Page 2 of 3
Re: Self-Bondage Ideas Thread 18+
Posted: Thu Dec 25, 2025 4:15 pm
by blackbound
Damn @Kishi, you went for the end boss version of the string challenge. Well done.
Posted: Fri Dec 26, 2025 7:13 pm
by Kishi
blackbound wrote: 1 month ago Damn @Kishi, you went for the end boss version of the string challenge. Well done.
If I'm not suffering, I'm not doing it right haha
Thanks for the idea! It added a steep sort of "exit cost" to the escape that was incredibly challenging to overcome. Must've spent half an hour meekly tugging on my nipples until I was finally able to grit my teeth and finish the job. Now I just need to figure out a way to make it even more punishing.
Posted: Fri Dec 26, 2025 7:55 pm
by blackbound
Kishi wrote: 1 month ago Thanks for the idea! It added a steep sort of "exit cost" to the escape that was incredibly challenging to overcome. Must've spent half an hour meekly tugging on my nipples until I was finally able to grit my teeth and finish the job. Now I just need to figure out a way to make it even more punishing.
You could run the string along a zipper, i.e. a row of clothespins or clips (or a mixture) starting on one nipple and going all the way down your chest one side and back up the other.
Posted: Sat Dec 27, 2025 1:00 pm
by CaptiveDan
Here's a predicament bondage position for @Kishi or anyone else who wants to try it! Note it's a bit intense and involves a good amount of torture. I tried it out in myself, but with only one set of keys/clamps instead of the full multiple sets.
Here's what you do:
- Rig up a rope or chain above your head that you can lock a lock to. I use a door hinge, Kishi has a pull up bar. Just make sure the knot will be out of reach when you lock your hands to the rope.
-Gag yourself if you have a safety plan in place (a person who can release you nearby, or a gag you can spit out if not). I used a sock and head harness, but anything will do.
- put a blindfold on your forehead, ready to pull down over your eyes later. I used a bandana, but you can use anything.
- tie a ring of a few different keys to a long string, only one of these keys should go to the locks you'll use on your wrist cuffs. Tie a second ring of keys to a long string, none of these should work. Mix up which ring is which so you don't know where the real key is.
- put a bunch of small rocks in a sock, and put that sock on one foot. Make sure their are enough rocks that when you put pressure on that foot, you will be forced to step on them.
- for the other foot, bring it up frogtie style to your theigh. Secure your ankle to your thigh. I use a frogtie futomoto rope tie, but you could easily use duct tape or leather cuffs.
- put nipple clamps along your body. Nipples, stomach, thighs... As many as you can. This part is inspired by @blackbound , connect to the far end of the two strings with the keys, then run the rest to the place where your hands will be tied. Make sure you don't know which string and subsequent nipple clamp chain is actually connected to the real key.
-if you have it, set a tens unit or other electro device to begin shocking one or both of your thighs
- Lock wrist cuffs on your wrists. Fist mitts or sock/stocks if you can
-pull down the blindfold
- lock those cuffs to the rope loop above your head
► Show Spoiler
If everything works as planned, you should now be forced to stand on one foot, where putting pressure on that one foot will cause rocks to dig into your skin. To relieve pressure from that leg (since the other leg is essentially useless) you'll need to hang down, pulling and stretching your chained wrists/hands.
To escape you'll need to pull off the nipple clamps, reel in the keys, and then fumble with the keys until you find the right one to unlock your cuffs. To make matters worse, there's a 50% chance you'll need to do it a whole second time if you pulled off the wrong string. If you pulled the right string, you'll still have the other set of clamps torturing you while you test each key on the ring to unlock yourself.
When I did it without nipple clamps, rocks, and only three keys on the keyring, it took me a good 20 minutes to get out. Not super long, but the leg strain torture enough made those 20 minutes exceptionally long.
For you @Kishi and any other pain pigs out there, I though I should add the extra sources of torture and challenges to break free.
Definitely only try this if you have an alternate escape plan (ie a partner or roommate you can call for help) because I truly don't know how long the full method will take to break free from.
