, went behind one of the curtains and the helpless woman heard something being wheeled. When the assistants came back into view, what Cassidy saw made her eyes grow wide and her face go pale...
No, please no, there’s no way that I can cope with that!
“Stop!â€
A device was being wheeled along between Kǎodǎ and Kǒngbù, with them each holding onto a long metal bar which was on either side of the object’s main framework and at the end of the bars were large clips. There were two wheels which looked like standard bicycle wheels, with them looking about the same size and between them was a leather seat which only allowed room for one person.
OMG! That thing is built for someone to ride in and those clips must be so that it can be attached to my waist. I’m going to be turned into a horse and cart in front of the entire world. It was one thing to play at being a horse, but to be made to trot around as an actual beast of burden will be the most humiliating torment yet.
“Why ladies, this is so precious. You arranged to have a small one woman buggy brought here, just so that I can ride around with Cassandra as my personal horse. Thank you for this incredible present.â€
It may be incredible to you, but it is just another psychological torture for me as I am going to be dehumanised even more by this. Cassidy began to struggle as the buggy approached but the restraints around her body were so effective that it was more accurate to describe her actions as a frantic wriggle, with her making a loud squeaking sound as leather rubbed on leather. Even this minor wriggle did more to make the two assistants amused than annoyed as the buggy was wheeled into position and they had no trouble with attaching the clips at the ends of the bars to the D-rings on the belt around the waist of the captive.
There is nothing I can do to stop this and I am going to be made to transport my Ring-Mistress around the warehouse. I wonder if there will be further humiliations laid out for me tonight? I really hope not.
“Madam SÇwáng, if you would be so good as to sit on the buggy while KÇ’ngbù holds onto the reins of the horse.†KÇŽodÇŽ said as she stood by the left side of the buggy while KÇ’ngbù went to the right side of the prisoner so that she could take hold of the reins and Cassidy yelped when her head was forced back because of a harsh tug on the straps.
“That is to remind you that your rider will be in charge.†KÇ’ngbù said as Madam SÇwáng approached the left side of the buggy with KÇŽodÇŽ putting her right arm out, so that the leader could remain steady while seating herself in the buggy in a comfortable position.
“Once again, I cannot thank you enough for this wonderful gift. I would have never thought of it myself, but Cassandra looks as if she is in her proper place.†The woman spoke as Kǒngbù took a few steps before handing the ends of the reins to the Madam and Kǎodǎ moved forward so that she could kneel by the legs of the helpless lady.
I notice that your riding crop is across your lap, which means that if I don’t do as you ask I will be whipped, so that although I won’t feel any pain, the psychological effect will be very strong.
“I think that I am ready to take a little ride now, so if you would be so good as to remove the hobble from the legs of our horse, I can go for a ride around the warehouse.†It only took a few seconds for the strap around Cassidy’s ankles to be unbuckled and once the restraint was removed at least the captive was able to move her legs again.
Freeing my legs are useless to me now as I am nothing more than a harnessed animal and my Madam will want me to move anyway. Any refusal to follow orders will just end with me suffering further humiliation.
There was the feeling of slapping against the side of the prisoner’s cheeks which let the pony-girl know that she was supposed to move forward and this was followed by “Start walking forward, my helpless horse.â€
This is not going to be easy, as I have never tried to move anything other than myself in boots like these. It took all of Cassidy’s effort just to get a little movement forward and she thought that she was going to faint with the ropes across her chest restricting her breathing, but each step was making the buggy move a little faster. Soon, the captive was surprised about just how easy it was to remain moving once she had reached a gap in the ring and a tug on the left side of her face let her know that she had to aim for the gap. I’m about to end up going around the warehouse, but I doubt that I will end up seeing anything that might be considered to be a secret.
