QUARRY (multiple cases of M/m and M/M)
QUARRY (13)
A Fine Hunting Day
Both HC’s were chained together by the rings at the tops of their bridles and Rhys, being the one in front only hoped that it would be the chain from the top of his bridle or even the choke-chain and not the wire noose next. As he felt and heard the device slipped round his neck and himself jerked forwards, he almost gave a sigh of relief when nothing cut into his neck as the chain tightened and then loosened again as the other purchase started to move.
Even with the less strict arm clamp in place, the lactic acid was building up in Rhys’s arms and the metal was still digging into his wrists whenever he didn’t position them correctly. The thought of running once more with that spiteful spiked cage enclosing his genitals quickly doused the tiny spark of optimism that Rhys had recently permitted himself. As his body became more accustomed to the routine, it adapted and responded differently. Rhys only hoped the adrenaline that had fuelled his previous escapes from the trophy cabinet would soon rage through his body again. Even the sound of the boy’s practice shots hadn’t triggered his adrenal gland into action yet.
The gate to the release pen slammed shut and both quarry were forced to their knees before their blindfolds were unlocked. A slave offered water which Rhys gratefully accepted but the other purchase declined. His trembling was extreme and, even without the metal plate weighing his head down, he couldn’t bring himself to raise his head and look around. Rhys noticed that they were going to be hunted over the second reserve; that gave him an advantage over his rival again. He couldn’t afford to let even a sliver of complacency or even compassion pierce his consciousness; he needed the fear to start the chemicals running through him.
The gate opened and the father and son entered. THEN the chemicals started flowing. Breathing quickened, time slowed down and Rhys prepared himself almost like a sprinter waiting in the blocks. The father seemed not to have stopped giving his son advice since Rhys had last heard him. Could he disregard the presence of those he was discussing and talk like that? Yes, it’s because they didn’t have rights any more, not since they’d become Hardened Criminals.
The chain connecting the purchases together was removed, along with the choke chain, and Rhys was out of the release pen almost before the gate was opened. He knew he was going to head off for at least a mile before changing direction. Should he head for the gulley that had concealed him previously? Would the purchaser know where he’d hidden before? How long did he have to find an alternative hiding place? The cage round his more delicate parts tormented him even more than usual but he didn’t have time to ask why; he just needed to stop for a while.
He found a hollow facing away from most approaches and listened. He waited even though the adrenaline surge demanded that he do something. He waited and listened. He waited for about an hour, an hour that lasted a day. Then he heard it: the sound of somebody creeping stealthily in his direction. It was decision time. If he stayed put, he was probably concealed from the direction of approach; but what if whoever it was turned around soon after they’d passed?
Rhys waited, the sound of approach continued and Rhys heard the breathing in spite of the way his heart beat against his healing ribs. It was almost certainly the other quarry. He stayed put. The young blonde passed Rhys quite some distance away and Rhys, once he had caught sight of him, worked his way round a nearby tree to keep himself out of sight. The younger quarry was moving even more clumsily than he would have been forced to by the arm clamp and the cock cage but his recent wound had not re-opened. Just for a moment, a long moment, Rhys hoped that his rival would bleed all over the ground so that he could be easily tracked. Could he catch up with him and knock the other potential trophy over? He could try to open his wound by raking it with his bridle and, perhaps even break a few ribs in the process of bringing him down. At least he could slow him down a bit.
His plans died on the page; even Rhys’s torments had not stripped him of all humanity.
Rhys decided to wait. He could see the other quarry if he returned and trying to do the same with the young hunter, if he appeared, as he had just done with his rival seemed like as good an idea as anything else he could come up with. But suppose the hunter came from a different direction? Only one other would give him a direct view of Rhys and the other quarry had just gone in that direction. Rhys decided to wait.
Endgame
Crouching in the hollow, Rhys continued to listen and eventually heard the slow approach of what he assumed to be the young hunter. He wasn’t going to make the mistake of impetuosity this time. He had taken his time zigzagging his way through the reserve. The sound of his approach moved from left to right behind Rhys and back again. Rhys judged that the gunman had passed him and was grateful for the extensive tree cover between them as the sound reversed again. Rhys took the risk of standing and his previous technique of keeping the nearby tree between himself and his pursuer paid off for a second time. The young hunter continued quartering and moving off into the distance.