Posted: Sun Dec 28, 2025 1:27 am
by Kishi
So my body is straight-up NOT ready after a self-bondage session I did last night (Escape Report here if you're interested in the sordid details ;P ), but oh my god I'm so grateful and thrilled that you're giving me a challenge! Looks really good and intense, bravo for lasting 20 minutes like that!
I might have to make some adjustments for my run (for one, I unfortunately can reach my pull-up bar and the tops of my doors from a standing position) but I'll DEFINITELY give this a go as soon as I'm not so sore anymore! Can't wait to see how long it takes me to get free~
Posted: Sun Dec 28, 2025 5:21 pm
by YourCaptor75
Posting this here so everyone can see and keep you accountable @CaptiveDan
You will drop a key at one end of your home and then go to the other. There you will hogtie yourself as tight as possible, in just your underwear, with earplugs, gag, and blindfold, as well as nipple clamps.
You have thirty minutes to get to your key. Every five minutes you take will get @Kishi an extra modifier to make the same challenge harder.
If you run out of time or give up by calling out to your boyfriend, you and Kishi will be both be given a forced workout as punishment.
Your best bet is to work as fast as possible, no matter how much it pushes you, for yer buddy
I'm not gonna tell you the extra challenges for Kishi yet. Good luck
Posted: Sun Dec 28, 2025 5:45 pm
by Kishi
YourCaptor75 wrote: 1 month ago Posting this here so everyone can see and keep you accountable @CaptiveDan
Only 30 minutes? Pshh, didn’t realize you were going to take it so easy on both of us. Either you escape or you don’t, @CaptiveDan ;P
Posted: Sun Dec 28, 2025 5:54 pm
by WhereAmI
Kishi will probably drop the keys just so he gets more pain added to his time.
Posted: Sun Dec 28, 2025 6:14 pm
by YourCaptor75
Aight, bet. @CaptiveDan you don't have a time limit; put on a stopwatch instead of a timer.
@Kishi decided to open her big mouth. Maybe an extra harsh gag is in order 🤔
Posted: Sun Dec 28, 2025 6:47 pm
by Kishi
YourCaptor75 wrote: 1 month ago Aight, bet. @CaptiveDan you don't have a time limit; put on a stopwatch instead of a timer.
Fuck, uhm, I’m really sorry @CaptiveDan. I didn’t think before I said that out loud. Pleeeeease escape as fast as you can 😭
Posted: Sun Dec 28, 2025 10:06 pm
by Kishi
CaptiveDan wrote: 1 month ago Here's a predicament bondage position for @Kishi or anyone else who wants to try it! Note it's a bit intense and involves a good amount of torture. I tried it out in myself, but with only one set of keys/clamps instead of the full multiple sets.
Here's what you do:
I was still very very sore this morning but between you @CaptiveDan and @YourCaptor75 both I had no real choice...
So here's my Escape Report! Like I mentioned earlier there were some modifications I had to make but I tried my best to preserve the spirit of the challenge as closely as possible!
Of course I immediately stripped to my boxer-briefs before getting started. I fished around the hamper until I found a perfect pair of dirty socks to gag myself with. They were somewhat thick ankle socks, so it was a tight squeeze cramming them into my mouth, but I managed. I secured my muzzle harness over my head, which kept the socks very tightly pressed in, and readied a padded blindfold over my forehead.
I set up my pull up bar and tied off a loop of rope dangling a couple feet from the center. Like you said, knots far out of reach. I set a padlock hanging open from the loop of rope to secure my hands to later. One more thing was I set down an old college textbook directly beneath, to give me a pedestal to balance on.
I set up both of my release strings, deliberately losing track of which keyring was the correct one before securing one at the end of each 100ft length of string.
This is where I diverged a bit from your plan. There aren't many pebbles in the immediate vicinity of my apartment, and I really really didn't want to go on an adventure searching, so I had to skip this part. Additionally, I can reach the tops of my doorframes, and consequently my pull up bar, from a standing position, so I couldn't do the flamingo posture. I still tried my best to make it as strenuous as possible, though!