“You are being a very good horse.†Madam SÇwáng said as the women left the ring and the pony-girl continued to walk in a straight line once the ring was left behind, until there was another slap on both sides of her face. “Now you start running.â€
I hope that I can do this, as it took an awful lot of effort just to get up to walking speed. At least manoeuvring is going to be easier with these spaces. Again, Cassidy felt dizzy due to the shallow breathing imposed on her by her tight bondage and she hoped that nothing would go wrong as she built up speed. When she reached what was almost a running speed, there was a little tug on the reins to indicate that she should remain at this pace, before another one on the left side of her head sent the signal that she should turn left. This pull remained until the captive was parallel to one of the walls of the warehouse and once Cassidy was able to relax, she became aware of the loud noises that the horseshoes on the bottom of the boots were making. The clip-clopping sounds even louder than before, which may be as a result of the extra effort that I am using and the walls of the warehouse seem to amplify them with the echoes that are bouncing off the walls.
“I have never been out for a horse ride like this before, my lovely pony and I must thank you as well for this entertainment.â€
Another tug on the left side turned the helpless woman’s head a little to the left as they started to come close to the end of the large building and the pony-girl turned so that the end wall was on her right side. Once I was fast enough, it takes every little effort to remain at this speed, but turning requires some extra effort and I have to make sure that I remain steady on my feet as falling over would be a catastrophe. I’m wondering how I am going to stop though, as I can imagine that it is going to be much more difficult with the buggy attached to me. As she half-ran around the warehouse, the captive saw a trio of beds with steel bars at the head and feet and there was a large area that was also separated from the rest of the warehouse with white sheets. That covered up place must be a special surprise, but those beds almost look as if they are out of some sixties British NHS drama.
Another left turn put them a course that was alongside the other long wall of the building and there was a pull on the reins that forced the captive’s head back a little. You must want me to slow down, but it will not be easy as you, along with the buggy, means that there is a lot more momentum top deal with. It is best if I take my time slowing down as I do not want to take any unnecessary risks in my current predicament/ At first, Cassidy slowed down a little, only to find that there was increased pressure on her waist caused by it being connected to the buggy, but this faded after a moment so the prisoner reduced speed a little more. That’s very unusual, the vehicle shouldn’t be reacting so quickly to my changes, what’s happening? Her answer was revealed in a few seconds when she slowed her pace again and the change in the buggy was accompanied by a small squealing sound.
Brakes, you must have basic brakes on the buggy and that explains why slowing down is easier than I thought. At least I know that I’m not at any risk as you will make it easy for me.
Within a minute, Cassidy had reduced the speed to the point where there was a flick of the reins and she remained at that speed for a while, as she turned so that they passed the second shorter wall. After the next turn they were close to the big top area, but the pony-girl was only instructed to turn right when the first long wall was near and once this was completed more flicks of the straps instructed her to increase her rate of motion to a fast trot.
Several circuits of the warehouse were completed in this way, with Cassidy varying her speed at the whims of her Madam but she was surprised when she completed going around the interior of the building at a slow pace. Are you making me rest in order to try for a full gallop? I doubt that it would be safe if you attempted that.
The answer to this thought was shown when Madam SÇwáng said “High-step!â€
Oh no, that was bad enough when I only had to move myself and it was exhausting then. A sudden feeling on the cheeks of the prisoner as she hesitated was followed by the familiar sour taste in her mouth and she knew that her bottom had been whipped. When the second occurred a moment later, her cheeks turned bright red from the embarrassment and she started to lift each leg up in the way that she had been taught. Just as she had suspected, it required more effort than just walking as it was much harder to get any kind of proper traction and within just a few minutes, she could feel the strain in both her legs and her joints. This is even worse than when I was inside the ring and I doubt that I will be able to continue being a pony-girl as this is going to murder on my legs as it is.
They had nearly completed another circuit when various tugs on the reins directed the captive to a course that was taking her and her Madam bag to the circus part of the warehouse and she sighed with relief when they passed the sheets. Once the restrained woman was back inside, she was directed to the far side of the ring and when she was there, the Madam said “Halt, my pony. Ladies, will you two unhitch the pony and prepare her for the next set of duties?â€
“Yes Madam SÇwáng.†Both of the assistants said almost in unison and as the leader dismounted before sitting on one of the side boxes, the accomplices set to work on the woman who was at their complete mercy. They took less than ten seconds to detach the bars from the sides of the belt around her waist by opening the clips and the buckles were easy enough to take apart. However, the next step meant that Cassidy was going to have to guess what was going to happen as the blinkers on her blindfold were closed, which left her unable to see again.