Rhys had a decision to make. Should he stay and hope that the hunter wouldn’t return? Should he move away from where the gun was heading? The need for survival won out over humanity as Rhys hoped against hope that he’d hear a shot in the distance. Rhys waited. Surely the three hours must be up. How would he know? Rhys panicked. The hunter must return soon. Rhys ran.
After nearly a mile, Rhys came to the edge of the clearing around the reserve. Was crossing it worth a try? The razor wire was too deep before he’d even be able to get near the fence. Then he heard the sound behind him and the siren and barking off to the right. What the fuck was that for? He turned to face the original noise and saw him approaching, gun levelled and pointing in his direction. As he backed into the open space, the lights flashed and the alarms sounded. Rhys continued backing up across the two hundred metre wide clearing with the hunter moving inexorably towards him. Once he was up against the wire, there was nowhere left to run and the young hunter continued to close in as did the dog. Every convulsive movement of Rhys’s body now caused the wire to flex, and every flex of the wire caused punctures and lacerations to his back, his arms and his legs. By now Rhys could hardly breathe and didn’t even notice the lacerations any more.
The boy stopped about ten metres short of where Rhys was gradually being impaled on the coils of wire. He knelt. He took careful aim and squeezed the trigger. He swore luridly.
The gun didn’t fire. He should have known better but he was desperate to win his first trophy. The siren indicated that time was up and justice decreed that the quarry had survived another hunt. The hi-tech rifle had automatically been remotely disabled after the permitted three hours and the Supervisor had set the dog to find the quarry.
The furious hunter stood. Tears of rage formed in his eyes as he continued towards Rhys with the gun shouldered and the barrel being held by both hands. If he wasn’t going to take a trophy home, at least he’d shred this bastard before he left.
TBC.
blackbound
Post by blackbound »
Damaging the merchandise after losing access rights? That sounds like a crime to me!
You'd think so, wouldn't you? What a pity it's not what you do but who you (or, more exctly, your father) knows.
Snozzberry
Post by Snozzberry »
Shredded Rhys Krispies does not sound very good at all, It will probably be an action that leads to the little snot nose crybaby becoming a convicted criminal at least in my humble opinion). But since Rhys is the Hero, the story can't end with him being Shredded. :o :shock:
When I was growing up Shredded Rice was one of my favorite cereals. Shredded Rhys doesn't sound as appetizing. 🤢🤮
It might simply be the Welsh spelling?
My dislike for this whiney little shit that seems to always get his way, is growing by the chapter. Be such a shame if he took a wrong step and ended up in the wire himself. My prediction, with this attitude, he'll eventually end up being hunted instead of hunting.
Rhys is getting closer and closer to getting his freedom back. Can he make it!
Don't forget: whiney, spoiled little shits have been known to become Prime Ministers and Presidents.
I wonder how much more Rhys can take without some recovery time.
Jb99
Post by Jb99 »
Really hope Junior experiences the hunt from the other side of the fence (so to speak)!
blackbound
Xtc wrote: 4 months ago Don't forget: whiney, spoiled little shits have been known to become Prime Ministers and Presidents.
The Italians knew what to do with this scum.
Unfortunately a certain extant Pres. ha a look of Il Duce about him, don't you think?
blackbound
Xtc wrote: 4 months ago Unfortunately a certain extant Pres. ha a look of Il Duce about him, don't you think?
Not nearly upside down enough - but let's not devolve further into the ugliness of the everyday world.
Agreed, my friend.
Jb99
Post by Jb99 »
Jb99 wrote: 4 months ago Really hope Junior experiences the hunt from the other side of the fence (so to speak)!
Or maybe his father gets pinged for attempted bribery and the salesman gets to market them as father and son quarry. That would be an interesting dilemma!
No dilemma whatsoever as long as it is not the first offence for either of them.
Perhaps they would make a special offer at one of the forthcoming festivals?
While I usually stray away from politics on public forms, even I have to admit that was a little funny :lol:. But yes, let's try to keep those real life things out of here. This place is meant to fun after all!
That's a good question. But it would seem as though Rhys has been growing more determined to not give up. I like his spirit. And unless someone tries to screw him over (which wouldn't surprise me given I think there's some corruption going on in the background), he's only got 2 more auctions/hunts to go!
Let's hope that's the way he sees it. Let's hope also that he is fit when he returns to the fray.
Post by Wedgieboy69 »
Rhys needs to pistol whip the little brat and throw him in the wire before the dog gets there.
Difficult with his arms clamped behind him. I regret that, once one is accepted into the embrace of that wire, escape is a complicated (and somewhat painful) process.