I brought both feet up frogtie style, using leather cuffs to secure ankle to thigh. I also brought out my 2B electro unit and stuck on a pair of tens pads spanning the length of each inner thigh.
I locked on a pair of wrist cuffs with two of my smaller padlocks.
I've been using my clover clamps a lot lately, so I wanted to mix things up a bit. I attached clothespins in two columns running down my body, from each side of my chest, over my nipples, down either side of my abs. I feel pretty clever about how I incorporated the release strings into this. Of course clothespins have that circular gap in the middle to run a clothesline through, so that's exactly what I did. Each string ran up through the corresponding column of clips, with the free ends tied to the corresponding wrist cuff. This way, the string would travel freely until the keyring at the end would eventually bump up against the clips and force me to pull them off, one by one, running up the length of my body.
I crawled up onto the textbook, standing on my toes, and reached up to confirm that I could just about touch the dangling padlock.
At this point, I was pretty much completely out of excuses to not turn on the electro. I set it to a quick pulse setting, and slowly started dialing up the strength. My inner thighs began rhythmically contracting harder and harder, more and more painfully, but I guess part of me wanted to impress you guys so I kept going until it was just about unbearable, and just about impossible to keep my legs under control. 80% power, if anyone happens to have the same unit for reference.
I frantically pulled down the blindfold, climbed back onto the textbook, and fumbled around trying to find the lock again. I had to stand on my tip toes, feet fully flexed, back fully arched, chest fully pushed up, reaching up with my entire body to grab hold of it, and I didn't hesitate to stick the D-rings of my cuffs in and slam it shut.
Immediately, I tried to relax, slump into the bondage, you know? But I essentially couldn't. There was zero slack from the very top to the very bottom of my body. I had to maintain that agonizingly stiff posture, standing on the tips of my toes, calves flexed, back stringently arched, or else all of my weight would immediately come down on my wrists and shoulders.
The electro wasn't any help either. I quickly ran out of stamina to keep my legs steady, and the contractions forced them to slam shut, crushing my cock between my thighs. The rhythmic contractions were insanely overstimulating. Every fiber of my being wanted to double over and pull my hips back to escape it, but I had no choice but to keep my posture steady.
My legs are strong but they're not that strong. I was shaking within minutes from the intense strain of what was essentially a never-ending squat, standing on my flexed toes, with my inner thighs violently contracting like crazy.
I figured righty-tighty, lefty-loosey dictated that I had to try the left string first lol. I was hanging on for dear life just trying to stay focused on the task at hand: reeling in the string. It was honestly a massive relief when I felt the resistance of the keyring bumping up against the first of the clothespins, meant I was getting close.
Pulling the clips off was a pleasant sort of gentle pain, more pleasurable than anything else, which got steadily more intense the farther along I got, and the closer I got to my chest (by far the most sensitive part of my body). It was a stark contrast to the electrocution hell happening below the belt.
Unfortunately, left ended up being the correct choice, and I was home free soon after.
All in all, it took me about 45 minutes to free myself. And not that you asked, but I climaxed three times from the constant crushing between my thighs. I definitely overdid the electro. Lot of tears, a few sobs. But this was a really fun predicament to try! Thank you so much Dan for this creative little challenge! I hope I didn't disappoint ;P
Pretty sure this counts as a completely insane leg day, so I'll be skipping over that at the gym tomorrow. God I'm so fucking sore...
Posted: Sun Dec 28, 2025 10:23 pm
by YourCaptor75
@Kishi
Proud of you
Keep working hard. (Not like you have much choice)
Posted: Sun Dec 28, 2025 10:42 pm
by Kishi
YourCaptor75 wrote: 1 month ago @Kishi
Proud of you
That's my secret, Cap'. I'm always hard~
Fr though thank you! Was really rough doing that so soon after my last tie. Rules are rules though, haha. No backing out now!
Speaking of things I have no choice in, starting to feel a little nervous about how CaptiveDan is going to do on his Challenge. Guessing there's no limit to how far my modifiers can build up now? Kinda can't stop thinking about what that'll look like for me. Haha...
