Hello all! Long time reader, first time poster. I recently thought I had a somewhat unique idea for a "story" that may be worth posting, I'll see if people like the basic idea and possibly expand upon it in the future.
Silencing Special Task Force Log
Log Preface: As per the orders of the Ministry of Silence and Her Majesty the Empress in the Silencing Special Task Force Act of 2050, the Silencing Special Task Force (informally referred to as the “HUSH Forceâ€) was created and assigned with the task of secretly and discretely apprehending those deemed enemies of the Empress by the Ministry of Silence, and keeping them silenced and removed from society. Prisoners have not been harmed nor are they permitted to be so, but are to remain silenced and removed from general society for varying amounts of time, depending on the nature of their offense.
Agent Info: Silencing agents are in peak physical condition and able to move quickly and with stealth. Agents wear sound cancelling gloves capable of neutralizing sound when the hand is tightly held over a prisoners mouth. Agents are also equipped with sound cancelling adhesive tape for the purpose of restraining and silencing a prisoner during their abduction. The Silencing Special Task Force is called to action when a target is not to be harmed, but must be effectively silenced and removed from society without drawing attention.
Prisoner Info: Prisoners of the Silencing Special Task Force are individuals deemed problematic by the government of the Empress and marked for apprehension by the Task Force. Prisoners (labelled as “the hushedâ€) are kept strictly removed from society and not to be heard from until their decided release date. Prisoners are required to be kept restrained and gagged at all times, speech from the prisoner is not to be permitted (aside from limited occasions, such as during feeding or during interrogation for information).
Glossary of Terms:
Sound Cancelling Material: Much of the material at the disposal of Silencing Agents is made of special fabric which is effective and preventing sound from traveling through it. The gloves of agents are made of this material, as are the different materials used to gag and silence prisoners.
Tier 1 Light Gag: Sound cancelling cloth tied between teeth in the mouth of the prisoner. To be used on compliant prisoners who have minimal problematic potential.
Tier 2 Moderate Gag: Mouth sealed with sound cancelling adhesive tape. To be used on prisoners who display resistance and a moderately noncompliant nature.
Tier 3 Heavy Gag: Mouth fitted with a sound cancelling rubber ball and a sound cancelling leather gag fitted very tightly over the prisoners mouth and lower half of the face. To be used on especially problematic prisoners who are to be silenced despite their persistent attempts to produce noise.
Prisoner Briefs - Standard issue for male prisoners, tight fitting briefs covering the genitals and leaving much of the body exposed to instill psychological submission into the prisoner.
Prisoner Leotard - Standard issue for female prisoners, tightly contours to the body to instill psychological submission into the prisoner.
Prisoner Log:
Prisoner Name and ID: John Eric (ID: 1687)
Sex: Male
Build: Fit, Little Body Hair
Garment Assigned: Prisoner Briefs
Restraint: Limbs secured to restraint table, prisoner face up
Blindfold: Yes
Gag Type: (Tier 2 Moderate) Mouth sealed with sound cancelling adhesive tape (Note: Prisoner is noncompliant and attempts to produce noise, consider upgrading to heavier and more effective gag)
Prisoner Offense: Prisoner is outspoken protestor of the Empress, was ordered abducted by the Ministry of Silence
Sedated: No (Use is under consideration)
Apprehension Detail: Prisoner was forcefully administered chloroform while isolated in private area and apprehended. Prisoner resisted until rendered unconscious, unable to alert other citizens due to mouth neutralized by the hand of the silencing agent
Status: Not to be released until further notice given by authorities
Prisoner Name and ID: Tyler Garrison (ID: 2687)
Sex: Male
Build: Slender, No Body Hair
Blindfold: Yes
Gag Type: (Tier 1 Light) Sound cancelling cloth tied between teeth in the mouth of the prisoner (Note: Prisoner is docile and does not resist, thus only light gag is required. Regulations require that prisoner be gagged even if docile and submissive)
Prisoner Offense: Prisoner was accidental witness to abduction of Prisoner ID: 3371, silencing and abduction of subject was required.
Sedated: No
Apprehension Detail: Prisoner was physically restrained with mouth neutralized by agents hand, was bound, gagged, and carried off.
Status: To be released in three months unless otherwise specified
Prisoner Name and ID: Kayla Harris (ID: 3178)
Sex: Female
Build: Slender
Garment Assigned: Prisoner Leotard
Blindfold: Yes
Prisoner Offense: Prisoner is associated with protestors of the Empress, was ordered abducted by the Ministry of Silence
Sedated: No
Apprehension Detail: Prisoner was silenced while asleep in bed, and abducted at night.
Status: To be released in seven months unless otherwise specified
Prisoner Name and ID: Paul Silverman (ID: 3418)
Sex: Male
Build: Muscular, Slight Body Hair
Garment Assigned: Prisoner Briefs (requested by Empress to be pink colored and very tight fitting)
Restraint: Tightly restrained in hogtie position, face down, kept in the private company of the Empress at her pleasure for unknown purposes
Blindfold: Yes
Gag Type: (Tier 3 Heavy) Mouth fitted with a sound cancelling rubber ball and a sound cancelling leather gag fitted very tightly over the prisoners mouth and lower half of the face (Note: Prisoner is combative and struggles violently, however the heavy gag is sufficient to keep prisoner effectively silenced)
Prisoner Offense: Prisoner is a longtime political enemy of Empress, was ordered abducted directly by the Her Majesty the Empress, is considered a high value prisoner
Sedated: Yes
Apprehension Detail: Prisoner was forcefully administered chloroform while isolated in private area and apprehended. Prisoner resisted until rendered unconscious, unable to alert other citizens due to mouth neutralized by the silencing agent
Status: Not to be released until stated directly by the Empress
Prisoner Name and ID: Angela Neilsen (ID: 3575)
Sex: Female
Build: Fit
Restraint: Fastened to wall for interrogation purposes
Blindfold: Yes
Gag Type: (Tier 2 Moderate) Mouth sealed with sound cancelling adhesive tape (Note: Prisoner is to be temporarily ungagged to give a chance to answer questions, is immediately to be gagged while being given physical persuasion or after an answer is given)
Prisoner Offense: Prisoner is known to contain valuable information leading to preemptively apprehending protestor movement.
Sedated: No
Status: To be released two days after information is given by prisoner
Silencing Special Task Force (aka "Hush Force") Prisoner Log (??/MF)
- Viperbound7
Being a fan of procedural stories, I love how this is written as a mission report/dossier. This actually has my attention! I'd love to learn more about the Ministry Of Silence!
- DeeperThanRed
This is an excellent idea for a bondage story! I loved the technical details and assigned garments. Paul being restrained tightly and at the mercy of his enemy in an emasculating position was great.
If you expand on this in the future, you have a fan right there.