@blackbound, @Bradstick, @Caldo203, @harveygasson, @Jb99, @Red86, @Snozzberry, and @Wedgieboy69, here's part 14.
QUARRY (14)
Protecting the Investment
Rhys was more or less immobilised by the time the boy came to within two metres of striking distance.
The growling noise had never been so welcome before as the German shepherd came and positioned herself between the two boys. She didn’t go down as usual but stood snarling at the hunter. That sound was even more blood-chilling than her usual, noisy warning barks. If Rhys had been afraid of the creature in the past, he now knew what she looked like when she really meant business. The hunter backed off.
The boy’s arms dropped to his sides, the gun fell to the ground and the boy fell to his knees. His head and shoulders drooped and he wept the hot tears of disappointment and temper. The dog went down but neither Rhys nor the hunter was going to take the chance of moving any more than necessary.
Before long, the Supervisor and his slaves arrived with the father in a 4 × 4 and the supervisor picked up the gun and completed the disarming of the weapon. The father knelt down and tried to comfort the distraught boy; it made a change for the kid’s tears to be genuine: the supervisor was sorry that, with the father present, he couldn’t fetch the spoilt brat a good clout round the head for damaging valuable sales goods.
Father and son climbed into the front of the vehicle while the supervisor assessed the state of the merchandise. He detailed two of the slaves to disentangle Rhys and apply some field dressings but, realising the delicacy of the task, he removed the bridle from the more experienced slave. It was usually considered more convenient to lock the bridles onto slaves in case they needed removing to facilitate their work unlike the way the devices were riveted onto the quarry. The supervisor then
departed with one slave and the dog to locate the other quarry.
Rhys was becoming accustomed to receiving first aid from the slave who could speak and who was now advising him to keep as still as possible while he assessed his predicament. Following a quick visual assessment he started giving his colleague instructions on how they could remove Rhys from the razor wire as gently as possible. It took about two minutes to complete the task but they did manage to keep any further cuts to a minimum. The slave comforted the squealing Rhys as best he could, while he wiped him over with an antiseptic that caused more pain in the smaller cuts than the cuts themselves had caused, and looked him over to locate the most serious wounds. Fortunately, in spite of the bloody appearance of Rhys’s back, arms and legs, all of them were superficial and only one on the fleshy part of his thigh would need stitching.
The slave in charge apologised before locking the metal blindfold onto the front of Rhys’s bridle while the other one got a rigid stretcher from the back of the ATV. Rhys was laid face down on the stretcher and strapped onto it by his arms and his ankles. He was lifted into the back of the vehicle and his bridle was strapped so that he could not move his head, which was held in a small depression in the surface. One more thick strap was pulled tight around Rhys’s waist and the stretcher was clipped into place.
Rhys was obviously not going to be fit for the sales stand for quite some time so no super-glue was applied to the largest of his lacerations. The two stitches, however, as they were put in, caused the almost completely immobilised HC to rattle the carabiners securing the stretcher to the vehicle even though he’d had warning of the procedure. By the time all of Rhys’s cuts had been covered with surgical plasters, the slaves might just have well covered his entire back, his arms and the backs of his legs with overlapping layers of wide Elastoplast.
In spite of the stoicism Rhys had been determined to display since the start of his sentence, his muted groaning was virtually continuous throughout the procedure. The slave looked round and, seeing no one watching, placed his hands comfortingly on Rhys’s shoulders, where he could see no lacerations, and tried to comfort him. “Shh. Don’t let the bastards hear you. Don’t let them know they’re winning.” They were the first words of comfort Rhys had heard since his arrest.
His job done, the “first aid” slave resignedly licked his lips, replaced his bridle, tightened it and snapped the padlock closed. He knew better than to let the supervisor see him without it once he no longer needed to speak and he really didn’t want anyone to use that savage, toothed tongue-clamp on him again. He knew that, as long as he didn’t mess up, he would soon be released into society again and, having seen what happened to two-time losers at first hand, he was going to make sure it wasn’t going to happen to him. The two slaves knelt and, with their arms folded behind them, awaited the return of the supervisor.
After the first-aid ministrations were complete, it wasn’t long before the Supervisor returned with the other blindfolded quarry in tow. He examined the job that had been done on Rhys and expressed his satisfaction with it. The slave risked a visible sigh of relief. The Supervisor needed to decide whether Rhys should be made to walk back to the holding pen as usual or whether there was a good reason to transport him in the 4 × 4.