Posted: Sun Dec 28, 2025 10:45 pm
by YourCaptor75
Keep opening your big mouth, that has been a good strategy so far ;)
Posted: Tue Dec 30, 2025 12:48 pm
by CaptiveDan
I did it!
It took me 43 minutes and 14 seconds.
Some takeaways:
One, it was very fun! A really good escape/predicament challenge.
The nipple clamps pulled off pretty quick with all the movement against the floor. Hurt like a bitch as it happened though. Blindfold also slid off from all my movement (switch to just keeping my eyes closed)... Guess I'll need to get some sort of hood :twisted:
I managed to hogtie myself incredibly effectively. Like no escape without the key. I've done this a few times before but I'm not consistent, so it was nice to get it on the first try this time. I did so by tying my legs in frogties (futomoto), then tying a chest harness on myself, I made a loop in the back of the chest harness than ran the excess rope down to my ankles, which I then tied together. The knot to the chest harness was down my my feet. I then locked wrist cuffs on, and padlocked them behind my back to the chest harness loop.
Locking my cuffs to the harness meant I couldn't pull them down to reach the knot at my feet. The combination futo and tied ankles kept my legs pulled up and out, butterfly style.
► Show Spoiler
This position was quite strenuous on its own. There was alot of pressure on my legs, chest, and core. I'd put the key on the other side of the apartment in the other room, and the truth sank in fast that I was trapped until I got all the way over there.
I began my journey. Squirming on the floor was slow, but I could make myself move. The clothespins hurt as expected, but quickly yanked off in all my struggling. The real torture came from my fucking carpet. Wiggling on carpet hurt my bare skin like a bitch.
Within 5 minutes I was sweaty and tired. I wanted out, but couldn't get out without subjecting myself to more. A few minutes later I needed a break. I'd made it to the hardwood of the other room. I figured out I could give myself a break by flipping over onto my back. This was awkward and took a few tries, but I got it. On my back, the pressure from my muscles was alleviated, and the mostly mental shortness of breath from the prone position was gone. I hated resting because of what it meant for @Kishi, but if I didn't pace myself I'd never make it to the key, would give up and beg my boyfriend for help, and no doubt totally fail the challenge.
The problem with laying on my back was I couldn't move as much. So after a break I flipped back over and continued to squirm on the floor. My bf was nearby playing video games and laughed a bit when he saw me. He'd made it clear he wasn't going to join in today, which was totally fine, but it was nice to know he was at least a little entertained. He asked if I was okay and I grunted and nodded my head.
Slowly I made it towards the key. We had left so much shit on the ground from Christmas things that it was actually pretty easy to navigate blind. The problem came from tight spaces and constantly bumping stuff.
I made it to the key and found it by sliding over it. I got it in my hand and tried to flip myself over so I could rest and start the untying process, but found I was pinned between furniture and couldn't get off my front.
I was forced to unlock myself in the deeply uncomfortable, very sore, prone hogtie position. It took actually quite a while, but I eventually managed to do it!
Thanks for the challenge @YourCaptor75 , good luck with your part @Kishi
Re: (18+) Self-Bondage Ideas, Challenges, and Reports (18+)
Posted: Tue Dec 30, 2025 1:29 pm
by YourCaptor75
Proud of you @CaptiveDan
You worked hard and pushed yourself. Hearing that yiu cut your rest short for @Kishi is exactly the kind of discipline I was aiming to cultivate.
Now for the bad news. I said no time limit, which is true, but I never said the penalty for going over 30 minutes went away 🐺
You are both assigned a total of 5 minutes of planks and 2 minutes of wall sits.
And @Kishi since you decided to get cocky, we'll be rounding his time UP to 45 minutes. That is 9 additional penalties for you when you complete the challenge.
Well done Dan. I'm proud of you for not giving up, and for putting on a good show for us and your bf lol. Celerbate your performance with some rest and relaxation before your workout
Posted: Tue Dec 30, 2025 5:28 pm
by Kishi
Hell yeah @CaptiveDan!!!