I’m as helpless as I was when they turned me into a pony-girl and I think that they are either going to turn me into another animal or change me back to the way I was. After a wait which may have been about a minute although the helpless lady couldn’t be sure, the horse’s tail was removed from her bottom and the two clicks at the top of her head along with the pressure on her scalp meant that the ears had been removed from the head band. There were two more clicks in quick succession and a new pressure on the bottom of the captive was enough to indicate that she was either being made up as a bunny girl, or as a new creature. I am still wearing the pony-girl boots on my feet at the moment, but that must be next on your agenda.
Her suspicions were confirmed when the hands of her captors took hold of her so that she could be guided backwards, until she felt the pressure of one of the ring-side boxes against the back of her legs. The downward pressure on her body made it clear that she was to sit down and once she had done so, the touches just below her knee were the assistants loosening the laces on the boots. As Cassidy waited, the boots became loose enough so that when her feet were lifted up, the boots were pulled from her legs so that they could be replaced with shoes and when she put her feet back down, the heels seemed to be the same height as before she wore the boots.
Perhaps they are dressing me up as a bunny girl again. If that is the case then I won’t have to perform any other activities, or at least I hope not. Well, this is hardly a surprise. Cassidy offered no resistance as her feet were placed side by side on the floor and next there was the very familiar feel of rope as it was wrapped around her ankles. Judging from the way my ankles are being forced together, it is probably five double stranded wraps around my legs and possibly three or four cinches added to ensure that the cord grips around my ankles. Just as always the knot will be tied so that it will be out of my reach, but it’s not as if I could untie a knot anyway, with my hands covered. The binding of the prisoner’s legs just below her knees were next and it seemed that there was about the same number of windings that were tightened by cinches before the knot was secured.
Now it’s time for my legs above the knees to be secured and this time there might be one or two extra loops added, although you have placed the same number of cinches. Hey! That’s a bit high! In the previous times when her thighs were bound together the normal position was around the mid-thigh area, but this time the rope was very close to the top of her legs. It felt as if there were more loops added around her legs and the number of cinches appeared to be unnecessary with the hands of the binder coming very close to the top of her legs when the rope was being threaded between her thighs. Please don’t, please don’t. During this binding the hands came so close to her most intimate area that the damsel thought that her modesty was going to be trespassed on, but in the end she was relieved when it didn’t happen. You used this as a mental torture on me, but if I had shown an obvious reaction that Madam SÇwáng would have been very angry. Perhaps you were planning on having some kind of ‘accident’ but decided against it at the end. Now this is a surprise.
The loosening of the rope that acted as a tight band over the captive’s chest in a figure of eight pattern came as a great relief and once it was removed, she was able to fill her lungs with air for the first time since it was wrapped around her. It was even more of a shock when the long cord that bound her forearms together in a figure of eight pattern was also untied, but given her previous experiences, she doubted that her arms would remain free for long. Her arms were brought around to the front of her body, her palms were placed together and what may have been the same rope was wound in a figure of eight pattern from just above her wrists, all of the way up to her elbows. Even though her covered hands would be unable to untie any knot, the positioning of the knots were in places where her hands couldn’t reach and the lady thought that this would have been done out of habit by the assistants.
I guess that you two want me to stand up now. Cassidy could feel the hands of her captors through the leather that enveloped her hands and the gentle tug grew stronger with each moment, so she used their grip to lift herself into a standing position. You wouldn’t have wanted me to stand up without going anywhere and the tug is constant, which means that I will have to hop forward in the direction that you choose. Once she had stood up, there were also hands gripping her arms so that the captive didn’t have to worry about falling down, although for reasons of safety she took very small hops in direction that the assistants were pointing her to. I wonder where you want to take me to, as at the moment I seem to be heading towards the centre of the ring.
With the help of the two others making sure that her balance was maintained, Cassidy didn’t take long to reach the location where she was supposed to go to and as the blinkers on her blindfold were pulled open, she stared at the full length mirror that showed her in her present state of bondage...
I must admit that this bondage looks quite impressive and you have done a very good job in making me completely helpless again. Once, I would have wondered why you have bound me like this, but there must be a reason to it which I will discover soon enough. As the captive continued to look at herself in the mirror, she shivered as she saw just how high the thigh ropes were so that they left a very small gap at the top of her legs.It could have been so easy for you two to have pretended that it was a mistake if you touched me and I doubt that I could have convinced Madam SÇwáng otherwise.
“My assistants have bundled you up well for the next part of tonight’s entertainment and now it is time for them to finish the preparations.â€
There was a motion in the corner of the prisoner’s eyes before the blinkers were pushed shut again and the helpless woman felt hands take hold of her body so that she could be guided down to the floor of the ring. Once the lady was in a sitting position, her forearms were taken down to her lower legs and she felt the touch of rope as it was wound around her elbows and knees. You must want the end result to be a surprise if you wish me to remain blindfolded, though I doubt that anything could be that shocking anymore. Within a few seconds, she could sense the pressure on her limbs as the cord was tightened and there was fumbling which would have been caused by the ends of the rope being tied together. Well, I am immobilised, so you can do anything you want to me and I wouldn’t even be able to put up a struggle.
What happened next proved to be a surprise for Cassidy as her legs were held before she was tipped over onto her back so that her limbs were pointing up into the air. There was a whirring sound for about ten seconds before something was forced between the shins and forearms of the captive and this was followed by the binding of her wrists and ankles with another length of cord. Oh, so now you are going to leave me hanging upside down in the ring while Kǎodǎ shows off her acrobatic skills on the trapeze. That sound must have been some kind of winch and I have already been hung upside down today, so this isn’t going to be too scary. After the winding and cinching was complete, there was a pause of a few seconds before the motorised sound started again and the pressure on the captive’s wrist and ankle binding increased as her back left the ground.
I wonder how far I will be lifted into the air this time? It seemed that the time that the winch ran for was even less than before, which suggested that there wasn’t a great increase in height for the suspended damsel as she hung from her wrists and ankles. I don’t think that I am ten feet from the ground, so there will be nothing to scare me.
“Your blindfold will now be removed.†KÇ’ngbù said “So, keep your eyes closed until you are told to open them.â€
It will be unusual to see in this way, as I will be looking straight up once I open my eyes, but all I will see is the line that I am tied to. There was a sensation at the back of Cassidy’s neck as the straps of the blindfold were unbuckled and she could feel the leather slide across her face as the object was pulled away. My head can’t even be six foot off the ground if you can remove my blindfold with such ease. I don’t know why you are going through all of this, as I have suffered much worse when I was placed in that pretend peril earlier.
“You can open your eyes now.†Kǒngbù said.
You are really trying to make this all so dramatic, when all I am doing is being suspended in a slightly different way than before. Okay, so now I can see what the fuss is all abou- NO! When the helpless lady opened her eyes, she expected to see herself hanging by her wrists and ankles from a hook, but she was unable to suppress a scream when she realised the true nature of her predicament. Kǎodǎ is standing above me and I’m hanging from the trapeze! That bar was what I felt against my legs when you bound my wrists and ankles together and when you start swinging, I will end up like a weight on a pendulum with no means of controlling my fate!
“Oh yes, Cassandra.†KÇŽodÇŽ said “You are going to take part in the final part of the evening’s entertainment. Surely, you must have realised that you would be involved in this. KÇ’ngbù, it is time that we started the show.â€
This is going to be horrible, you can’t have me swinging back and forth like this. Cassidy shook her head as she heard what was going to happen, but she knew that this was just a futile gesture as she felt a pair of hands press against her bottom while Kǎodǎ forced her own body forward on the trapeze. This was enough to make the trapeze swing a little and each successive push increased the momentum until Kǒngbù was unable to apply any more pressure to the swing. The damsel was already frightened by the predicament that she was in and this was enhanced by her swinging at the end of the trapeze by her wrists and ankles with Kǎodǎ using her own body to add even more momentum.
Please stop, just please stop.
“I cannot wait to see just how you appear on the screen when I replay this later.†Kǎodǎ said “Plus, the look on your face is so enjoyable, which must be the opposite of what you are feeling right now. I think that there is enough energy in the swing, so I had better start my performance, although I doubt that you will like any of it.†It took all of the captive’s concentration to not surrender to her fear and give out a continuous scream, so when the assistant started her trapeze routine, the damsel was not paying any attention to what was happening. As the act continued, the only thing that registered on the mind of the suspended victim was that the trapeze was swinging less and less until Kǎodǎ started to use her body to bring it to a halt.
Thank goodness it’s over so that I don’t have to go through any more of that. There was a whirring sound from above the helpless lady as Kǒngbù pressed a button on a remote control and the trapeze was lowered until Cassidy could feel her back touch the floor. I’m not sure how long that took, but I was subjected to that torture for quite a few minutes. There was a clear look of relief on the captive’s face as Kǒngbù untied the rope that bound her wrists to her ankles and this was followed by the cord that was wrapped around her elbows and knees. At least I don’t have to suffer this thing again. However, why have you brought some extra ropes over though and why are you lowering the trapeze even further?
Cassidy was taken by surprise when she was spun around on the floor of the ring so that her body was lengthways with the trapeze bar and Kǒngbù lifted her arms up so that her elbow touched the point where the rope was attached to the bar. Kǎodǎ took one of the ropes, winding it around the prisoner’s elbows and the connection point before cinching the loops and securing the ends with a secure knot, so that her elbows were bound to the trapeze. By the time Cassidy realised what was going on, Kǒngbù had lifted her legs up so that Kǎodǎ could use another length of cord to bind the damsel’s knees to the other end of the bar.
No! You can’t take me up again! At this point Cassidy started to struggle, but she know that it was already too late as Kǎodǎ bound her ankles to one of the trapeze supports while Kǒngbù tied her wrists to the other. Her self-control failed for a moment and she let out a piercing scream as she realised that this torture was only just beginning, while Kǎodǎ climbed back onto the trapeze with Kǒngbù raising it back up into the air.
Why have you tied me up this way? There is a gap between the bar and my body which is the same as my upper arms. This time, the bar was raised higher than before so that it was above Kǒngbù’s height and this meant that it took longer for the swinging to build up to the same level of momentum. Once it had been achieved, Cassidy discovered why the gap between the bar and her body was there when the assistant started her second routine on the trapeze. You’re using me as the bar! Instead of the acrobat keeping her feet on the bar itself, Kǎodǎ used Cassidy’s own chest and abdomen instead and this pressure was worse than if they were stationary, because centripetal force added to the weight of the trapeze artist.
I don’t know if my body can take this level of punishment. By the time Kǎodǎ had finished her second routine which was as long as the first, it seemed to the captive that the front of her body had been trampled all over from her hips to her shoulders. There’s probably going to be more and it will be even worse for me, but I don’t think that I can put up much of a fight anymore. When Kǒngbù lowered the trapeze so that Cassidy was touching the floor again, the helpless woman offered no resistance as her body was untied from the device before she was turned around so that the bar was across her abdomen. Her arms were untied and the woman was turned over before her wrists were crossed at the small of her back with a length of rope binding her hands together.
“This is just a temporary measure which will prevent you from struggling with your arms.†Kǒngbù said.
I can’t really see the point in trying to resist your actions at the moment, so the rope is quite unnecessary in the first place, but there is no way of explaining this to you. With both of the assistants concentrating on the bonds, it took very little time for the damsel’s legs to be freed from the ropes, although like before this was just going to be a temporary measure. Her feet were pulled wide apart first, before her legs were bent over at the knees which led her to suspect that she was going to be placed in some kind of frogtie. However, this thought changed when she felt the back of her ankles touch the trapeze bar with there being brushing against one side of each ankle. So that’s it, you are going to bind my ankles to the ends of the bar so that my legs will be forced apart. She could feel the ropes being wrapped around her ankles and the bar, which pushed harder against the back of her legs and after ten loops there was the familiar cinching that caused the cords to bite into her flesh. This time, I’m probably going to be hanging upside down from my legs which will be wide apart.
