The Lifeguard (F) (Voted POV Story)
- lanadelgagged
Option C wins unanimously!
"Let go of me you creep. HELP! SOMEONE HELP ME!"
Enough is enough, her deafening shrieks pierce your ears as they echo across the locker room. Your heart begins beating faster, and the nerves of being caught send an adrenaline rush through your head. It's time to act. Your arm stretches reaching for the lifeguard's duffle bag, barely reaching it with the tip of your fingers. Her rocking motions hinder your movement, but after a short-lived struggle, you manage to push her body forward enough to reach the pair of rolled-up socks in your hand. As her screams continue, you see the perfect chance: her open mouth allows the socks to slip between her lips. Without a sliver of hesitation, you press the palm of your hand against her lips, clamping them shut and cramming the socks deeper inside her mouth until they lodge between her teeth. Her full mouth defines a slight bulge on her rosy cheeks, but most importantly, the screams suffocate into muffled garble.
"MMMMMPPGHHHHH!" - The acrid taste of her socks is enough to force her to voice her complaints as audibly as the garment allows. For a few moments, she wrenches her body in every direction possible in an attempt to escape your grip, causing you to work hard to keep your hand clamped over her mouth. But after resisting the initial struggle, you can sense her stamina decreases significantly. You sigh in relief, the solution might be momentary but it has served to reduce her complaints into incoherent mumble. Even with her forces significantly dwindling, you know she's not giving up that easily.
Once again you survey your surroundings as you think about your next course of action. First on the storage room, then averting your gaze back to the first aid kit on the wall...
You decide to:
A. Resist her struggles and pull her body towards the storage closet, and then tie her up using the rope from the pool lanes.
B. Stretch your arm to open the medicine cabinet, in the hopes of finding tape or bandages to secure the socks inside her mouth.
You decide to:
Bondage writer and graphic designer. https://www.deviantart.com/lanadelgagged
Put a sock in it!
Put a sock in it!
A, it’ll be easier to finish the gag if she’s not fighting you as hard
Beautifully and clearly written, [mention]lanadelgagged[/mention]. You make me feel like an actual observer.
I think option B at this point. You might be in trouble if she gets the socks out and screams. Finish the gag, then tie her up.
A List of my stories:An Unlikely Savior Completed
Spy Task Force Completed
Tale of an Archer Completed
- Switcher1313
B. Silence her first so you' ll have time and options.
A I would like to hear her plead and beg
bradhabitz
Option B!
I've just found this, blasted though the chapters, such good reading.
Liking the short format, offering up choices quickly. Great setup too.
Vote wise, I'd love to see her tied up with that pool rope, what a fun thought
But. I'm going with the current majority, that gag needs properly securing.
B. Please.
B. Please.
I would do A. Thank you this is an amazing story.
It would be bad form for me to pressure you to continue, @lanadelgagged. So I will not. I won't. Like hell, I won't. This is just too good not to be continued.
- GwenGagged
I’d vote C if this is still going in!