Really happy you had fun with this. You really went above and beyond too! That hogtie looks and sounds fantastic!
Thank you so much for thinking of me and pushing yourself! I knew you could do it! Genuinely though, really impressed and proud that you persevered!
Holy shit 9 penalties though 😭 haha. How’s that even going to work?
Posted: Tue Dec 30, 2025 9:20 pm
by YourCaptor75
Kishi wrote: 4 weeks ago Hell yeah @CaptiveDan!!!
Here's how the ELEVEN penaltied @CaptiveDan and your big mouth got you are goint to work
Long socks over arms
- Elbows tied
- Knees tied
- Toes tied
- Crotch harness / bulge tied
- Muzzle gag
- Ankles to muzzle / Body arched backwards
- Butt plug or toy (a big one, I want you to feel like each wiggle is you getting f*cked
-Tied-off bulge pulling as much as you can carry, and remember I have you by the balls, bitch 🐺
-Mouth stuffed with 2 socks and some briefs. Be smart about your stuffing, full but breathable
-Tight underwear hood. Dirty obviously. My preference is briefs, as they suit you.
No bitching, begging, or backtalk. You're mine and this is for your own good. Respond 'yessir thank you sir' and be a good example to the other subs 🐺
Posted: Tue Dec 30, 2025 9:39 pm
by YourCaptor75
Oh I almost forgot
Hide the key inside a sock and then mix that into a pile of your dirty laundry.
Have fun
Remember your proper response 🐺
Posted: Tue Dec 30, 2025 9:50 pm
by Kishi
YourCaptor75 wrote: 4 weeks ago Here's how the ELEVEN penaltied @CaptiveDan and your big mouth got you are goint to work
- Elbows tied
- Knees tied
- Toes tied
- Muzzle gag
YourCaptor75 wrote: 4 weeks ago Oh I almost forgot
Have fun
Thank you, Sir…
Wish me luck @CaptiveDan! Hopefully I’ll still be able to free myself like you did 😭… I’ll set a stopwatch too so we can compare!
Posted: Tue Dec 30, 2025 9:55 pm
by YourCaptor75
- Elbows tied
- Knees tied
- Toes tied
- Muzzle gag
Have fun
Thank you, Sir…
That's *almost* how I told you to respond. Read carefully
@CaptiveDan do you think that error is worthy of another punishment? 🤔
Posted: Fri Jan 02, 2026 8:36 pm
by Kishi
Sorry for the delay, I ended up doing my part of the challenge last night! Hope my performance is up to snuff.
5 hours and 46 fucking minutes.
I have to agree with @CaptiveDan, this was very fun! But man this came really close to breaking me.
A quick recap of the binding:
First, as always: the gag. As @YourCaptor75 specified, I stuffed two socks into my cheeks, then crammed a pair of my own briefs in between. I held off on the underwear hood and the muzzle for now, since my bf’s boxers aren’t very see-through. I inserted a pair of foam ear plugs though, like specified in the original challenge ;P
Next, the plug. I have an almost fist-sized, egg-shaped transparent plug that I really like, so I worked that in before putting on a tight pair of briefs.
I know this wasn’t specified, but @CaptiveDan you’ve really been pushing yourself, and it’s inspiring me to push myself just as hard! I used all 6 pairs of clover clamps I own. Starting at my nipples, and running a “zipper” up along either side of my chest.
Next, the crotch harness. I isolated the bulge of my briefs pretty brutally, and left a few feet of rope dangling from it. Nonstop throbbing from this point on.
I started the actual tying pretty similar to Dan’s tie. Frogtied my legs (only with cuffs instead of rope), tied a belt just above and below my knees, and used some duct tape to tie my big toes together. I tied a very basic chest harness, and tightened a rope back to my ankles until my back was pretty severely arched.
You said as much weight as I could carry, and I took this to heart. To the end of my crotch harness bulge rope, I tied my backpack, with all of my physical college textbooks in it. Had to have been 30 pounds or more.
I finished my head bondage by stretching the boxers over the top of my head, using my blindfold to hold it in place, then putting on my muzzle gag harness to hold everything neatly (and tightly) together. I used another length of rope to tie my head back to the belts at my knees. I was trying to be as cruel as possible, putting myself in the harshest arch I could.
The arm bondage was extremely difficult to do in this state lol. My socks stretched up to my upper arms, cuffs above my elbows, then my wrist cuffs locked on with the padlocks whose key was across my apartment, in a sock, in a dirty laundry hamper…
I used a belt to pull my elbow cuffs strainingly close together behind my back, then quickly used the last of the padlocks to lock my wrists together, pinned to the base of my crotch rope, just behind my already-aching bulge.
Now, the escape:
Immediately, my heart was racing. It took a while for the “holy shit, I just did that” feeling to subside enough to think. But time was wasting. I had to start my journey.
I had to fight for every millimeter of progress, straining and lunging with my whole body. And every little motion mashed my bulge against the floor, crushed my belly around the huge plug, and bounced every clamp against my chest.
I came, violently, before I’d even made it far enough to pull all the slack out of the backpack rope.
I was already starting to sweat. When I did finally make it the 1 or 2 feet to start actually dragging the backpack, my heart sank as my progress basically slammed into a brick wall.
I had to fight even harder now, torturing my cock and balls with every twitch. I thought it was slow before, but this was a whole new level.
@CaptiveDan was right, my skin dragging on the carpet was brutal. It only got worse the sweatier I got.
I must’ve been having a climax every 5 feet. Between the relentless yanking on my bulge, the pummeling of the plug, the clamps ruthlessly tormenting my whole chest… It was humiliating.
It was disruptive, too. I found myself falling on my side repeatedly. It was impossible to make just about any progress lying on my side, and it was a struggle every time to re-right myself.
Navigating was a little difficult, too. My spatial awareness is also pretty awful, so I really had no choice but to try to move forward until I bumped into something. Try to guess what it is, where that puts me, and go from there. Blind and deaf, that was literally all I could do.
I’m pretty sure I ended up going in a circle in my living room but I have no way to prove it. Between the impossibility of concentrating, and the constant falling over, I really had no way of being sure I was ever actually traveling in a straight line.
Even with the constant agony, I had no choice but to take numerous rest breaks. My body just couldn’t take the constant monumental straining. Sitting still just made all the stimulation hit all the worse though, with nothing else to distract me.
I could feel the sweat pouring down my entire body. The plug hurt like hell. Everything did, really.
Words cannot describe the relief I felt when I bumped up against the hamper in my study. But this also proved extremely difficult. My arms were so thoroughly restrained they were no help. I had to bump into the hamper until it fell over, then wriggle around and try to use my body to identify where the correct sock was.
I don’t know how long it took. But there was a lot of screaming, and crying, in frustration. This is where I really came close to breaking.
The despair was unreal. The dirty clothes got spread further around the room the more I searched, making the search exponentially slower the longer it took me.
But eventually I obviously did find the key, and eventually I did manipulate it out of the sock and into one of my wrist cuff padlocks.
I got free of the wrist cuffs and just fell over limp, sore from head to toe, and so, so fucking exhausted.
By the time I’d finished untying myself, the stopwatch read 5 hours and 46 minutes. Dragged myself to the couch (closer than the bed) and immediately passed out.
Thanks for playing this game with me you guys! I think I’ve learned my lesson to not run my mouth so much… Maybe the next challenge can be something a little less grueling? Haha
Posted: Fri Jan 02, 2026 8:49 pm
by YourCaptor75
I have no words to describe the pride I feel.
Good girl.
But, remember your manners. Thank me for this experience
Posted: Fri Jan 02, 2026 8:55 pm
by Kishi
YourCaptor75 wrote: 3 weeks ago I have no words to describe the pride I feel.
Good girl.
Thank you, @YourCaptor75. And thank you @CaptiveDan!!
Posted: Fri Jan 02, 2026 9:41 pm
by sock slave boy
Seriously Kishi, you're a wonderful person, you're so cool