“Kǎodǎ, I think that it is time to remove the leather restraints from the hands of our captive, as they are not needed anymore.†A few seconds later, Cassidy felt the pressure just below her hands lessen before the gloves were pulled away and she was able to wiggle her fingers as her hands were no longer forced into a ball. Her wrist restraint was removed by one of the assistants and the lady wondered how her arms were going to be bound when she yelped as her upper body was lifted up from the floor. Before the damsel could understand what was happening to her, each of her wrists was pulled up onto the trapeze bar and the two ladies used a length of rope to bind her wrists to her ankles, applying several loops with cinches to tighten them.
I’m going to hang face down from the trapeze from my wrists and ankles and my own body is going to be made to torment itself! As the captive looked to the right, she saw Kǎodǎ pick up the remote control, pressing a button for a second so that the trapeze bar was raised a few inches upward. The effect on the whimpering lady was immediate as her limbs bore almost the entire weight of her body and the joints in her shoulders and hips felt as if they were going to be pulled apart.
“KÇ’ngbù, perhaps we should lessen the pressure on Cassandra’s arms and legs, otherwise this session might be too much for her. Maybe you should tie a rope around her waist so that the other end can be attached to the trapeze bar. It won’t do much, but at least it should alleviate her predicament a little.â€
“Yes sister, I will get started on it right away. However, there will need to be quite a few loops around her waist to spread the pressure out.â€
I never thought that you two would think of doing something to lessen my suffering, but you might not want to cause Madam SÇwáng to get annoyed. At least the torture to my arms and legs will be reduced, which is something to be thankful for. KÇ’ngbù approached from the left with a long coil of rope and Cassidy thought that at least ten double-stranded loops had been wound around her waist before it was knotted together behind her back. However, instead of the other end being tied to the trapeze, the bound woman realised that this particular cord was going to have a secondary purpose as it was taken between her legs, threaded around the waist loops at her front and pulled back between her legs. The free end was pushed underneath the waist winding at her back and looped around the trapeze bar where it was pulled as tight as possible before the rope was secured with a knot.
Oh no, you’ve not only put a new crotch-rope on me, but the other end is tied to the bars itself! This means that when I am lifted up into the air, part of the weight of my body is actually going to be supported by my- OMG!
“Oh, I cannot wait to see how this is going to turn out.†Madam SÇwáng said as she walked over to where the helpless lady was lying on the floor and she took the opportunity to give a few sharp tugs on the crotch rope which pressed into the captive’s most sensitive location. Even this small action was enough to create a small ember of desire between the legs of the prisoner and she realised that even in her current position of torment, her body could very well end up betraying her. “This show will be much more interesting than the last two.â€
“It is my turn to entertain you and our viewers, Madam SÇwáng.†KÇ’ngbù said as she stepped onto the trapeze so that she stood above the restrained woman and KÇŽodÇŽ pressed the button on the remote control so that both ladies were raised into the air. As Cassidy was lifted off the floor, her joints felt even worse as they had to take her full weight and the effect forced the rope between her legs to press even harder into her intimate spot, which fanned the embers of her lust.
I can’t even pull my legs together to hide my shame while I am tied up like this and being suspended in this way with a crotch-rope on view is just horrible. You’ve done this to me so that it adds to my public humiliation as well.
Once the trapeze was high enough, Kǎodǎ released the button on the control and her sister started to sway her body back and forth so that the trapeze would start swinging. At first, the fear of being suspended from the trapeze in her present way, along with the torment in the arms and legs occupied the captive’s mind enough so that she ignored anything else. When the swings moved further away from the vertical, however, she realised that as well as the swinging increasing the strain at her hips and shoulders, the crotch-rope was also having an increasing effect.
Oh no, this swinging is causing the rope to caress me! As Cassidy reached the apex of each swing, the strain on her shoulders and the pressure of the crotch-rope against her skin increased due to the momentum of her body. This lessened as she swung back from the maximum height, with the effect that her most sensitive location was subjected to a rhythmical force by the rope, almost as if the material was thrusting against her at a constant rate. With each swing becoming higher and higher, it was inevitable that the dull embers of warmth between the legs of the helpless lady would burst into flames.
This is worse than when I have to suffer a rope like this before, as this time the swinging is causing the cord to bite into my body. Not only is this particular bondage tormenting my arms and legs along with frightening me, I have the humiliation of having this rope at my most personal place and it is causing me to become aroused, despite what else is going on!