The argument for using the vehicle was, as far as the supervisor was concerned, overwhelming. Once Rhys had been properly patched up, tattooed again and been given a couple of weeks’ recovery time and exercise, his value would exceed the cost of any effort put into his recovery. Five tallies on a piece of merchandise would command a very good price indeed. Not many HC’s survived that often and scarcity value alone boosted their value. That, and the challenge of stalking the most experienced prey attracted very wealthy sporting types to the sales.
One of the slaves jerked the other piece of merchandise to its feet and set off for the holding pen with it while the ATV set off for the service centre. At least this time the merchandise wouldn’t need too much repair but the Supervisor decided to try to bid-up the time available to allow Rhys’s cuts to heal and the subsequent scars to fade and for the exercise regime to restore a certain amount of muscle tone to his abused body. He’d try for a month. In that time, they should be able to transform Rhys into the most prime lot to have been presented on the sales stand for at least a year. The Manager should be very pleased indeed
TBC.
Rhys in one way is lucky the wire did the damage it did. Sounds like he's about to get a month off before going back to the sales stand. Though it seems as though getting his 5th tally may be coming with a price. A higher price that could spell disaster for him. Still rooting for this so called "Hardened criminal" though!!
That's what makes to bookies' profits! And from that, the state rakes in the taxes.
OK, @blackbound, @Bradstick, @Caldo203, @harveygasson , @Jb99, @Red86, @Snozzberry , and @Wedgieboy69, here's the next part.
QUARRY (15)
Repairs
Rhys arrived at the service centre once more but he wasn’t taken to a service bay like the previous one, not that he could tell yet as he was carried in on the stretcher and he heard his porters leave. He remembered the next voice he heard. The doctor gave abrupt orders to, “Get that thing off and that. Don’t damage the goods – no burns, no more cuts. Then I need to look at the injuries. Call me when you’re ready.”
Very soon after that something had been forced between Rhys’s arms and his back, his arms and hands were covered with some sort of heavy fabric and the noise started, he recognised the procedure as the clamp was cut from his wrists. His whole body was shaken as the angle grinder did its work and the wrist loops were jemmied open. At least he could feel no spark burns this time but he was sure his wounds had been shaken open once more. About that he was correct. Once freed, Rhys’s wrists were strapped to the surface and the other straps round his arms were removed.
The straps immobilising his head were loosened slightly and Rhys felt the top ring of the bridle being pulled down to the surface forcing his chin into his neck. The cramped space that had just been created between the back of his neck and his bridle was stuffed with something solid that seemed to cover the whole of the back of his neck and some more heavy, wet fabric was draped over his head. That noise and smell again accompanied an intense shaking of his head, immediately preceding the sudden release of the bridle but Rhys’s cry of alarm was still firmly muffled by the gag until the entire device could be distorted and his head wrenched free of it.
The resultant cry was as much one of relief as of pain as Rhys’s mouth was pulled clear of the wedge. Rhys felt a hand reach round the front of his face and clamp itself over his mouth. The hand pressed hard against Rhys’s mouth a few times and, by the time the metal bridle had been removed and Rhys’s head lain gently down again, he had taken the hint and was determined to maintain his customary silence.
Rhys’s determination did not outlast the far from gentle removal of the sticking plaster from his extensively lacerated back. He did manage to keep his head face down in the padded and ventilated depression that had recently accommodated the front of his bridle while the stupid thought that he could do with a gag right now for something to bite on went through his mind.
Rhys heard someone approach and the Doctor’s voice saying, “Strap him in properly” as he placed his fingers on the back of his head. A wide strap soon prevented Rhys from lifting his head which, still being accommodated in the depression was also unable to turn to any appreciable degree. He was effectively blindfolded again but at least he could breathe more easily this time.
Expert hands worked silently over Rhys’s wounds, cleansing them painfully and applying adhesive sutures where needed. Rhys was far from silent during the procedure but the Doctor seemed prepared to indulge him all the while he was carrying out treatment but he still offered no words of comfort while he worked. There was no warning even when the stitches were removed from the gash in Rhys’s thigh prior to a body-wrenching swabbing of the wound before the stitches were replaced. A heavy adhesive dressing was then applied, drawing the sides of the wound closely together. “That will need a week” said the Doctor not to Rhys but to his electronic notebook.
The doctor left and, as far as Rhys could tell, so did anyone else who was in the room. In spite of being face down, Rhys had fallen into a deep sleep by the time the porters returned.
There were obviously several people surrounding him as the drowsy Hardened Criminal came to his senses once more but, as usual, no one seemed over-interested in addressing him directly as they went about their appointed tasks.
The strap holding Rhys’s head into its niche was unfastened and a device rather like a wide, part-padded elastic band about the thickness of a car inner tube was pulled over his eyes before he got a chance to see anything of any significance. The padding was held rather too firmly over his eyes and even impinged somewhat on the sides of his nose. He managed a feeble, “Ple . . .,” before a rubber tongue was forced into his mouth, trapping his own tongue and nearly forcing him to gag. This wasn’t like the panel gag he’d been forced to wear the last time he was in the Service Centre, it had no panel and the tongue, part of which had a hole in it and protruded from the front of his mouth, was attached to an inch-wide bit that held it in place. It was pulled hard back into his mouth, nearly tearing the sides of his mouth, and padlocked.
Not that Rhys knew it but the nurse with the red shorts inspected him to see if any stypsis was necessary, especially to the gash on Rhys’s leg. Having found no need for it, he announced that he’d check again tomorrow and that, “You’d better make sure that you don’t stress that leg too much for at least a week.” Rhys could hear a barefooted exit from wherever he was.
“Turn him over.” Rhys recognised the slightly accented voice of the muscular physio who’d helped to repair him previously. His wrists and ankles were unstrapped and two pairs of hands did as their owners had been instructed. “Wrists, ankles, waist and neck. Make them tight.” Soon Rhys was strapped supine and immovably on the surface. He was no longer sure for how much longer he would be able to control his bowels and bladder but he knew better than to let go. It was fortunate for him that the physio considered that the next procedure would be better carried out once his charge had been “cleaned out”. Once he’d told the slaves that he just meant urine and faeces, Rhys received the relief he badly needed. There was no more shame, just an acceptance of the inevitable as first the bottle and then the bed-pan were positioned. Rhys couldn’t have stopped himself in any case. “Clean him off.” That was still humiliating.
Rhys felt a hand clamped over his cock cage. He immediately convulsed at the feel of the touch and his penis immediately tried to spring into life causing the inevitable pain as it came into contact with the internal spikes. Even with the wide strap round his waist, Rhys managed to arch his back slightly before the voice of the physio tried to reassure him. That in itself was not what Rhys had come to expect. “I need you to do some very vigorous exercises for the next few weeks and this thing,” he said as he tweeked the metal cage, “Won’t help as your legs work. Just understand that, if you so much as touch yourself or try to give yourself relief in any way, there are alternatives, one of
which would render the wearing of such a device redundant in any case. Do you understand?”
Rhys nodded and “Efff’d” as best he could. Life might be a painful barrel of shit but he’d prefer to suffer it in as in-tact a state as was possible.
“Cut it off. Leave the rings. And their spikes. We’ll only have to put another one on once he’s repaired.” Having been without a full erection for so long, Rhys’s body reacted predictably as the tube was cut free. That resulted in a certain amount of tearing as the tube was removed. Rhys didn’t bother to try to maintain his usual stoical silence. He couldn’t. The removal of the spiked metal sac from his scrotum was painless in comparison. Rhys’s screaming gradually subsided into very heavy breathing as he felt his parts relatively free for the first time since he’d started his sentence. That erection hurt. Tears started to form. Even involuntarily, Rhys tried to move his hands to his engorged member. It’s probably fortunate that he was unable to reach. He knew that there would be no delay in “altering him”, as the euphemism has it, if he had done so.
The physio and the slaves went about their jobs as if nothing untoward was happening and Rhys was even glad of the blindfold; if he couldn’t see them, perhaps they couldn’t see him. More pain came as Rhys’s newly unconfined penis was disinfected, the tears examined and the leakage wiped away. All were considered to be little more than superficial scratches that could be treated with disinfectant a couple of times. Not the best news Rhys had heard that day.
“Give him until five-to then take him into the corner, hose him down and give him a good scrubbing but be careful of the dressings.” The physio then went to his laptop to examine his notes and to plan Rhys’s repair schedule.
TBC
Snozzberry
Poor Rhys after months and months of wearing an internal Spike Cock Cage finally having it cut off and not being able to enjoy the resulting Erection and The Abundance of Cum Downloaded. Don't enjoy it Rhys or touchie, touchie and lose it forever, this is definitely not the time to belive in USE IT OR LOSE IT. RHYS definitely needs to recuperate for the next hunt session. 🪢🥾🪢🥾🪢 :D :mrgreen: :shock:
